Question about Casio FX-115ES Scientific Calculator
When I enter 2 shift ( % = My answers comes out in a fraction mode 1/50 yet on the manual the answer comes out as 0.02 How do I get my answers not to come in a fraction matter?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Press SHIFT MODE 2 to select LineIO mode.
Posted on Sep 08, 2010
Anytime I enter a problem I always get a fraction as the answer..
To convert a single result from symbolic (fractional) form to decimal, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Apr 05, 2011 | Casio FX-115ES Scientific Calculator
Dividing fractions are not calculating correctly, I have to manually get the answer I need
Press the S--D key located above the DEL key to convert between symbolic and decimal forms. To have all answers come out in decimal form, press SHIFT MODE 2 to switch to LineIO mode.
Dec 13, 2010 | Casio FX-115ES Scientific Calculator
How do i convert fraction answers to decimals?
If result displayed is to be converted, press the S-D key. This will toggle display from decimal to fraction and from fraction to decimal.
To force a result to be in decimal format press SHIFT = instead of just =.
To configure calculator to display only decimals, press the SHIFT MODE key sequence to enter SETUP and seledct 2:LineIO.
Oct 14, 2010 | Casio fx-300ES Calculator
So i keep trying to divide...and my answers are all coming out as fractions and i tried what was listed below, but that only makes the answers come in scientific notation, so how do i make the answers...
Press SHIFT MODE 8 2 to select the Norm2 display mode, which will display in fixed decimal notation unless the magnitude of the number is larger than 10^10 or less than 10^-9
For more information about the display modes, please refer to your manual.
Sep 22, 2010 | Casio FX-115ES Scientific Calculator
Why does the answers goes to fractions
In MathIO mode the calculator tries to display answers as fractions whenever possible. You can convert a single result to decimal by pressing the SD key just above DEL. To have all results come out in decimal format, press SHIFT MODE 2 to select LineIO mode.
Sep 12, 2010 | Casio FX-115ES Scientific Calculator
How do i change my calculator from fraction answers to decimal when i'm dividing
If the fraction has just be typed in, press [SHIFT][=] instead of just [=] to get the result displayed as a fraction. However the fraction displayed will be the irreducible form of your fraction (equivalent but reduced to its simplest terms).
If you do not want fractions at all ( input and output)
Press [SHIFT][MODE] and select [2:LineIO]. This is the entry mode of the old generation of calculators.
The other IO mode is MthIO: In this mode fractions are entered as in textbooks, radicals are also entered as in a textbook. If by any chance you like this new IO format but just want the final results displayed as decimal, you can do your calculations in MthIO to get the result. Once displayed the result can be converted into decimal format by pressing the [S<>D] key.
Aug 26, 2010 | Casio FX-115ES Scientific Calculator
When I enter 55/2 - the answer appears as a fraction. I would like for it to appear as a decimal. I know I can convert the answer using the SD key, but I would like the initial answer as a decimal.
To get the result in decimal format, press [SHIFT][=] instead of just [=].
You can also configure your calculator to show only decimal results:
  1. Press [SHIFT][MODE] to access the (SETUP)
  2. Select [2:LineIO]
Aug 12, 2010 | Casio FX-115ES Scientific Calculator
I just bought this fx-115es and am entering 5x3.3= and getting an answer of 33/2, althought it is right how do i get it to answer 16.5
There are several ways you can extract decimal numbers from this fine calculator.
In MathIO Mode
1. Once a fraction or radical is displayed press [S<=>D] button to convert it to decimal. Pressing it again restores the fraction or radical display.
2. Instead of pressing the [=] key to obtain a result, press [SHIFT][=]. The result will be displayed as a decimal number.
In LineIO
If you do not care for exact calculations with radicals and fractions, just change the default mode from MathIO to LineIO. To do so
press [SHIFT]{MODE][2:LineIO]. In this input/output mode all results are decimal.
Please be informed that with this mode you will not be able to access the formula templates that allow you to enter fraction as you see them in textbooks (the natural display format). You lose other neat functionalities also.
As a suggestion, if you like the natural display for input keep it as default, and press [SHIFT][=] to display decimal results or [S<=>D] to convert display to decimal format.
Hope it helps.
Nov 16, 2009 | Casio FX-115ES Scientific Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Casio FX-115ES Scientific Calculator Logo
26 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
