Question about Fiesta Blue Ember Gas Grill
Can I convert a Propane grill to a run on household natural gas?
  • 377 Answers
Yes. The most important thing to do is to get the right size orifice so that the correct amount of gas is allowed to enter the burners. This is a small brass unit that has a hole in the middle. There is one size for propane and one size for natural gas.
Posted on Sep 12, 2010
Converting a natural gas Webber genesis bbq to propane. Can you buy a kit to convert?
Hello, Kevin -
Do you mean a Weber (not Webber) Genisis grill? If so . . . see the information from the Weber grill company regarding the conversion of a natural gas grill to propane here:
https://consumer-care.weber.com/hc/en-us/articles/360001730474-How-can-I-convert-my-grill-from-liquid-propane-LP-to-natural-gas-NG-or-vice-versa-
Bottom line:
The Weber company does not recommend it and does not provide a conversion kit.
Best wishes.
Apr 30, 2018 | Grilling
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Converting a propane grill to a natura;l gas grill
You will need a larger gas manifold (you need more natural gas to do the same work as propane) and a new regulator. Your local grilling store should have both for around $50. But running the gas line can be big bucks and your grill is not going to be as hot - I wouldn't do it.
Jun 24, 2011 | Weber-Stephen Products Spirit EP320...
I have a new PinnacleTG560N natural gas BBQ and I want to convert it to propane, what can I do, or can I get a converion kit to make this work.
Unfortunately, there's nothing you can do. According to Weber, there are no conversion kits, as your grill is not convertible to propane. Like wise, a Weber propane grill is not convertible to natural gas.
Link to your Owners Manual (see page 2 - Warnings):
http://help.weber.com/manuals/pdf_files_2011/Gas/Spirit%20ES%20Series%202007newer/OwnersGuides/Spirit_210310_NG_OwnersGuide_89961_022811.pdf
Apr 28, 2011 | Weber Spirit? E-310 Propane Grill
I have a Turbo Elite 3 burner barbecue. Want to convert it from propane to natural gas. Where can I get a conversion kit?
Your best bet is BBQ's Galore. Since it's their grill, if there is a conversion kit for that model, they'll have it. However, not all gas grills are convertible from one gas type to another.
Apr 01, 2011 | Grilling
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
I have owned the Fire Magic A660 for a year and a half. The main burners have never worked right. Sometimes they light 25% and other times up to 90% but never even. I've adjusted the air, I've cleaned...
If your using a 20lb grill tank, that may be where the problem lies. All 20lb LP refillable tanks are now equipped with an OPD Valve. It's a safety feature prevents over filling of the tank. However, it can cause problems for gas grills if not turned on properly.
If this is what you're using here's what you need to do:
  • Turn off the tank and disconnect the grill hose from it.
  • Wait 5 minutes and reconnect the hose to the tank.
  • Very, very slowly turn the tank valve on. When I say slowly, I mean VERY slowly.
  • Once the valve is fully open, light each burner one at a time and turn them all up to the highest setting.
Are all the burners, burning properly? If so, you just solved the problem. Remember to always turn the tank valve very, very slowly when turning it on.
If you're not using a propane grill tank and your supply is hard piped from your household supply of propane gas. You may very well have a pressure and gas volume problem, depending on the length & size of the run gas piping. This will have to be determined by your propane provider. But, I can tell you this, if the gas piping is not at least 1/2" OD, that's were your problem lies.
If you're using Natural Gas from your household supply. Was the grill properly converted to operate on Natural gas? If it wasn't, that definitely is the problem.
Hope this helps you solve your problem. "Happy Grilling."
Feb 11, 2011 | Fire Magic Aurora A660i1E1P Stainless...
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
Fiesta Blue Ember Gas Grill Logo
224 people viewed this question
Top Fiesta Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Lawrence Oravetz
Are you a Fiesta Grilling Expert? Answer questions, earn points and help others
