Question about Cameras
I have a Samsung L100 digital camera. It would not power on & when I tried to charge it the chargered flashed orange. I bought a new battery & charged until the charger light was steady green, but it still will not power on.
  • stacey_andra Sep 08, 2010
    I'm not sure how the charger would show it was fully charged if there wasn't a good connection to the battery from the camera
    How would I clean the battery contacts?
  • Cameras Master
  • 19,396 Answers
Hi.
The charger is tested reading Volts at its terminal. Volts must be within half volts from specifications.
If the charger is OK, then the camera has an internal problem. A fried main board or a broken contact will cause the same problem. The repair must be done by a technician.
You can get a quote calling Samsung at the number on manual, or get a quote from a third party repair service here:Repair
Posted on Sep 08, 2010
  • 3,083 Answers
The bettery contacts inside the camera could be slightly oxidized. Clean them with a qtip and at least 90% isopropyl alcohol. Some rechargeable batteries have to be recycled on charge 4 or 5 times before they take a full charge, also. Check the output on your charger, to make sure it's good, but it probably is.
Here is a web blog of things you can try when a camera won't power up:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
There is another possibility that you have a stuck len, and here's a blog for that:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The blog says it's about lens errors, but it applies to "stuck" lens, also.
Good luck, hope this helps, and thanks for using FixYa.
  • Cameras Master
  • 6,487 Answers
There might be a problem with the connection between the external battery and the logic board. This is due to bad circuitry caused by water damage or particle obstruction. The only to have this problem is to have it repair from a service center for part replacement.
  • Mark Gil
    Mark Gil Sep 08, 2010
    It has something to do with the battery contacts, you can try to clean those contacts.
  • Mark Gil
    Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper.
Acquired Samsung L100 camera. Battery won't charge. Is it because of age of battery?
most likely is battery try a new battery. when battery is charged the light should stop blinking
Jun 12, 2014 | Samsung Cameras
My battery is empty but if i plug it in to charge.. it keeps blinking orange and aint charging.. When i got this camera as a present it had the same problem.. bought a new battery.. problem fixed and even...
I have this same problem. I went onto the Samsung website troubleshooting and it says that if there is an orange blinking light then the charging cable is damaged and needs to be replaced. Hope this helps!
Feb 19, 2011 | Samsung L100 Digital Camera
Camera charger flashes orange not charging the battery
I had first camera,2009 after few month my camera didn't want charged, it's always been flashing yeallow,. I gave it back to the shop i bought it from. They refund my money.
Dec 11, 2010 | Samsung NV10 Digital Camera
I bought an untested Samsung L730 digital camera without a battery, I have bought a USB charger/data cable but the orange flashing light on the charger stays on. I am using Windows XP. Is it likely that...
You CANNOT charge a camera through a USB port there just is not enough power! you need to get an original wall charger and power up from that. Even the USB cable/wall charger will NEVER charge it up sufficiently.
The USB cable is for data transfer only.
Aug 07, 2010 | Samsung Digimax L730 Digital Camera
Samsung L100 camera, battery charger shows battery is fully charged, camera powers on, lens extends then immediately retracts and camera beeps three times
it sounds like a faulty battery try testing it with another battery and see if the problem persists if not then get a new battery,
let me know how it goes,
Jul 31, 2010 | Samsung L100 Digital Camera
I bought this camera in October and took it to
It should state in your user manual how long the initial charge should be, usually about 24 hours.
Try this first, if you still have problems, go back to the vendor, ask them to demonstrate it to your satisfaction. If they can't or won't request a replacement or refund under warranty.
May 03, 2010 | Samsung L100 Digital Camera
Samsung L100 cant figure out how to charge!!! Adaptor supplied but no battery charger to plug in to mains. Do I need to purchase a battery mains charger???
you can charge the battery through the camera like a cellphone.
plug the USB cable to the ADAPTER then plug it to a wall socket then plug the USB cable connected to the AC power adapter to your camera
the USB cable should have an indicator (RED) if it is already charging and (GREEN) when its done
Jun 23, 2009 | Samsung L100 Digital Camera
When charging my camera the charger light flashes red, green, orange and then it goes off. What does this mean?
battery issue try changing the batt they are not taking the charge pls replace if they got weaken or aged
pls rate me fixya if it helped
Mar 09, 2009 | Samsung Digimax L830 Digital Camera
L830 wont charge
it is possibly the battery itself. i have a two batteries for this camera one of them has this problem orange flashing light and doesn't charge and the other works fine. You might need to get a new battery. Good luck
Oct 11, 2008 | Samsung Digimax L830 Digital Camera
Cameras Logo
132 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
