Question about Cannon Office Equipment & Supplies
Error code 64 on Canon 3300IR Photocopy Machine
3 Suggested Answers
canontech
  • 1219 Answers
SOURCE: my photocopy of canon ir3100f the give massage
Wich code?
Here is examples:
E000 Insufficient temperature rise of the fixing unit at power-on
E001 Abnormality of the fixing unit
E002 Insufficient temperature rise of the fixing unit
E003 Low temperature of the fixing unit after standby
E004 Error of the protection circuit in the fixing unit
E006 Connection error of the fixing unit
E008 Life expectancy of the fixing roller
E010 Main motor error
E012 Drum motor error
E013 ITB waste toner full error
E014 Fixing motor error
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
E021 Developing rotary error
E026 Toner empty error
E032 The counter of the NE controller fails to operate.
E045 OHP sensor error
E067 High voltage-related error
E070 ITB HP detection error
E100 BD error
E110 Operation error of the laser scanner motor
E202 CIS unit HP detection error
E225 CIS light quantity error
E227 Power supply error in the reader unit
E243 Control panel unit error
E248 Backup memory error
E315 Abnormality of image data
E351 Main controller PCB error
E400 Feeder communication error
E490 Model error
E500 Finisher communication error
E503 *** Finisher internal communication error
E505 Finisher backup memory error
E514 *** Stack delivery error / **** End assist motor error
E519 **** Gear change motor error
E530 *** Rear alignment error / **** Front alignment error
E531 Staple error
E532 Staple unit shift error
E535 Swing error
E537 *** Front alignment error / **** Rear alignment error
E540 *** Stack tray up/down error / **** Upper tray up/down error
E542 **** Lower tray up/down error
E577 *** Paddle error
E580 Stack tray up/down error
E584 **** Shutter unit error
E590 ***** Puncher motor error
E591 ***** Puncher dust sensor error
E592 ***** Puncher side registration sensor error
E593 ***** Puncher shift motor error
E5F0 **** Saddle paper positioning error
E5F1 **** Saddle paper folder error
E5F2 **** Saddle guide error
E5F3 **** Saddle alignment error
E5F4 **** Saddle rear side staple error
E5F5 **** Saddle front side staple error
E5F6 **** Saddle paper push-on error
E5F8 **** Saddle connector error
E5F9 **** Saddle switch error
E601 Abnormality of image memory
E602 Hard disk error
E604 The image memory (SDRAM) is faulty/insufficient
E609 * Abnormal low temperature of the hard disk
E610 ** Failure in the hard disk cryptographic key
E674 FAX board communication error
E677 Abnormality of the external controller
E710 IPC initialization error
E711 IPC communication error
E712 Communication error between the ADF and the reader
E713 Communication error between the finisher and the printer
E717 Communication error with the NE controller
E719 Communication error with the coin vender/card reader
E730 PDL error
E731 UFR PCB error
E732 Reader communication error
E733 Printer communication error
E740 Abnormality of the Ethernet board
E743 DDI communication error
E744 Language file/BootROM error
E745 * Token ring board error
E746 * Option board error
E747 Main controller PCB error (Image processing ASIC or memory control/communication control
ASIC)
E748 ** Main controller PCB error
E749 ** Restart in accordance with a change of the product configuration
E803 Door close error
E804 Controller fan error
E805 Fan error
Posted on Jun 30, 2010
  • 158 Answers
SOURCE: error code C0202
this is a tray 1 lift up failure code pull the paper tray out and check to see if some torn paper is blocking the lift sensor look around where the paper is fed into the feed plates if not it could be a failed lift motor or sensor and they will need to be replaced
Posted on Dec 02, 2009
Error code E102-01 for canon ir7095
E102 - A read error has occurred in relation to the laser scanner unit EEPROM data.
theres a good chance that what is needed here is the laser scanner unit has a Beam Detect mirror and sensor and after time gets coated with foreign particles(dust) cleaning these mirrors/sensors will probably allow the unit to work again- this job should only be undertaken by a qualified service personnel, as more damage than good could be caused. if the laser scanner unit appears clean then iut will need replacing.
Jan 16, 2014 | Canon Office Equipment & Supplies
Canon ip4500 problematic with win 64bit - seeking solution
Go to a 64-bit machine on the network and copy the 64-bit driver files to the machine
From the 64-bit machine, open Windows Explorer and browse to the 32-bit server
Open the Printers dialog seen via Windows Explorer.
From the Menu bar, select File > Server Properties, select the Drivers tab and click the Add button.
In the Add Driver Wizard, tick the x64 Processor checkbox, and untick the x86 checkbox.
Click Next, then click Have Disk and browse to the 64-bit driver on the local 64-bit machine.
Complete the Add Driver Wizard.
for more help visit CBR Tech Solutions
Dec 07, 2012 | Canon Pixma iP4500 InkJet Printer
I am getting this error code message e000020-0000 on my canon ir2870 do you know what it is and how i can fix it
my canon ir 2270 photocopy machine k panel m baar comp. hone ko hota h. phir s restart ho jati h, kya problem hogi sir g
Apr 26, 2012 | Canon Office Equipment & Supplies
My canon photocopy machine displays an error code presenting as (E 000602 - 0003)Please help me solve this problem.
Hi these means that you have HDD trouble, and it needs to be changed and upload the system on it - CALL SERVICE.
Aug 19, 2010 | Canon Office Equipment & Supplies
May canon np 3020 ka machine liya hu. jab photocopy kiya jata hai to isme ek taraf kala aata hai. ye kis problam se aata hai
may canon np 3020 ka machine liya hu. jab photocopy kiya jata hai to isme ek taraf kala aata hai. ye kis problam se aata hai
Jul 24, 2010 | Canon Office Equipment & Supplies
Download standby,CANON IR 2016jphotocopy machine
Amanuel Getachew.
I faced this type of problem before. This type of error code or message may occurs when the system software of that machine is corrupted. So flash the machine with canon driver software. then it will be ready. good luck.
Apr 06, 2009 | Canon imageRUNNER 1023iF Black and White...
171 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
