I bought a new car and it came installed with a amp and two fusion 12" woofer. The problem is that the woofer is getting constant power and it chews up the baterry overnight i think so their is no acc wire connected.how do i solve this problem
  • 32,281 Answers
Wire the power connection from the amp to the fuse box that is only live when the ignition switch is switch on and or the accessory is on.
When the ignition switch is off then there won't be any power to the amp. Connect this power lead with its own in-line fuse and on the power side of the fuse box before the fuses.
Posted on Sep 08, 2010
Received a RF P2002 for Xmas want to install in my PU to power 12 in woofer I can figure out the input do I just connect the woofer to the bridged + and - or is there something I need to do to get thi
this amplifier is a 2 channel 50watts rms per channel and would not really be powerful enough to drive a subwoofer of any substance for car use, however , bridging it would give you 200watt rms into 4 OHMS but your subwoofer would have to be a single 4 OHM voice coil. Best you use this amplifier to drive a pair of speakers.
Hope this helps. let me know if I can further assist you
.......andy......
Dec 30, 2013 | Rockford Fosgate Punch P2002 Car Audio...
I want to install a self powered woofer and tap it to the rear speakers. Can you please tell me what are the colors and polarity of the rear speaker wires for 2006 Honda odyssey right hand drive
FIRST OF ALL --- THERE IS A FEW THINGS YOU NEED TO KNOW BEFORE HOOKING UP
A WOOFER LIKE THIS ---- IS THIS A STORE BOUGHT POWERED SUB WOOFER ? DOES IT HAVE IT'S OWN CROSSOVER BUILT INSIDE ?? I WOULD GUESS IT NEEDS TO BE HOOKED
UP TO A SUB WOOFER OUTPUT FOUND ON THE BACK OF THE IN DASH PLAYER ..
THE WOOFER NEEDS TO RECEIVE ONLY LOW FREQUENCY AUDIO WHICH MOST OF THE NEWER CAR STEREOS PROVIDE BY AN RCA JACK ON A SHORT WIRE COMING OUT OF THE STEREO ...
IF YOU TRY AND TAP IT TO FULL RANGE SPEAKERS THAT ALREADY ARE CONNECTED TO AN AMPLIFIED SIGNAL THE SOUND WILL BE DISTORTED .......
POWERED SUB WOOFERS NEED A LINE LEVEL INPUT WHICH IS MUCH LOWER THAN SAY
SPEAKERS ALREADY RECEIVING AN AMPLIFIED SIGNAL.
POWERED WOOFER WILL ALSO NEED TO HAVE A 12 VOLT ELECTRICAL CONNECTION AND A GROUND WIRE TO OPERATE THE AMPLIFIER BUILT INSIDE.
IF YOU HAVE NO EXPERIENCE WITH THIS TYPE OF HOOK UP I WOULD STRONGLY RECOMMEND SOMEONE WHO DOES [ CAR AUDIO SHOP ]
Jun 29, 2011 | Car Audio & Video
I have an sony xplod 4 channel 600 watt amp
First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
May 06, 2010 | Rockford Fosgate P112-200 Car Subwoofer
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
Power not running constantly through amplifier
You might check your ground cable for poor connection. If it is attached to the painted chassis of the automobile, the paint needs to be scraped off a little. Or go to a local audio shop or Walmart and buy a cheap capacitor. It is supposed to hold power in itself providing the amp constant power for just this reason.
Dec 07, 2009 | Infinity Reference 7541a Car Audio...
Amps on woofers are fine just won't hit
your probably making your amp run to low ohms if its a 2 channel amp bridged to one channel you can probably only run it at four ohms
Also seeing as your subs are 2ohm dvc you can't wire them individually to 2ohm and use each channel separately. So i'd recommend buying a 2ohm stable monoblock or running it at four ohms. a 1400 watt amp'll still pound at 4ohms and it'll extend your amp's life span
Aug 29, 2009 | Pioneer GM-7200M Car Audio Amplifier
Amp light is on but no power to my subs!
Hi There.
When you say the 40 Amp fuse blew. Was it your mains battery fuse or was it the fuse on the amplifier? If it was the fuse on the amplifier then you may have hurt the amplifier. The Kenwood KAC-8101D is a 1000 Watt monoblock amplifier. Therefore if you say that 1 of your woofers is not playing, then it is almost certainly blown if you are sure it is connected correctly. Try disconnecting it and only running the woofer that tries to play. If this woofer is still working correctly, you will notice a drastic drop if the sound of your bass. The reason for this is because you have changed the impedance load on your amplifier due to the fact that the other woofer is not working. Have your working woofer checked and replace the faulty woofer then you should be banging again.
Hope this helps!!
Jan 30, 2008 | Kenwood KAC-8101D Car Audio Amplifier
22 people viewed this question
 Grubhead
Grubhead
