Question about Sharp AR-5320 Black and White Copier
Show U2 code - Sharp AR-5320 Black and White Copier
ERROR CODE U2
Posted on Sep 21, 2010
Sharp copy ar-5631
show error u2-40
how to fixed it
thanks
Posted on Nov 13, 2011
Driver for hisense phone u2
How to download the driver for hisense u2.
please show me. Thanks
Jul 25, 2012 | Universal Hisense HS-U8 Android 2.3 WCDMA...
Hi I have problem with my photocopaier. Sharp ARM236. It shows Code: U2-40
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Aug 07, 2011 | Sharp AR-M237 Copier
Call for service U2-40, on a sharp AR275 printer
In AR 275 Sharp copier U2 40 is very common problem, U have to only reset the above error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 16 then press ok key
pl ask for any difficulty
May 17, 2009 | Sharp AR-275 Copier
U2 main code 40 subcode on A-162 Printer
u2-40 is a code that this copier will show if the toner unit is a non oem product , you can rest simulation 16 in the service modes but the error many come back
clear, interupt , 0 , interupt , 16 clear all and print
many need to do this severl times
Feb 09, 2009 | Sharp Office Equipment & Supplies
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-12 EPROM error
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Nov 11, 2008 | Sharp AR 201 Copier
U2 fault code?
The last two faults are logged into EE memory.
The other U (user) faults have been removed. The old U2 fault, which was the tub forced open during a cycle, has
been removed completely. Instead if the tub is forced open the product simply pauses as if someone had pressed
the start/pause button. The old U3 fault, which indicated a failure to drain i.e. water left in the tub, will not show up a
fault and the DishDrawer will continue through the cycle
Aug 13, 2006 | Fisher and Paykel 24 in. DD603H W Built-in...
Sharp AR-5320 Black and White Copier Logo
550 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
