Question about Electrolux Dishwashers
What does CL on the display mean on a Dishlex Global 500 Dishwasher ?
SOURCE: Dishlex Global 500 dishwasher
theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
Posted on Sep 12, 2008
Benimur
  • 6966 Answers
SOURCE: i have a dishlex global 450 and it shows ND. what does this mean?
Hi and welcome to FixYa,
Offhand, error message "ND" refers to "No Drain" and therefore would require that the drain system be checked, cleaned and inspected for any faulty components. Normally, there would be a drain filter, a sump or sorts, a valve, an impeller and a pump that leads to the drain hose. Access to these components would be through removal of the bottom/kick panel. Further the presence of water at the bottom of the dishwasher indicates that the water is not being flushed/drained out but is leaking from any of the above.
Unfortunately, this is a very messy job.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 15, 2008
  • 69 Answers
SOURCE: I have a dishlex Global
nf= not filling. check inlet vale, or fault will be with pressure switch. If you have poor water pressure, you may need to increase the fill time- insructions can be downloaded from:www.electrolux.com.au, click on "customer service", then "download manuals", then Dishwashers-semi integrated, electronic, then download Dishlex Global Part 1 and Part 2.
Information on setting fill time can be found at the back of Part 2, but Part 1 has a list of the fault codes
Posted on Aug 08, 2009
  • 6 Answers
SOURCE: dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Posted on Apr 18, 2010
  • 159 Answers
SOURCE: dishlex global 500 dishwasher says
Hi there.this is (over fill error).It has over filled & flooded water down into the base.It has tripped a flood switch in the base wich turns the drain pump on even though the washer is off.You can simply try tipping the washer to get the water out or you will need to disassemble the front kick panel at the bottom front to mop out the water.The switch will reset after you do this.Or wait a couple of days and the water will evaporate enough that the pumping will have stopped & the washer should work again.The booklet for your washer has water hight level settings in it.Sometimes someone leans against the washer and presses the buttons wich changes the water level to high & thats why this has probably happened in the first place.It may need setting to a lower level.
Posted on Jun 04, 2010
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Dishlex 500 global. How do you take bottom drain
If you remove the entire dishwasher you will have assess to the hose that runs up to the sink drain and to the bottom of the dishwasher. I don't know if it comes apart but if you fully remove it you will get a better look.
Sep 10, 2014 | Dishwashers
Dishlex global 500 dishwasher - light inside on but no lights on control panel
Hello misi340 - Try reprogramming the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it was unsuccessful, then the unit could possibly be experiencing a communication error with the control board or wiring failure which only a professional can help with.
Feb 14, 2013 | Electrolux 18 in. ESL4114 Slim-Line...
What does the Code CL mean on a Dishlex dishwasher
from what i can find out cl means child lock
Sep 25, 2011 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
Feb 07, 2010 | Electrolux Dishwashers
Dishlex global 500 rinse and wash problem
This was due to a faulty pump motor which I have now replaced.
Jan 10, 2009 | Dishwashers
Aug 24, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex Global 500 dishwasher was relocated to a new house upon first run the display showed ND for no drain, the filters are all clean and can manually siphen water out through drain hose so i know there...
when running the drain hose it must be hung from the highest point under your benchtop before draining to the sink waste. ND is sometimes displayed when the hose is not mounted high enough
Jun 06, 2008 | Dishwashers
My dishlex global 450 dishwasher was making a humming noise all night and dispayed OF before I disconnected the power to it. Thanks Karen kar14839@bigpond.net.au
The of means the grease trap is over full or over flowing and needs to be serviced. This is best done by a qualified serviceman.
Apr 06, 2008 | Dishwashers
Dishwashers Logo
74 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
