Question about Brother LS-2125 Mechanical Sewing Machine
I was sewing and after I changed the bobbin, all of a sudden I couldn't pull up the bottom thread. It seems like the bobbin didn't move at all. What shuld I do? Please help.
    Genius:
  • 1,788 Answers
Put your bobbin back in, look at your manual for placement. I think that your don't have yours threaded right and inserted the way it should be.
Posted on Sep 08, 2010
In my electric sewing machine, i came to unique problem , thread is not coming up even i changed niddle and bobbin. In short no problem in thread and in bobbin.I faced this problem when i was...
Try moving bobbin shuttle, the outer "hook" piece that travels around the bobbin housing, to see if it will re-seat into correct position.
Oct 26, 2014 | Sewing Machines
Thread is bunching up in bottom.
It sounds like you have no tension on the bottom bobbin reel. Did you check your tension on the bobbin reel. The tension must be right on both sides. When pulling on the cotton when the reel is in its bobbin case you need to feel a little resistance. Adjust the tiny srew on the bobbin case to tighten the reel to avoid it to turn in the casing.
Jan 11, 2014 | Brother PE770 Computerized Sewing Machine
Bobbin won't move
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is wound correctly & inserted correctly
into the bobbin case
if these suggestions don't help then you might think about having
the machine checked at a sewing machine shop
Aug 05, 2012 | Brother PC-420
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
Bobbin thread tangles
when this happens have you check to see if the thread has come off the thread take up lever?
Feb 09, 2012 | Brother CE5000 Computerized Sewing Machine
My bottom thread is a real mess when I sew. The
I would suggest to replace the bobbin case,
make sure the needle is not in backwards
make sure the needle is not bent
Jul 29, 2010 | Brother BC-1000 Computerized Sewing...
Thread bunches up under the fabric
For normal everyday fabric, tension should be 3-5.
If it is looping on the bottom, the problem is the threading of the machine. If it loops on the top then the problem is with the bobbin.
Mar 22, 2009 | Singer 3116 Simple
Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Apr 30, 2008 | Brother PE-150V Computerized Sewing...
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Free Motion Sewing - Jams
The Designer 1 usually has a very nice free motion stitch using the V1 stitch. It should pull only slightly to the rear so that no bobbin thread shows while doing free motion embroidery. Upper tension may be increased for balanced stitch when stippling.
If your machine doesn't sew with the regular stitches with the teeth up, and it's properly threaded, the thread must be dragging on the bobbin case somewhere. First get the machine sewing a straight line, then try V1 again.
Feb 19, 2008 | Husqvarna Designer I
Brother LS-2125 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
