Question about Philips Health & Beauty
I have qg3060 from Canada. Am in New Zealand now, tried to charge it using power adapter. The light on the adapter/cord came on at first but doesn't now. When I turn the trimmer on, it works for about a minute and dies. What do you think is the problem?
Benzschwagel
  • 33 Answers
SOURCE: HP Pavilion dv4000 battery won't charge
all you really need to do to find out if it might be broken is to check and see if that DC Jack on the computer is "wiggling" around, if the center part is moving around. If it is, then there is a chance that it is broken. I used to work at a computer store where the owner would resolder new DC power Jacks into laptops, but he was the only one in town who did that. So you might want to check around at the local computer repair or electronics stores to see if someone does that type of thing. Also, have the power supply checked out, it could just be dead.
Posted on Mar 25, 2009
stif_NEC
  • 441 Answers
SOURCE: hp compaq nx7400 - battery died and power cord will not turn comp
If your system won't boot up with just the AC adapter connected, it means to say that there's a problem with the AC adapter or the motherboard of the computer. Basically, if the AC adapter or the motherboard is damaged, you won't get a charged battery. If there's another AC adapter that you can try your computer with then that will be great. If antoher AC adapter works, then you just have the AC adapter replaced. If a known AC adapter didn't work then you may need to consider replacing the motherboard of the computer.
Posted on May 07, 2009
  • 370 Answers
SOURCE: Toshiba Satellite A15-S127 won't power up
here is a complete list of bios code...
http://www.pchell.com/hardware/beepcodes.shtml
you will need to find out what BIOS chip is on the mobo...
hope this helps you out, when mine did it, it was much easier than this i found a bad connection at the power plug.
Posted on Aug 23, 2009
rick_stokes_
  • 61 Answers
SOURCE: the trimmer does not move although charged!
It sounds like you may need to oil the blades with the clipper oil that is included with the kit when you bought it. The blades will become gummy and sticky after use. The "Wahl oil" provided with the clipper is specially designed to "de-gum" the blades and let them move freely. The knob you speak of only holds it from rotating and should have any affect on run time. The only other possibility is if the rechargable battery is at the end of its life which shouldn't be the problem unless it has been used a great deal.
Posted on Sep 27, 2009
  • 87 Answers
SOURCE: Power cord isn't working for Acer 5720
I have had a similar problem but not with this PC. Some power cords look the same but are slightly different in design. They may fit but often the cords are built differently and over time the pins wear and lose contact.
First, try another power cord from something you know is working. If this doesn't solve the problem then we need to look at the power supply itself.
That may have blown or overheated and cooked something (it happens). If the CPU fan is dirty with dust and you use the PC on non-hard surface ie. no air flow underneath, you will cook the thing.
The fact that the power supply doesn't light up indicates to me its simple power cord problem or a dead supply.
Posted on Nov 05, 2009
No Power battery went dead I plug it in and still no power and it will not charge battery ether??
Your power inverter most likely has died or the connection between the inverter and the wall outlet cable has come loose. Most computer retailers sell universal power adapters you can test this with.
Mar 03, 2011 | Dell Latitude D510 Notebook
My acer laptop computer will not turn on, charge or anything. the charging cord has a flashing green light but no charge light on the computer.
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 11, 2010 | Acer Computers & Internet
Toshiba Satellite Pro L300-EZ1524 no longer charges. The jack seems ok (it's firm, not loose, and it is not pushed in). When the power cord is plugged in the light does not come on -- it no longer seems...
Sep 11, 2010 | Toshiba Satellite Pro L300 Notebook
Typing g would return me g5
Hi. Probably this already a hardware issue with your keyboard, you can double check this by updating first the keyboard driver, or try going to safe mode first to double check if this just a sotfware issue. Turn off your machine and right after you turn it on you should continously press the F8 button to how the Safemode menu, then choose safemode. On the safemode try using the keyboard if its still doing the same thing, and if yes this already a hardware issue. Last you could also try powerdraining it by removing the battery and unpluging the ac adapter then press and hold the power button for 20 seconds while the battery and ac adapter is out, after that place back the battery and plugin the ac adapter and turn on your computer and try the keyboard, if its still doing the same thing, then you should call Lenovo tech support if your machine is still under warranty and they would just replace your keyboard without any charge. This there number for LENOVO IDEAPAD: US/Canada:
Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia:
Available 24/7 1300-557-073
New Zealand:
9am-9pm Mon-Fri 0800-446-833
LENOVO THINKPAD:
US/Canada 1-800-426-7378
Australia 1-300-880-917
Hope this Helps
Jun 09, 2010 | Lenovo Keyboard
Can I change my printer power cord from a Euro 220 to US 110?
Yes All Printers Run On A DC Adapter. So Go Buy Any Power Pack For DC And It Will Work Just As Well As It Did In New Zealand
May 07, 2010 | Brother DCP 130C All-In-One InkJet Printer
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Can you use both 120 and 240 power
Canada is 120. U.K. is 240. This is only for the adapter (large block between PC and wall outlet). This adapter changes A.C. current from wall to D.C. current for laptop. If power adapter is from Canada.  You must buy a different power adapter.  These should be available in U.K. Bring old cords and block to computer store so you get the right plug and voltage.
May 10, 2009 | Acer Aspire One PC Notebook
The little orange light that comes on when the computer is charging just flashes and computer wont trun on what does this mean?
Make sure the power cord is securly connected to the computer and that it plugged in. Are you sure the battery isn't emty?
Try taking out the battery and leave the power cord plugged in and try to turn it on.
Mar 13, 2009 | Acer Aspire 4720 Notebook
Battery will not charge
Hi!
It's your ac adapter that is causing this issue. The ac adapter doesn't supply enough power or doesn't supply any power at all to the battery. Try to borrow another ac adapter from any inspiron system and if that works, then you need to replace the ac adapter, else, it's the motherboard.
Hope you find it helpful.
Thanks,
Karlox™ :)
Jul 28, 2008 | Dell Inspiron 1501 Notebook
Health & Beauty Logo
144 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
