Question about Whirlpool AWM8143 Front Load Washer
I have a LG Intellowasher 7.2kg WD-8050F model as soon as it start to wash the temp light are flickering and it doesnt want to wash again can you help me please
Temp lights flashing LG intellowasher WD 80100tp
it appears the diagnostic computer has found a problem with the water inlet servos and may need replacing contact LG for replacement parts
Jul 29, 2016 | LG Washing Machines
Lg intellowasher wd 10160f
Check the Lid Switch Assembly with an Ohm meter for continuity, these switches are a common problem. Replace the switch assembly if faulty.
Mar 18, 2014 | LG Washing Machines
Need the operating manual for a lg intellowasher 7.5 wd-1018c
go to www.lg.com/au then click on product support left hand side of screen then type in wd-1018c in search box under box high lighted in red wd-1018c washing machine comes up. click on it. half way down page down load pdf for manual
Oct 10, 2010 | Washing Machines
I do not know how to undo the child lock on my LG intellowasher Model no.WD-8013F
The Child Lock can be activated and deactivated by pressing and holding both the Temp button and the right Option button simultaneously for 3 seconds as shown below.
Let us know if this procedure fails to deactivate the Child Lock feature for further troubleshooting and repair advice.
Aug 23, 2010 | LG Washing Machines
Washing Machine stops in cycle.
The ECU seems bad.
Look for the service manual inside and do the diagnostic test to see what is wrong.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Washing Machines
My LG intellowasher DD WM1480 FDH washer displays DE (door open) and refuses to start, if I repeatedly open and close door sometimes it will start or the door will lock and it still doesnt start.
I have this problem too for my LG Intellowasher. I suspect it is because you're selecting "Rinse Hold" from the options. Try turning the power off and washing again on another setting to see if this resolves the issue.
May 03, 2008 | Washing Machines
Whirlpool AWM8143 Front Load Washer Logo
151 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
