Question about Motorola Mobility RAZR V3
Keyboard will work to dial a call, but then will not work to enter a voice mail PIN, enter an answer machine code, or any other function after dialing the call.
  • rondo7 Sep 09, 2010
    Tried Master Reset and the DTMF setting. The phone still has the same problem. The keypad works fine to dial a call, but will not work to enter voice mail PIN, answer machine code, etc.
  • rondo7 Sep 10, 2010
    Thanks for your help. I will try that.
  • 944 Answers
This could be because of proximity sensor issue.The proximity sensor in your phone may be defective or the timer settings could be corrupted so reset it.Just reset the Motorola RAZR V3
to factory settings.This will solve the issue.If still the problem persist proximity sensor is defective.
Master reset:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which "000000" as a default code
6. Finally press select or ok and the phone will reset itself to the factory condition
DTMFmay be a problem sometimes:
It sounds as though your DTMF tones are turned off.
1. From the stand by screen, press the Menu key.
2. Scroll to "Settings", then press Select.
3. Scroll to "Initial Setup", then press Select.
4. Scroll to "DTMF", then press Change.
5. Choose Long, then press Select.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 09, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 10, 2010
    Then proximity sensor is defective.It will be near the place where you keep your ear.That is internally to the phone.Sweat or water would have gone in.Replace it.
How do I change our recorded message on our Panasonic KX-T7630? Its an old system and I have downloaded manual but it has no instructions. Any help would be appreciated many thanks
Hi Caroline, this kx-t760 doesn't have a answering machine function. This is why you can't find it in the user manual.
I can not take credit for this answer as it was answered in sep 2009
with
The panasonic KX-t7630 doesnt have a answering machine and runs through voice mail.. if you have voice mail set up simple dial your number for voice mail (eg. 500) press 311, then record greeting at the end of tone. hope that helps.
http://www.fixya.com/support/t2417399-record_voice_message_oanasonic_kx_t7630
and
http://www.fixya.com/support/t7388687-im_trying_change
page 16 of the manual below may be useful to you as it has the voice mail access codes listed
http://www.boileau.com.au/assets/Manuals/Panasonic-Manuals/OPERATER-GUIDE-New.pdf
Have a Happy New Year Caroline and I hope you find the answer you are looking for.
Jan 02, 2015 | Panasonic KX-T7630 Corded Phone
My Samsung phone never set viocemail pin
voice-mail is a phone number your phone dials that is managed by your carrier. if you dial voice-mail from you phone it usually doesn't require you enter a pin but if you dial your voice-mail from another phone you should have to. dial you voice-mail and follow the menu prompts if you want to change this.
Jun 24, 2014 | Cell Phones
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
I left my Vtech phone in New York, left for Europe and forgot to set the answering machine on. When I call in I get a factory recorded announcement that I'm not available, etc. I have my PIN # with me,...
Can you please specify the exact model of the phone? Because the steps in accessing it remotely varies from model to model. Anyway, you can try to follow the steps posted here and then test:
Remote operation allows you to control the functions of the Answering System when you
are away from the Base,and call from an outside telephone line. The Answering
System cannot be accessed from another telephone on the same line. You can access
many of the Answering System functons from a remote location, such as listening to
messages, changing recorded announcements, and recording memos.
Remote operation can only be accessed from a touch tone telephone. If the remote phone
is set to pulse dialing, switch it tone. If tone dialing is not available, you will not be able
to access the Answering System.
Note: All function codes should be entered within 2 seconds in order to activate Remote
Operation.
To Activate Remote Operation From a Different Telephone Line
1. If the Answering System is OFF, you can dial your telephone number and wait for
the Answering System to answer your call after 10 rings. An announcement, "Please
enter your security code" is given, and you enter your security code to use remote
operation.
2. If the Answering System is ON, it will answer your call and begin playing the currently
selected announcement (as with any incoming call).
3. Enter # followed by your 2 digit security code during the announcement. The
default security code is 19.
4. Once the security code is received, a double confirmation beep will be given, and
you are in Remote Operation mode. You can then control the Answering Machine
functions using the telephone keypad.
5. The user can also enter the Remote Operation mode during message recording. The
procedure is the same as step 3. The recording will be stopped after entering the
valid security code "s#xx " and the incomplete message will be deleted. If " 0s"
is entered, the Answering System will release the line, but the recorded message
will still be retained.
6. If the user enters a wrong security code, the system will release the line.
Playing Messages Remotely
1. Press " #1 ", " #2 " or " #3 " on the touch tone keypad to play the messages in the
corresponding mailbox.
2. The system will announce "Mailbox X. You have XX new messages and XX old
messages" and the system will playback the new message only. If there are no new
messages, the system will announce "Mailbox X. You have XX old messages. On
the other hand, in the absence of old messages, the system will announce only the
number of new messages.
Repeat Messages During Playback
1. Press "#4" once during message playback to repeat the current message.
2. Press "#4" twice within 2 seconds to skip to the previous message.
Skip Messages During Playback
1. Press "#6" once to skip forward to the next message.
Stop Message Playback
1. Pressing "#5" during message playback will stop playback.
Deleting Messages
1. Press "#9" once during message playback to delete the current message.
Note: Playback will pause if "#" or " " is entered. Answering System will wait for the
command in the following 2 seconds. If no further tone is entered, playback will be resumed.
Memo Recording
1. Press " 8".
2. After selecting the mailbox by entering command "1", "2", "3", You will hear, "Now
recording", followed by a beep.
3. Enter "#5" to stop recording when you have finished.
Change OGM Remotely
1. Enter " 7" to record a new OGM. You will hear, "Now recording", followed by a
beep to signal start of recording.
2. Press "#5" to stop recording. Your new OGM will playback automatically.
Check OGM1 Remotely
Enter "#7" to review OGM. You will hear playback of OGM followed by a beep.
Turning Answering System ON or OFF
Pressing "#0" toggles the Answering System ON/OFF. "Answer machine on", or "Answer
machine off" will be announced, followed by a beep.
Voice Menu for Remote Operation
The system provides two pre-recorded voice menus to help you during remote operation.
Press " 5", and you will hear the simple voice menu.
The simple voice menu is as follows:
• Press "#1" to play mailbox 1.
• Press "#2" to play mailbox 2.
• Press "#3" to play mailbox 3.
• Press "#5" to stop.
• Press "#4" to repeat the message.
• Press "#6" to skip the message.
• Press "#9" to erase the message.
• Press " 5" for other functions.
(To advance voice menu)
The advanced voice menu is as follows:
• Press "#7" to review outgoing message.
• Press " 7" to record outgoing message.
• Press " 8" to record memo.
• Press "#4" twice to repeat previous message.
• Press "#0" to turn the system on or off.
• Press " 5" to return to the simple voice menu.
Pressing any function code will stop the voice menu, and perform the corresponding
functions.
Exiting Remote Operation
1. Enter " 0" on the touch tone keypad to exit remote operation mode. The Answering
System confirms your action with a long beep and then disconnects.
2. The Answering System also automatically disconnects if no key is pressed within 20
seconds during remote operation.
Oct 17, 2009 | Vtech Two Line Digital Answering Machine...
Line rings does not fo to voice mail
The call forwarding was canceled; try this
1. pick up handset or press speaker
2. dial the code for call fwd busy/ no answer (default code is 744)
or press the forward function key
3. dial 1
4. dial the extension (lead number of your voice mail)
5. press speaker or hang up
May 20, 2009 | NEC Lands Phones
Only one phone will dial a number...
Most multi-handset systems require 'registration' of the rest of the handsets otherwise the system doesn't know how many stations are in use for intercom and conference purposes.  Check your instructions for how to do this on your system.
Checking 'voice mail' can differ from one system to another; this can be a function of your local telephone service and would require 'caller ID' service being active, in other systems, this just gives you remote access to your answering machine (ours does that).
If the software is logical, choosing the 'Menu' should give you the chance to listen to messages from any handset once they are registered on the system.
May 18, 2009 | Panasonic KX-TG2357 Cordless Phone
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
Checking voice mail remotely
for this model of phone, you perform the following:
1- Call the phone, wait for the machine to answer
----if the machine is on, it should answer within about 4 rings and begin playing your answering machine message
----if the machine is off, it will still answer after about 10 rings with a series of beeps
2- During the message (or beeps if it is off) press 0 and then enter your 2 digit PIN code. This should get you remote access to the phone. from there you can follow the menu structure that the phone tells you. If you never entered a PIN code, that's not a problem. the default code for this model of phone is 80.
you have about 15 seconds to enter a command, all commnds are two digit (01 through 10) and the digits must be entered within 2 seconds of eachother for the command to hold.
follow those directions and you'll be checking your messages in no time flat.
Jun 09, 2008 | Southwestern Bell (S60802)
RCA Model 25204 2 line speakerphone corded with call waiting caller ID
As bsmither said, how voice mail is accessed is very dependent on your phone company and how they've set things up. They would be the best place to ask about any problems you're having there.
As for programming the voice mail buttons on the 25204, I was confused by that one as well until I finally figured it out. Specializations aside, they're just speed dial buttons, and are programmed in exactly the same way as the ones along the right side of the phone. RCA could have documented that detail better than they did.
In my case, with Vonage, I just programmed the buttons with the numbers for the lines that they're associated with. When they dial and I'm connected to the voice mail system, I'm prompted for my VM password, which I then enter manually.
Jan 30, 2008 | RCA 25414RE3 Corded Phone
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
location (when you are away from home, or from another room using a handset).
Additionally, you can turn On or Off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any
1) Call your telephone number and wait for the system to answer. If the answering system is
off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
3) The answering system announces the current time and the number of messages stored in
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered within 2
seconds. You may select a command from the following chart:
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
corresponding command, it starts the Recording function. If you want to stop the
recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the system
is in the command waiting mode. You may enter another command at this time from the
chart above.
6) When you are finished, hang up to exit the system. The answering system automatically
returns to standby.
Dec 29, 2007 | Uniden DCT648-3 Cordless Phone
Motorola Mobility RAZR V3 Logo
74 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
