Question about Sony Audio Players & Recorders
MY SONY CD/RADIO/TAPE PLAYER ONLY PLAYS ONE CD AT A TIME NOW. IT USED TO PLAY 5 SUCCESSIVELY. CAN IT BE FIXED?
  • jamary1 Sep 08, 2010
    THE sn IS 8180488 AND THE MODEL # IS HCD HPZ9
  • 3,083 Answers
I'm sure it can be fixed, but repair can be costly. It could be something as simple as a loose ribbon connector or oxidation on a connector, or a faulty relay or ic.
Check with a car audio repair shop and get an estimate, and then you will know whether to fix or let it go.
Wish I had a simple fix for you, but hope this helps.
Posted on Sep 08, 2010
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
May 04, 2014 | 2002 Acura 3.2TL
My sony cfs-w360boombox plays tape at high speed upon play, normal or high speed poition
there may be 2 possibles
1, the pinch roller is not going down and staying in the fixed when during playback, easy way to check power down the unit, press play and see if it looks firm, it will push back, if working right
if its loose, it may well have come off a little sping, and may well be an easy ish fix, by someone who know about cassette decks,
2, the speed adjustment has failed, there will be an internal speed control, which keeps the playback at a correct speed, if this has failed it may be fixable, but only by someone who can take it to bits and remove and solder a new one in, and they are very small and Sony items i have had have failed on speed control! too for me its a junker box
good luck
Sep 24, 2013 | Sony Boom Box With CD Player & Cassette...
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
Dec 26, 2012 | Sony CDP-CE375 5-Disc CD Changer
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
Jul 27, 2011 | 2003 Chevrolet Tracker
The tape plays songs so fast sounds like donald duck. The speed the tape is feeding is to fast.
Hi, the casette deck has a mechanical system (servo-driver) most of the problems that happen when in your case, plays song so fast is that you look at the pinch roller. The pinch roller is a rubberized free spinning wheel typically used to press magnetic tape against a capstan shaft in order to create friction necessary to drive the tape along the magnetic heads with a normal tape speed if the pinch roller brakes, get lost from his place or got dirty then you get this fast sounds play, check the pinch roller if still good in his place or clean his rubber with alcohol, then the problem should be fixed.
Jan 29, 2011 | Sony CD Radio Cassette Boombox, CFD-E90...
Pioneer multi cassette changer CT M6R
I have had this same problem too. I fixed it by taking the tape transport out of it and removing both capstans with their flywheels and oiling the capstans. However this only fixed the problem for a few months. Maybe you need to more a most soild oil since i used just regular motor oil.
Oct 17, 2008 | Pioneer DEH-1600 CD Player
Cd player comes up with err message
Oh, i had this problem several times... look, the best answer that i can give you is to buy a new one, there's sony's cd-players that are great, me and my father have. now, if you want to stay with this cd player just insert the cd several times until it will play. but again, you better buy a different one.
Jun 16, 2008 | 2000 Renault 181
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
22 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
