Question about Swarovski Optik (58060S) Binocular
Left eye blurry wont focus - Swarovski Optik (58060S) Binocular
VIEW SCREEN IS SO BLURRY I CAN'T TELL WHAT ITS SHOWING.
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry?
If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup.
If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair.
If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
Feb 26, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
When I look through the eye hole of the Canon Rebel t1i, the view and numbers of the eye hole are blurry even though everything is auto focused, and when I take the picture, it's clear. Why is the eye hole...
There's a diopter adjustment knob just to the right of the viewfinder. Turn it while looking through the viewfinder at a blank wall until the numbers in the viewfinder appear sharp. This knob allows the camera to adjust for individual eyesight.
Dec 23, 2010 | Canon PowerShot A70 Digital Camera
Cannot focus single focus side of monarck binoculars
First you must focus the left eye on a given object with the center focus wheel. Once the left eye is sharp while looking at the same object adjust the right eye to be as sharp as possible. The right eye diopter is only meant to adjust for the small differences between the eyes.
Thomas E. Kuenzli Eagle Optics (800) 289-1132
Dec 18, 2010 | Nikon Monarch ATB 7345 Binocular
My left eyepiece on my Zhumell 20X80 will not turn to allow me to focus it. The right one works just fine. I don't want to force the left eye piece. Is there a locking mechanism I'm not aware of? Is this...
Typically the left eye piece is not adjustable. You focus the left eye with the center adjustment and then focus the right eye with the eye piece adjuster. I hope this helps.
Dec 12, 2010 | Zhumell SuperGiant Astronomical Binocular
I bought the 10x25 camera binoculars and only one lens will focus using the center dial. Its almost like the other one needs to be focused at the eye piece itself. The pictures are not clear and are...
It is common for binoculars to have one independently focusable eyepiece.  If one eyepiece can be rotated, then that is the case.
If that is the case, focus through the one that DOES NOT rotate using the center control until you get a sharp image on that side.  Then rotate the eyepiece on the blurry side until the blurry side is sharp.  If you succeed at this, from henceforth the center control will focus both eyes adequately
Aug 11, 2010 | Sharper Image Optics
Can not focus, all images blurry, no clear images
Normally this problem is caused by incorrect setting of the dioptre. This is a "focus" ring on the eyepeice which adjusts for the strength and position of the eye. Try adjusting this for best focus at about 5-10metres prior to focusing the unit.
Jun 21, 2009 | Optics
The image is blurry and doesn't focus.
I believe the ring around the eye moves and will focus.
Apr 25, 2009 | Logitech QuickCam Communicate Deluxe...
No longer focusing
On Nov 5 2008 someone posted to look for a scroll whell to the left of the view finder when you have a blurry view....in 2010, this answer prevented my husband from sending back his SECOND new camera!!! yipppeee
Sep 30, 2008 | Canon PowerShot S3 IS Digital Camera
40 DX - blurry pics
The lens is out of focus or the shutter speed is too slow, to determine if this is a defect or failure, mount the camera on a tripod and use the self timer or remote cable (if you have the remote cable) to take exposures while autofocusing on a neutral colored object such as a beige item,
if they're still blurry then manually focus the camera and try again.
If they are still blurry and your Nikon has a diopter focus adjuster (this is typically in the rear next to the viewfinder where you focus your eye), set the diopter to neutral and manually focus again.
If they are still blurry, remove the lens and using a cloth dampened with high percentage or denatured alcohol, clean off contact rings since this is where the lens and the camera body communicate and transfer focus data.
If they are still blurry, then use the same cleaning method for the contact ring of the camera body.
If they are still blurry use a different lens and repeat the first two steps.
If they are still blurry then you may have a smudged and dirty sensor, this is the part which actually registers the image and should be cleaned by a professional.
If you are so brave to, you can use the cameras feature to lock the mirror and expose the sensor, this is typically only done to perform a dust cleaning using light blasts of clean air and using solvents on the sensor is dangerous.
If you choose to do so anyway, use a bright flashlight and look for anything that appears to be smudging, if it isn't apparent then your camera or lenses are likely in bad need of maintenance.
Aug 23, 2008 | Nikon D40x Digital Camera
Web cam blurry
There are basically 2 adjustment can be made to focus your webcam, 1st is by the webcam software, try to search from the software any feature that can focus your webcam. The 2nd is the mechanical adjustment on the webcam itself, try to rotate the focus ring (webcam's eye) and see how the picture improvement.
YBC (/\)
Jun 02, 2008 | Micro Innovations IC50C Basic Webcam
Swarovski Optik (58060S) Binocular Logo
133 people viewed this question
Top Swarovski Optik Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Swarovski Optik Optic Expert? Answer questions, earn points and help others
