Question about Refrigerators
All lights are on; I hear humming. Warm inside.
  • Refrigerators Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 12, 2010
Why does A/C blow warm air?
Have the AC system charge checked, you may be low on refrigerant from a leak.
Apr 02, 2016 | Jeep 2009 Grand Cherokee Laredo
Refrigerator has developed a low buzz or hum. Do I need to be concerned?
Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator, LFHT1817LW1, is buzzing or humming. With modern, high efficiency compressors you may hear a high pitched humming or pulsating sound. Additionally, if you have an icemaker equipped inside of your refrigerator the water valve may produce a buzzing noise as the valve opens to fill the icemaker with water. I hope this has been helpful. -Matt
Oct 15, 2014 | Frigidaire Refrigerators
Why netis router 150mb won't come on, no power
The cooling fan inside it is spinning, and making noise, but the "electronics" parts inside are dead. Replace it.
Aug 23, 2014 | Netis Systems 150Mbps Wireless-N Broadband...
The mashine is not taking water
If washer spins (has power) put on warm fill . If you hear a hum but no water then one or both fill valve connections are blocked. Clean screens and try . If no hum on either valve then the fill valve may be bad.
Nov 17, 2010 | Washing Machines
Dryer turns on, but with every cycle option, the dry and cooling lights are both illuminated, the former blinking. When I try to start the cycle, I hear a short hum, then nothing. The barrel doesn't turn,...
Possible that the motor capacitor is faulty and not lettingg the start up. Opne and get access and change the capacitor . If you are hearring then hum then when you touch the motor it should be quite warm which confirms the failure off the capaccitor or the winding of the motor.
The timerr runs accordingly not knowing if the motor rotates.
Hope this helps.
Aug 26, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Light is still on but temperature reading cannot be seen, can hear humming but food is warm/melting.
the main board in the back of fridge could be gone.this feeds power to the temp display,everything goes through the board.the board is around 200 hundred bucks
Jul 20, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Warm air
could be several things...if all is working/blowing and its clean inside & outside with a clean filter then more then likely it's low on gas/freon......if you continoue to run it it'll pobly ice up/freeze......also make sure you hear the compressor running as well as the fan blowing. sometimes this can be tough listen for that deep rumble/humming sound thats the compressor.
Jul 08, 2010 | Frigidaire FAC126P1 wall/window Air...
Maytag MAV6200 will not washer on cold water cycle. Could this be a problem with the push button switch? Washes on all other cycles. However, the warm water is very hot, not warm.
Your cold water inlet valve has more than likely fialed.or.... the inlet screen is completely clogged. First turn off the water to your unit both hot and cold water lines. Then select the wash cycle w
ith hot water only and listen for a hum from the inlet water valve. Then select cold and see if you hear a similar hum. If you do not hear a likewise hum then the cold water solenoid on the water valve has failed and will need to be replaced. (Sometimes this requires the entire water valve be replaced due to the design of the assy) If you hear a similar hum then remove the hoses from the water valve and check for a clogged inlet screen just inside the water hose attachment fitting. If you can not tell if it is clogged remove the screen and hold it up to the light. You should be able to see light through the screen. If it is clogged scrub and wash the screen under running water. It is prety easy to tell if you have it clean. Once you finish reinstall the screen in the water inlet valve, reconnect the hoses and turn on the water. Good luck.
Jan 07, 2010 | Maytag MAV6200 Top Load Washer
Washer won't fill with hot water
If you hear a humming, the coil on the water valve is probably OK. On warm, you are getting cold fill only. (hot + cold = warm) Take the hot water supply hose off the machine and look inside where the hose attached to the washer. There should be a screen inside. Remove it and clean it out. Also, check both ends of the supply hose, as sometimes you will find a screened washer in there too.
Oct 26, 2008 | GE WBSE2090A Top Load Washer
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
