Question about Samsung SCX 4521F All-In-One Laser Printer
Scanner locked - Samsung SCX 4521F All-In-One Laser Printer
  • 360 Answers
The left of the scanner glass/window, there is another narrow window where you should be able to see the scanner head. The scanner head on mine was locked at a slight angle in this window. an extremely thin kitchen knife in on the right side of the narrow window, between the edge of the window and the narrow plastic strip. able to push the locked end of the scanner head down with the knife by prying the knife up and down between the glass window and the plastic. The end of the scanner towards the back of the printer was locked on mine and it was slanted towards the left side of the printer. After a couple minutes of prying and pushing down on this end, it popped free!
Posted on Sep 08, 2010
Hi I have just purchased a Samsung CLX- 3185 Colour printer, scanner and copier and the screen states ' Scanner Locked'
The scanner may have a locking lever that locks the scanner head so you can transport it without damaging the scanner head.
Locate the locking lever and unlock the scanner head.
Jan 23, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Scanner locked
Check your green scanner lock which is under the scanner area right in that area where your copies comes out of the machine. This is the most common cause of the "scanner locked" condition. The lock gets accidentally engaged as it is located right where you reach in to get your copies.
If the lock is not the problem then you may have a scanner drive issue.
Good Luck and Thank You for using Fixya.
May 13, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
SCX 4216F Scanner LOCK
It can also be the ribbon cable connecting the scanner to the formatter board. Check that it is connected properly.
Aug 20, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Error message says: Scanner is locked, Computer cannot communicate with scanner.
Have you checked the obvious? The scanner lock switch is located on the bottom of the scanner back right corner. --Ted
Jun 29, 2009 | Canon CanoScan 4200F Flatbed Scanner
Scanner is locked
Pls try locking and unlocking when power is off. S. Mohan
Feb 05, 2009 | Visioneer OneTouch 8600 Flatbed Scanner
Scanner locked - unlock scanner
To unlock a scanner open it where you would put cartridges in and look for a red or green colored tab hanging down. There should be a little picture of a padlock. You can switch it from lock to unlock. It's kept locked to protect the scanner during shipping.
Hope this is helpful...
Jul 14, 2008 | Lexmark X340n All-In-One Laser Printer
Bank are locked out
Simple, some Radio Shack models respond to their preset lock out override control protocol. Try holding the lock out button and the scanner should override the lock out on the banks. If that doesn't work, you may need to un-lock them one by one, which may be time consuming. Or, you could reprogram the scanner all together.
Hope this helps!
Jun 30, 2008 | Radio Shack Pro-2096 Base Scanner
Dell A940 - Unlock Scanner then press power
See
Page 51 contains
holds it open.
page iv.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
326 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
