Question about Sony DHCNXM2D Hi-Fi Stereo System Shelf System
HOW TO CONNECT DHC-NXM 2D MINI HI-FI SYSTEM TO COMPUTER FOR CONVERTING AUDIO CASSETTE TO CD.
5 Suggested Answers
  • 13 Answers
SOURCE: playing a M.d. that has been recorded in long play!
This system is too old to support long play minidiscs, only systems with MDLP written on them or the HiMD systems will play and record mindiscs in long play mode.
Posted on Sep 01, 2009
welcomejee
  • 10594 Answers
SOURCE: I need a owners manual for a Sony Mini Hi-Fi
Click Sony Support to download user manual of MHC-GX250
Thanks.
Posted on Nov 25, 2009
  • 3289 Answers
SOURCE: What is the total WATT
According to page 24 of the manual, it delivers 11 Watts RMS (route mean squared) per channel into 8 ohm speakers.
Elsewhere in the manual, you'll see references to "15 watts per channel" and as much as "25 watts per channel". The 15 watt value is valid when putting up with some 10% THD (total harmonic distortion), this value is 11 times higher than the .9% THD value given for 11 watts per channel. You tolerate .9% THD now, but you wouldn't want to listen to anything with 10% THD. The 25 watts per channel is what they call "Music Power". Watts is an electrical term, "music power" is not. You could use it to compare other devices that only offer "music power" values, but the best indication of how it will perform is based on watts in RMS, into an 8 Ohm load (most speakers are 8 ohms). The lowest THD values are best.
From the manual:
AUDIO POWER SPECIFICATIONS
POWER OUTPUT AND TOTAL HARMONIC
DISTORTION:
With 8 ohm loads, both channels driven, from
70 - 20,000 Hz; rated 11 watts per channel
minimum RMS power, with no more than
0.9% total harmonic distortion from 250
milliwatts to rated output.
I hope this helped!
Posted on Nov 23, 2010
lestat_001
SOURCE: Power shuts off when CD/tuner/Tape Button is pressed
check your wires for your speakers/sub. when i added an extention to the wires for my stereo, if they become loose or rub together they short out the system and it will shut off like mine did
Posted on Jul 19, 2012
How to record a cassette tape to a cd
Your question is posted under a "CD Shelf System" heading. If you really have one of these, the answer is "you can't". The CD player is a player only, not a recorder.
On the other hand, if what you're asking is how to transfer cassette tapes to CD using a computer, there are a couple of ways. One is to connect a cassette player (boom box, component system cassette deck, etc.) to the line-in jack of your computer's sound card. Download and install Audacity, which is free software for recording and editing sound. Then you can record the sound from your cassettes as you play them into the computer.
Another option, If you want to be fancy and spend a little money, is to buy a USB cassette deck. It automatically converts the cassette audio to digital and sends it to your computer over a USB cable. Recording software is supplied (sometimes the Audacity program mentioned before). Several companies make them. Here's one from a company called ION that some friends of mine have, and it seems to work well for them. They've been converting a lot of tapes of family members, and Audacity has been good for cleaning up tape hiss and enhancing the sound.
Either way, once you have the sound in your computer and processed to your liking, you just need to burn it to a CD using whatever burning software you have. (I use CDBurnerXP. It's free, easy to use, and does everything needed for normal CD and DVD burning.)
Aug 10, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
We need a manual of Sony mini hi-fi component system mhc-5600
The manual that you are looking for can be downloaded here http://www.nodevice.com/manual/sonymans/manual2435pdf/get3955.html In order to view the PDF file you will need to have Adobe Reader installed. This is provided free from their website, http://get.adobe.com/uk/reader/ djrydr.pngThis would be the first page from the manual. Hope this helps, and good luck DJRYDR
Jul 27, 2011 | Sony 720W 5-Disc Mini Hi-Fi Component...
Sony Mini - Hi Fi MHC - EC55 won't play CD's. Says it is "Reading" then says "No Disk". I have used lens cleaner and reset factory settings. Any ideas
If you've already tried to clean the lens then with no improvement then its down to the laser having failed.
In some cases these are availble as a replacement part but aren't normally cost effective.
Jul 11, 2011 | Sony 720W 5-Disc Mini Hi-Fi Component...
CD burned on my computer won't play back on my Sony Mini Hi-Fi Component System MHC-NX1. I'm using Memorex Music CD-R and the burned CD will play back on my other stereo systems.
you have probles with a driver try to unistall the driver on the cd or dvd burner and automatic it will install the driver the pc will look for the driver on c:hdd if the porblem continue call 956 400 4141 I'm a computer technician send me you info and i will repair you computer problem.
Nov 27, 2010 | Sony 720W 5-Disc Mini Hi-Fi Component...
Stuck a disc, removed it and display says ''no disc''
Solution: In a fit of disgust, I threw the thing in the trash dumpster! So there! I'll just go buy another cheap one.
Mar 23, 2009 | Sony 720W 5-Disc Mini Hi-Fi Component...
Playing a M.d. that has been recorded in long play!
Dec 20, 2008 | Sony DHC-MD333 Shelf System
Dvd wont play in mini hi fi system
First, you should never use commercial cleaners on CDs or cassette heads. They can create more problems than cures.
Unit may have bad disk motor or optical pick-up
May 01, 2008 | Audio Players & Recorders
Cd jumps tracks
The CD lens may need cleaning.
Try a 'wet' CD lens cleaner.
The laser PU may be low emision.
Nov 09, 2007 | Emerson MS9700 CD Shelf System
Sony DHCNXM2D Hi-Fi Stereo System Shelf System Logo
60 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
