Fills up ok from very beginning but switch does not move any further. can stop and move manually by hand but does not spin dry either
    President:
  • 1,554 Answers
It sounds like the timer is not working and the drive belt/coupler is broken depending on the make and model of the machine. Please be advised that we want to give you specific and accurate troubleshooting and repair advice but I cannot be possible without knowing the make and the exact model number of the machine.
Please indicate the make and the exact model number of the machine before troubleshooting can push through and appropriate advice is given. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 08, 2010
Kenmore 417.97922701 washer tub will spin but will not agitate
Disconnect power to the unit.
Does the agitator move freely in both directions by hand?
Could be your agitator coupler needs to be replace
Also need to verify the lid switch and pressure switch are working properly. Let me know if you need further assistance
Nov 10, 2014 | Washing Machines
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
Tub filled with water, but nothing happened after that. power outlet is ok. switch was on, but not moving through the cycle. water is still in the tub.
Programmer or motor faulty
Try moving the progam on to Spin and see if it drains out
Once it is dry it should try to spin if not you are back to the two original options
Jul 03, 2009 | Kenmore Washing Machines
Washing machine overflowing
the valve on your inlet pipe may be faulty, have the valve checked or buy a new valve, not very dear, around $30 australian
May 30, 2009 | Whirlpool AWZ412 Front Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Mar 13, 2009 | Washing Machines
Telmann washing machine TEL6TL
Telemann TEL6tl E2 Problem
E2 on screen means the lid is not closing properly and thus not activating the (hidden) switch that prevents the machine from spinning while the lid is up.
The lid switch in this model is not a direct contact switch between lid and switch , but it switches on and off due to a MAGNET embedded in the lid on the left hand side near the front. You will see a small indentation where the magnet SHOULD BE. My magnet had fallen off, so the lid could not activate the operation switch. I had lost the original magnet( about 1cm X 2cm) so glued another into place.
Machine is now fully operational again, and the job cost .78c.
If your magnet is still in place, the E2 fault could lay with the switch itself , which is fixed to the underside of the top casing of the machine near the front right hand side of the lid cavity. The switch measures 1cm X 3cm heavily black tape insulated. Access is gained by popping the 2 X2cm discs at front top of machine and releasing the 2 small philips screws here and a further 2 at the back top of machine. This operation of replacing the switch is best left to an electrician or washing machine specialist.
Hope that helps
Apostle95
Nov 01, 2008 | Dishwashers
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
