Nokia 5130 Cellular Phone Logo
Posted on Sep 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Giving contact service error. - Nokia 5130 Cellular Phone
Anonymous
Level 3:
President:
  • Master 1,118 Answers
  • Posted on Sep 08, 2010
Anonymous
Master
Level 3:
President:
Answers
1118
Questions
0
Helped
276585
Points
4142
My Dear Brother:
Flash The Phone With Latest softwear Version
Contact service problem will Quickly Solved
OR:
contact service center And Hilp the Service Oprator
1helpful
2answers
Error code B200 PIXMA MX452
Error B200 is a print head overheat error. Just need a new printhead. You should see the power and alarm lights flash on and off 10 times then repeat the cycle. That's confirms the fault more than the error code. Its very simple to fit a head, just be careful putting the new one in as it's easy to break the pins in the carriage. No force is needed when fitting the head. Just let it drop in and lock the lever. Try taking out the old head first and gently clean the contacts at the back as they can rarely make poor contact with the carriage pins.
Good luck
Error code E0000001-0002
That's a fuser temperature code that will need to be cleared in service mode. Press the additional functions key * then press 2
Canon MX860 printer is showing: "Error B200 Printer error has occured. Unplug the power cord and contact the service center." I have unplugged the printer and plugged it back in -- there is not...
It is my pleasure to guide you.
After looking at some information about the printer error and that the error tells you to "contact the service center" I have given you places to contact about this error. Some of the information that I have looked at about the error said that several things can cause the error. I suggest that you contact Cannon through the 'Email Assistance'.
Service & Support
Support Home ' http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx860#
Email Assistance ' http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx860#
Solutions List:
Contact Canon for B200 error (MX860)
Press ON switch and wait a few minutes before powering back on the device
Good luck and please post back that you are successful, giving thumbs up, or if I can be more helpful.
Can't update your console. Please contact xbox customer service
your best bet is to contact customer service and give them the error code
My brother dcp-330c was unable to clean 46
If you are giving the error as 46 see below the error chart fix. I hope this gets you going and thanks for using Fixya. The number is 800-284-4329 What the error is saying is shown below. I copy and pasted so let me know if it doesn't show up for you and thanks for using FixYa.
Error 46 Ink absorber pad is full...replace it contact brother customer service.
46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us".
3helpful
2answers
My nokia 5130 express music shows contact service in red when i switch on the phone. pls suggest me the solution
Welcome toFixYa
Dear user
You have to Re flash your Phone if its due to Software damage. Some times hardware Error also leads to this trouble.RPL file damage also makes this error to phone.
Its better to give authorized service center if you are under warranty.
Contact service will shows in some models due to water damage...
Thanks for Connecting FixYa...
1helpful
My nokia 5310 has not free from contact service so plz give me a
I think you mean "contact service" error message, if this is the problem, then this is the biggest problem with every mobile. You first need to check it in software and see whether it can boot from the software. (better get it repaired by an experienced technician)This problem is mostly caused by database corrupt(software/firmware) and cpu failure.. Good luck..
1helpful
I get an error message, E:91:01 blinking ,I can't find Reset bottom under LCD cover
Hi!
It's flash error. Could be a dead flash fuse on the main board or bad flash board. Contact your local Sony service center, but if they ask too much, you can contact me at [email protected] and I will give you a good price.
I work in Sony service center.
Tom
When i turn on my canon C2620, it gives me the error E000001-003
what is the error code it is giving?? write it down and re submit it
Error 16
Dear Rashid,
I understand that this errors occurs in POST mode. You can always refer to service manual or troubleshooting guide of your machine upon purchase especially it displays error code. However not all error codes are not servicable for ordinary users due to risk. To give you an idea in solving the problem; present this error code to authorized service center and offer them to purchase the defective parts regarding this error, or you can troubleshoot by detaching or removing running parts one at a time. We'll see if the error changes. Contact me if there are progress, I can help you pin-point the problem somehow I can resell parts soonest with this type of printers.
Best regards,
Rosener Guyano
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
