Question about IBM E74 17" CRT Monitor
Lcd in by on by on blinking for vga - IBM E74 17" CRT Monitor
    Sergeant:
  • 237 Answers
Power cable or data cable connection loose please tight or after removing the connection do it again tightly
Posted on Sep 08, 2010
Acer c710 chromebook screen blinks
Plug a monitor to the vga port or a tv onto the hdmi port and start the laptop.
Still blinking but you can use it through the other screen?
->Cable inside the machine for the lcd screen damaged.
If you don't see anything on the second screen try CTRL+F4 to mirror the main screen if nothing happen then the video module is dead.
Feb 08, 2014 | Acer New C7 C710-2847 Chromebook 11.6"...
Blinking screen
The screen might be going bad, or the lcd cable could just be loose and needs to be reseated. The lcd would have to be taken apart to get to the cable.
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
If the external monitor you plugged in blinks then your video card has an issue. If not, it's the lcd screen.
May 06, 2012 | Toshiba Qosmio X305-Q725 PC Notebook
Power on power led blinking
Hello.
The LED blinking light usually means that the attached PC is not powered on or the VGA connector (end of cable connected from the monitor to the PC) on the monitor, the cable or the VGA port on the PC is faulty.
Try your monitor on another computer. If it works, there is a problem with your PC. If it doesn't work, the VGA connector, the monitor's VGA cable or the monitor itself, is faulty.
Hope this helps.
Jan 23, 2011 | LG Flatron L1710S 17" LCD Monitor
My moniter isnot open as soon i start pc it is blinking and after some time it get startes automatically
This is no a monitor problem, you should have problem with your Video Card, or Mother Board if you use the Built In Video, remember that a monitor is blinking while wait VGA signal from computer.
You can check too the VGA Cable to discart...
Jan 07, 2011 | Samsung SyncMaster 510N 15" LCD Monitor
My monitor wont show picture and if it does it has a sing saying vga blinking what do i do please help
Check all your cables and in a worst case senario use another monitor or select vga mode, by pressing f8 before booting into windows.
Aug 02, 2010 | Gateway FPD2275W LCD Monitor
Acer 5515 on external monitor
Get an VGA cable and connect your external monitor to your laptop via a VGA port that is usually used for digital projectors. In this VGA port, you can initiate dual monitors.
Then look at your keyboard and look an icon in your function keys (F1 to F12) that looks like a pair of an LCD and a TV like this {LCD icon/ TV icon}. In most laptop keyboards, this is located in F4.
When found, and with the external monitor hooked to the laptop via VGA port using a VGA cable, press and hold down the FN key and press the function key where the icons described above is located. Example, FN + F4 to toggle a single and a dual monitor.
Give it a try.
Jun 26, 2010 | Computers & Internet
Monitor is blinking green light but no dark screen
does you cpu have a built in vga or you use a separate card? check at the back of the cpu, if you are using a cpu that has a built in vga and youre using a separate vga card may you have just connected your lcd monitor on the built in in which many cases will not work you need to connect your lcd on the separate vga card, if that is not the case and you head a beeping sound with intervals then there a problem with your vga card now if you use built in video you need to put on a separate vga card agp or pci-e which ever is supported by your motherboard, hope this help
regards
michael
Nov 20, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Blinking BENQ FP531 continuosly...
you probably have a loose wire in the unit, you might have a bad vga cable, except for the vga cable, you will probably need to send it in for service.
Apr 18, 2009 | BenQ FP531S (Silver) 15" LCD Monitor
Princeton LCD17 blinks off immediately
Check the VGA cord that connects from the PC to the LCD, try putting VGA cord properly to the LCD and PC, or change the VGA cord. saving mode indicates no signal from the PC. So either the PC is not booting up or VGA cord faulty.
Nov 09, 2008 | Princeton Digital VL1918 Monitor
IBM E74 17" CRT Monitor Logo
27 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
