Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i get the side back on my poulan wildthing theres a ring on the cover does whats the trick on getting it back on does it go around the sprocket housing or inside it
    Brigadier General:
  • 4,088 Answers
That is the brake ring and should fit over the clutch outer drum. If the brake was set when you pulled the cover off, it will be necessary to release the brake mechanism to get it to pass over the drum. Good luck!
Posted on Sep 09, 2010
I have a poulan pro 650:series it's a briggs and straton motor. My oil dipstick tube is loose and allowing oil to leak out . How do I tighten this. Also it has oil dripping from what looks like the air...
You will have to remove to top plastic cover on top. Then if your fuel tank is wrapped around it backside and has a ring make on it. There will be three 5/16 bolts(remove) and back left side facing the front of mower bottom there's a 3/8 bolt loosen tilt ring up and tank back you should beable to reach the 5/16 bolt then repeat in reverse order when putting it back together
Mar 26, 2015 | Poulan Garden
HOW DO YOUREMOVE THE SPROCKET
The P4018 has an out board sprocket, so to remove you need to remove the side cover nuts and take away the cover, the bar and the chain, there is then an e clip on the end of the crank, insert a suitable screw driver into the inner edge of this clip and gently pry off, take away the large backing washer, the sprocket will now just pull off the crank.
Jan 13, 2013 | Poulan P4018wm Wildthing Chainsaw Wild...
Poulan 18" wildthing chainsaw wont start
have you tried spraying Starter fluid into the Carb to see if it will at least try to run and verify you have good spark?
Dec 05, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need a routing map of the fuel lines for the wildthing 2375
There is no diagram that shows this, however i can tell you where they go, the fuel hose from the tank with the fuel filter on goes to the fuel inlet on the carb, the nozzel nearest to the pump side of the carb ( cover held with one screw ) the pipe from the carb nearest to the metering side ( cover held with four screws ) goes to the suction side of the primer ( short nozzel on primer ) there is then a pipe from the pressure side of the primer ( longest nozzel on the primer ) back to the tank ( just pushed into the top of the tank ), just remenber the primer pulls fuel from the carb, and dumps it back into the tank.
Mar 02, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Plastic housing broken due to over tightining
I call it a clutch cover, Poulan calls it a "Chain Brake Assembly", pn 545139903 for Type 1 or 2 - 2375 WildThing.
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 17, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Nov 08, 2008 | Poulan Garden
Poulan Wildthing 18
Hi tchild, my name is Dennis and I will try to assist you with your problem.
You can get the part from Poulan parts and it will take about 15 minutes to fix the first time eight minutes the second time. In addition I might add that to remove the centrifugal clutch and the sprocket, it unscrews from the crankshaft with a left hand thread. A little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance. Please rate the solution because I can learn from your rating. Thank you
Nov 08, 2008 | Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
121 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
