Question about Asko 24 in. D3120 Dishwasher
Havnt used my dishwasher in 2 years on account of saving water. now when i push the start button some water flow into machine for a few minutes and then just stops. manual says to clean filters and drain pump but all clear. what is next plan of action?
  • 901 Answers
Try pouring water from a bucket through the front. maintain the level. It should not overflow.
Run a empty cycle. If there is a air block it will get cleared.
Posted on Sep 08, 2010
  • lcfresh1 Sep 08, 2010
    how much water do you want me to pour into the bottom of the dishwasher 1-gallon 2-gallons? what do you mean by maintain the level?
  • Ambari Sep 08, 2010
    Water level up to bottom rim level of the bottom chamber of the
    machine.
    If you pour more water it will over flow and your floor will become wet.
    I hope I have cleared your doubt!
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
Dishwasher makes a whinning noise during the washing cycle. I have opened to check inside, and the dishwasher is ok for a few minutes, then it starts whinning again. The dishwasher is just over a year old,...
If wash quality is OK leave it. Pump will make whining noise due to its' ball/bush bearing problem.
Some times if the water inlet flow is not free in flow also results in noise.
Clean the inlet water filter and check the flow before re- connecting to the machine.
Aug 30, 2010 | Dishwashers
Dishwasher runs about 3 hours
First check the inlet water flow into the machine. There is a strainer attached to this. If it is clogged water filling into the machine will be delayed!
Also check whether using the same wash program as you were doing earlier. There can not be any other fault aprt from this. i presume the wash quality is good.
Heance clean all the water inlet and outlet for free flow.
Jul 08, 2010 | Siemens 24 in. SE25A091 Hi-Line...
No water flow after trying to prime
Hi First off, don't leave the machine on for a long time if you don't have any water flow. If its been setting for a long time you might have a stuck check valve in the pump. The best way to prime the pump is to put in test mode. Turn the machine off and then push and hold the 2 right buttons at the same time. While holding them down turn the machine on. Release the buttons and turn the dial counter clockwise till it stops. This will keep the machine from heating. If you push the center button the pump will activate. Open the steam knob. If you don't have your old priming pump, you can use a bulb aspirator. Remove the water tank and fill the bulb with water. Insert the bulb into the hole on top of the machine where the tank was. Push and hold the center button and squeeze the bulb to force water into the hole. Sometime it takes 2 people to prime the machine easier. If the bulb squeezes easily and water flows, you did it. If not keep trying. You may have to remove the pump and blow some air through the small end (intake side).
Jun 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Dishwasher only runs for 21 minute cycle
I bought and replaced the control board in the door. $145 CAD it took 5 min saved myself $300
May 07, 2009 | Dishwashers
Doesn't run
I asked for help when the dishwasher (GE 1991) started up and then quit. Your site was useful as we found a priority list of things to check, thus saving much time and confusion. Our problem turned out to be a disconnected ground wire.
Thanks for the help. You probably saved us a couple of hundred dollars for a repairman. We intend to replace the dishwasher next year when the kitchen is renovated so the timing was important.
Nov 23, 2008 | GE 24 in. GSD4020Z Built-in Dishwasher
Bosch Dishwasher
what is the model #?... there are 2 buttons when pushed together it will drain the water out..try the button to the left next to power scrub... and economy...hold the 2 buttons for 3 sec. you will hear you drain pump running.. if you don't hear any water draining out into your sink, you might have a clog d/w drain line.
May 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Celsius deshwasher CDW12. Dial gets jammed on water inlet settings?
The Celcius dishwasher is owned by GAF. Their phone number in Australia is 1300 659 489. You could try them. Hope it works.
Mar 16, 2008 | Dishwashers
Asko 24 in. D3120 Dishwasher Logo
135 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
