Question about Whirlpool Ovens
Why does food get hard after cooking or reheating in a microwave
  • Whirlpool Expert
  • 414 Answers
It's basically a loss of moisture during the cooking process, to avoid this in a standard oven cook on a lower temp for longer and cover with foil....in the microwave, drop the power setting and always reheat or cook with the food cover with a microwave safe cling wrap or microwave specific cookware with lids.
Hope this helps.
Posted on Sep 08, 2010
I would not recommend that you "cook" a fresh pizza with raw pizza dough in a microwave . A frozen pizza designed for microwave "cooking", which is actually defrosting and "crisping" a frozen precooked pizza on a silver colored sheet, will have instructions on the box as to power level(s) and time(s). It really depends on the number of servings and size of the pizza. Also, is it a thin, standard or thrown pizza crust? Or, perhaps what's commonly known as a "french bread" frozen pizza?
For reheating any pizza, I recommend not the microwave but a good quality 10-12" skillet. Lightly brush a non-stick pan with olive oil. Bring up to medium heat, place pizza in pan, cover, leave on heat for two minutes and remove from heat. Check after 2 minutes and remove for eating when it has reached desired temperature and crispness!
Posted on May 19, 2012
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    I want to reheat a strawberry (already) baked,but frozen pie and do not want it soggy
    Defrost in the microwave and then place in a heated oven. Or if you have a convection microwave you can do it in the one action. Cheers
    Dec 16, 2016 | Ovens
    MICROWAVE OVEN HOW TO USE POWER LEVEL AND COOKING TIME. For example a want to cook pizza what will i use?
    We probably need a little more info on your particular oven before suggesting what power levels and times. Do you know the wattage of it i.e 900w?
    Does it have presets on it? Your manufacturer may have put auto programs on it to reheat, cook from frozen etc.
    Final hint: If you are buying things such as frozen pizza, microwave dinners, the microwave instructions are usually on the box with a recommend time for a particular wattage oven.
    May 04, 2011 | Ovens
    We have bought a microwave oven of GOODMANS "ME21S" .We want to know whether it can work as a oven for baking?
    no i dont think your micro wave oven can be used for baking it is only limited to what it is used for that is for only warming and cooking some small foods
    Dec 23, 2010 | Ovens
    The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
    The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
    Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
    Pleace HELP!!! How do I set the clock on my Russell Hobbs RHM1712 microwave?
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day.
    Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
    Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
    Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours.
    The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat.
    A small indicator light will come on below the word to tell you the cooking temperature.
    thank and thanks for using fixya.
    Aug 20, 2010 | Ovens
    The Microwave equipment does not heat any thing when placed on the turntable. The turntable rotates, all the functions appears to be in place , but food does not get heated / cooked Model CE 945G (...
    first check the HT fuse enlosed in a black or gray case or the micro switches at the door is faulty, if ok then the magnetron is dead and need replacement.
    Aug 06, 2010 | Ovens
    We have recently purchased a Coopers halogen oven. I cooked a frozen fruit pie in it and the pastry looked beautiful, but when it was cut open the middle was cold and the pastry under the fruit not cooked....
    Frozen food should be defrosted before cooking in halogen ovens.
    Halogen ovens use only radiant heat and will not cook the centre of frozen food.
    Jan 21, 2010 | Ovens
    Large oven burning food on top shelf when in fan assisted mode
    Always cook food in the middle of the oven. Assuming this is an electric oven, there is a heating element up there that will cause burning of food, much like a broiler works.
    If you must cook that high up in the oven, then cover the food your cooking with foil.
    Dec 16, 2009 | Kenmore Ovens
    OTR Microwave Magnetron Fan and Interior Light Run with Door Open
    Could be a defective door interlock or control board.
    Mar 06, 2017 | Ovens
    Ovens Logo
    289 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
