Good afternoon I have a Philips Dual Deck C D R 778 CD burner it will not accept any CD+R to record to except philips. Now I have a problem in that I don't seem to be able to find philips CD's any where in Auckland New Zealand. Could you tell me please 1/ where I can buy CD's in Auckland or 2/ is there a electronic modification that can be done to this machine so that it will reconize other CD's
SOURCE: PHILIPS GOGEAR 6GB
The same thing happened to me. I contacted Philips and they sent me this solution, which worked for me. Question My GoGear has no power/no display even connected to the power supply with the AC adapter. What should I do? Answer Do a soft reset by pressing and holding the Power On/OFF button and the volume + key for a couple of seconds. Then connect your GoGear to a power outlet with the AC Adapter to charge the player again for around 30 minutes. Try turning the unit back on and see if the display appears. If the display is able to come on again, keep the player connected for another 3-4 hours until it is fully charged before use, else contact our Customer Care Center for assistance.
Posted on Sep 14, 2006
SOURCE: philips cdr 760 cd recorder: OPC FAILED
I have a Phillips 775 CD Recorder, and can only get it to record using Maxell CD-R Music Pro brand blank discs. They usually come in packs of 10 and are in full-size jewel cases. Haven't bought any in awhile and am not sure about availability.Hope this helps.
Posted on Sep 05, 2008
SOURCE: philips audio recording jukebox when
how can i upload music my pc find drive but dont know how load my music file into my philips jukbox
thanks
Posted on Nov 16, 2008
  • 68 Answers
SOURCE: File system error comes on every time i power on my philips mp3
try to get the latest software updates for your product from the philips website or format the pen drive to another file system
Posted on Feb 05, 2009
SOURCE: Free code for Philips DVP 5980K
1. Press Setup in the remote control
2. Go to Preferences and press OK in the remote control
3. Press the next sequence of numbers "1-3-8-9-3-1" in the remote control
4. Use up and down arrows to change the region
PS: if the sequence doesn't works, do it a little more quickly
Posted on Feb 28, 2009
Philips cdr778 play side door
remove cover and disassemble the tray carefully, and see if it can be put back together/ reset in the tracks. Hope fully nothing is broke and your back and runnin.
Nov 13, 2007 | Philips CDR778 2-Disc CD Recorder
Recording
The No OPC message means that the unit can't record. The laser power calibration for the burner failed the internal test with that disc. Was the disc a blank disc? Make sure that you use a clean CD-R or unfinalized CD-RW. Try a different lot or brand of CD-Rs or CD-RWs. If the problem persists, then the laser on the recorder is damaged. If the unit is under warranty, contact Philips. However, based on the date given on the manual, this may not be worth finding a shop to fix the unit. DVD/CD burners for computers are fairly cheap but I'm not sure of the specs for a replacement CD burner for inside this unit.
The manual is available from Philips here: www.p4c.philips.com/files/c/cdr765bk/cdr765bk_dfu_eng.pdf . The trouble-shooting information is on page 21 (page 23 of the PDF).
I hope this helps.
Jul 11, 2013 | Philips CDR765 2-Disc CD Recorder
I need a user manual for a Philips Dual deck Cd Recorder CDR775, Model No:775/00 Production No:VN10220230826. I bought one without the cable. I need to know also what cables I need to record live sermons
Dig down in this slow-to-load directory for the manual.
http://www.p4c.philips.com/files/c/
What 'cable' allows live recoding? You need a mike, a mike preamp and from there probably any standard audio patch cords might work. It would depend on the other equipment.
Sep 06, 2011 | Philips CDR775 2-Disc CD Recorder
My philips 778 will not fast record and the jog knob is missing. would the jog control have any thing to do with the record speed?
I doubt it. But what else is broken on this thing?
What message(s) do you get when it "will not fast record"?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Philips-CDR778-CD-Players-manual/id/455ag917/t/2/
Page 19 discusses High Speed recording
Mar 02, 2011 | Philips CDR778 2-Disc CD Recorder
I have a Philips CDR 778 audio cd recorder. I try
you prbly need to replace the burning laser which i would imagine is still avail however the cost of the laser may not b a prblm but fitting it could b
Apr 17, 2010 | Philips CDR778 2-Disc CD Recorder
My philips cd recorder is not recording
the recorder philips cdr-778 put my 80 min sony cd-r audio in it start recording 20 second on track 1 go to track 2 for 20 second then stops goes to update some times it reads no disc when installing the disc we have been recording at the Church for the past 2 years
from clyde
Mar 02, 2009 | Philips CDR778 2-Disc CD Recorder
I nead a new manual for a phillips cdr 775 dual recorder
http://www.usersmanualguide.com/philips/home_audio-video__cd_recorders/cdr775_00
Choose your specific model and language. Downloads in pdf format.
Good Luck,
BB
Jan 05, 2009 | Philips CDR775 2-Disc CD Recorder
Disc won't initialize or record, keeps saying no disc or opc erro
I suggest you try cleaning the lens...
If the wrong disc was inserted, say a music disc, there would surely be a message to that effect. If no such message is displayed I would guess the unit is faulty.
Apr 13, 2017 | Philips CDR778 2-Disc CD Recorder
 Grubhead
Grubhead
