After i format my computer, i can not connect to the internet??help me..
  • 32,281 Answers
To protect your wireless network from unauthorized access and to connect your computer to your wireless router, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Sep 08, 2010
I formatted my dell laptop but there's no internet connection even after i plug in my internet cable?
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Jan 16, 2013 | Computers & Internet
The connection has timed out The server at www.facebook.com is taking too long to respond. The...
You are using internet connection with bad speed in that case you have three option :
1.checkout your internet connection and talk to you internet guy and also change your internet and wifi password so that no one can theft your internet data and get 3g or 4g speed connection.
2. get you computer or laptop format in case of malware or virus problem.
3.download facebook lite for lower data consumption. Connection has timed out Firefox Solved Closed
centain link for help.
May 22, 2017 | Facebook Social Network
How can i format my phone memory
You can't format phone memory You can forma(flash) the entire phone(actually formatting means deleting the entire system file it's also called as flashing).
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE**
**Please don't disconnect while updation process
Thank you
Don't forget to rate
Jan 17, 2011 | Nokia E52 Smartphone
I am not able to access the internet .......?
Hi there, have you chanced internet provider ??
Some times you need a user name and code to internet connections, you can get this at your internet provider.
Do you use wireless connection ??
You can normally go to : Start - Control Panel - internet connections and on the icon there highlight it and ricght click on your mouse and from the menu choose: disconnect the connection and after reconnect the connection, that should solve the problem.
If not then you can try to use the menu repair on the same icon
Hope that solve the problem
IF NOT then return here
Have a nice time over there
Please rate my answer
Oct 07, 2009 | Computers & Internet
PHYSICAL IP ADDRESS NOT RECOGNIZED, IT JUST SAYS FF-FF-FF-FF, AND DOESN´T RECOGNIZED THE IP ADDFRESS FOR THE INTERNET CONNECTION?? PLEASE HELP, DO I HAVE TO FORMAT MY COMPUTER OR I JUST NEED A DRIVER?
Update the O/S first
Check the connection is DHCP
control panel,network connections, right click your connection to the internet, properties,
TCP/IP VER4, highlight this in grey, click properties,
should be set to
( obtain I.P. automatically ) tick this box.save it.
Reboot the system.
hope this helps
Regards
Apr 19, 2009 | Toshiba Tecra M2V-S310 Notebook
Wireless internet connection problems
What you can do is go into your wireless network and manually connect to a wireless network. If that doesn't solve the issue then let me know and I can help you more.
Apr 09, 2009 | HP Hewlett Packard Compaq dx2400...
Kare??? Senji_90!!! E....
sir you will have to tell me what kind of internet connection did you use
was it a dial up or broadband and do have a cd provided or you used to dial the connection
also the operating system,,,,,
pls do provide the detail
i am sure we can help.
Mar 15, 2009 | Computers & Internet
Can i use my blackberry pearl to connect my pocket pc to the net?
Yes on both issues which seem different to me.
1) To connect your blackberry to your IPAQ for Internet requires finding a means to connection share between them. That means having a computer as an intermediary since IPAQ only uses Activesync. Connect the blackberry to the computer and setup the blackberry as a modem. Then setup activesync to share Internet to the IPAQ.
2) Your blackberry will not play video if it is in certain formats, you need to convert it. Streaming sites like youtube do work, but only if you have sufficient bandwitdth. Blackberry's prefer 3GP format.
Dec 08, 2008 | RIM BlackBerry Pearl 8100
Sony USB Flash Drive does not work.
plz helps me my usb no saves data not delete
Dec 02, 2008 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
