Question about Refrigerators
I need wiring diagram of samsung refrigerator no frost model no.sr-348
My samsung fridge is not working rl41wgtb but the freezer is working any advice please
Posted on Apr 06, 2011
I need no frost refrigerator wiring diagram
Posted on Sep 23, 2011
For Samsung Refrigerator SR-L629EV my freezer
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
Model SR-L39. "no frost" dec
The defrosted water that drains to the drain tank has leaked when the fridge is defrosting,it can be due to some puncture in the drain hose from the freezer ,specially when the temperature is high this can be more . You can set the thermostat a little lower to reduce the frosting , also keep a flat tray under the drain tank so that the excess water can be collected and disposed.
If you can check and see if the drain pipe is damaged.
Jul 02, 2011 | Samsung Refrigerators
My Westiinghouse Silhouette Series 2 Frost Free 303 Freezer (Model No. FJ303F) appears to have blown a fan. My electrician is wanting a wiring a wiring diagram to facilitate repair.
what you need to do is get rid of the electrician, and get a refrigeration service man and he wont need the wiring diagram.
Feb 22, 2011 | Freezers
My frig, which is only about 3 years old, makes a "whistling" sound sporatically. I'm guessing it needs cleaning somewhere, but don't know what to check. Can you help? OOps, it's NOT a Samsung.
That whisteling sound is what we call "Ghosting". To get rid of this sound one needs to put more gas into the system, but more gas will create the suction pipe to frost up and reducing the gas level will create less cooling. Basically. leave it and live with it. Whirlpool used to be a prominent fridge for this sound. No harm is created only the sound appears while running.
Aug 25, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Excess frost and condensation
Could be that it is not getting a good seal when the door is shut. Check for obstructions causing that and check the door seal to see if it needs to be replaced.
Mar 13, 2017 | Sanyo SR-9510W Refrigerator
Need wiring diagram or schematic for GE refrigerator
if you look on the back there should be one stuck to the inside of the case near the compressor. if not go here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=TFX20JRSM
Aug 14, 2009 | Refrigerators
Refrigerators Logo
1,707 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
