I want to change my key settings to a softer touch how do i do it
    Scholar:
  • 95 Answers
Unless you are using a touch screen, simply replace your keyboard. most computer stores have keyboards on display so you can feel how soft the touch is before you buy a particular model.
Posted on Sep 08, 2010
Volume gets louder and softer without touching control
I would consult the mfr. to see if it is some known issue---possible causes are some problem with manual volume controls on set itself or a microprocessor problem inside the set.
Worth talking to the company to see if they are aware of this issue.
Mar 14, 2012 | Vizio Televison & Video
Is water hardness set at 19 softer or harder than water set at hardness level 25?
Water hardness set at 19 would be softer than 25...expressed as gpg or Grains Per Gallon
Nov 01, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
How to change display from Japanese to English
4-2. User’s Choice Function Setting Procedure
<Setting Procedure>
1. Press the User Mode key on the control panel and then touch the “User’s Choice” key.
2. Select the page number key that contains the desired function from among 1/6 through 6/6 shown YOURS WOULD BE 1/6
at the bottom of the Touch Panel.
3. Select the function to be set and make settings as required.
4. After the settings are complete, touch the “Enter” key to validate the settings.
NOTE:
The function selected is highlighted.
<Exiting the Mode>
Perform any one of the following steps to go back to the Basic screen.
 Press the Panel Reset key on the control panel.
 Touch “Exit” on the Touch Panel.
Language Selection
English
Select the language of the Touch Panel messages.
French
Dutch Italian Spanish
Portuguese Danish Norwegian
Swedish Finnish Greek
–Metric Areas–
English German French
Japanese Chinese Portuguese
Mar 18, 2010 | Minolta Office Equipment & Supplies
How do I unlock my router?? I want to add my ipod touch to my internet
If you have already setup your WEP key you would need to add that WEP key into you IPOD Touch settings.
Open up your IPOD Touch and click your Settings button. Touch your Wi-Fi option and turn on your Wi-Fi. Under Choose a Network you should see your SSID. When it ask you to put in your WEP Key just enter you key.
If you have not setup your WEP Key you need to open up a broswer and type in the following:
http://192.168.1.1
A screen will pop up requesting your user name and password. If you have changed your password place that in. If you have not changed the password then use the default admin. Leave the username blank.
Click on the Wireless Tab. Click on the sub tab Wireless Security. Set your WEP Key.
Hope that helps you!
Dec 31, 2009 | Linksys WRT160N Wireless Router
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
My photocopier has 3 drawers - First is universal and 2 & 3 are both set at letter. I would like to set drawer 3 to legal. how do I get the copier to recognize the change?
Please specify the models.Also the Minolta copiers paper tray change:Press utility key-User choice-paper set or
Utility-Meter count-Stop-0-Stop-0-0-1 Paper size input :set the paper size used in each paper source.Touch the key of paper sorce for wich the paper size setting is to be changed to show the paper size input screen.Touch the desired paper size keys.Touch END to validate the paper size setting.
Please look the mechanical setting in the trays.If so need,change.
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
I want to change my konica sitios 7020 printer to english,its in japanese
Procedure
Touch 1. System Initial on the Key Operator Mode Screen to display the System
Initial Setting Menu Screen.
2 Touch 2. Language to display the Language Selection Screen.
3 Touch ENGLISH, FRENCH, SPANISH, GERMAN, or ITALIAN
Touch OK to complete the setting and return to the System Initial Setting Menu
Screen.
5 Touch RETURN to restore the Key Operator Mode Screen.
6 If no further changes are required, touch RETURN to restore the Basic Screen to
perform copying operations
Jun 11, 2009 | Konica Minolta Office Equipment & Supplies
Disable the Key counter on my Konica 7130
HI,
Please refer the manual by clicking on the below link.This will solve your problem.
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Oct 07, 2008 | Office Equipment & Supplies
Changing the time
lift the speed dail flaps. touch the data registration key
when the display say user setting touch set key first one
option should be date& time if not scroll to it
when date and time is displayed touch set. then enter
date and time using number key pad then touch set.
finally touch stop.
TRM
Jun 04, 2008 | Canon LaserClass 9000L Plain Paper Fax
PROBLEM WITH LANGUAGE
#Press the FUNCTION Key $Select the COPIER SETTINGS in Function Setting mode. (See page 36) %Touch the H key to advance to the 02/02 Display Screen of Copier Settings menu. &Touch the 09 KEY OPERATOR MODE key. (Enter the Key Operator’s ID Code and then press the OK key. )Follow the on screen instructions. *After setting, touch the OK key in Display Panel. +Press the RESET key, then exit the Function mode The screen to change the language is 01/05 option (04)
Mar 27, 2008 | Panasonic Workio DP-2500E Copier
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
