Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My usb drive is showing shortcuts inside - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
  • sharath_v Sep 08, 2010
    My usb drive is showing shortcuts inside ,but the filesfiles are still there(hide) , how can i remove shortcut virus from usb drive?
  • 34 Answers
Your usb drive should have been infected with virus or trojans before. So the files or folders are "hidden" by showing shortcuts. Follow the steps from this article about how to fix this kind of problem. It helped many people to make it right. Regards
Posted on May 18, 2011
    Sergeant:
  • 172 Answers
It means that you didnt copy the file. you just copy the shortcut icon.
try to right click the file and click send to and select your Sandisk or you can drag your file to sandisk folder
hope this help
Posted on Sep 08, 2010
How to remove autorun.inf virus
scan with letest antivirus programs then show all hidden file and folder and chak out hedden option....................
Sep 28, 2014 | Electronics - Others
Pen drive shortcut problem
Try Shortcut Virus Remover.
It will work against Shortcut Virus.
You can download Shortcut Virus Remover from this link for free,
Aug 21, 2013 | Dell Computers & Internet
ALL FOLDERS ON MY USB HAVE BEEN CHANGED TO SHORT CUTS
This is usually a signal that a virus is at work. Check that your computer has been checked and is clear. Then check your thumb drives-all of them including your external hard drives.
Apr 15, 2013 | Dane-Elec DaneElec 4GB USB Drive Red Hard...
I have S2 portable 640gb external hard drive. Do not open the main folder with info and gives me only shortcuts and no way to my folders
Do you think my problem is a cable wear or the device itself
and how can get access to my data
can anyone hepl me
please
May 05, 2012 | Samsung S2 Portable 640 GB USB 30 External...
My memory card is showing shortcuts inside.. all folder changed to shortcuts.. n i m unable to open this.. pls suggest me answer
This is one VIRUS. Please Scan that sandisk with any antivirus. just you can use Kaspersky.
The manual procedure to see all the fiels is:
1. Connect the USB drive
2. go to command prompt. Run-> cmd
3. goto sandisk drive
by default c:\> prompt appears. type the drive letter with colon.
c:\> E: (if E drive assigned to your sandisk)
you can see in mycomputer: drive letter may be e: or f:
4.After getting that drive as prompt. like e:\>
Then type these commands.
attrib -s -r -h *.* /s
attrib -s -r -h desktop.ini /s
attrib -s -r -h autorun.inf /s
del desktop.ini /s
del autorun.inf /s
rd recycled /s
rd recycler /s
rd $recycled /s
5. Then goto My computer. you will find the folders and shortcuts also
please remove the SHOTCUTS only...
This will helps you .,
Jun 17, 2011 | SanDisk 1GB microSD Memory Card
All folders on usb flash memory card changed to be shortcuts , I can't display their contents directly , there is folder called recycler contain an index for the data inside my folders ... i want...
Hello there, sadly you have been attacked by a virus named - RECYCLER. This is a very common virus, I also had an encounter with it recently. What zou are going to do in order to delete is:
1.Look for all folders with shortcut arrow.
2.Right click then properties.
3. in the field TARGET delete everything before path to your usb (before eg. F:/Kobac usb).
4.Save settings. Open folder and copy it to harddrive
5. Do this for all folders.
6. When zou finish coping your data, format your USB.
7. To Format fo to My Computer, right click on USB and format.
8. Copy files from harddrive to your USB back
9. Enjoy!
Good luck, Kobac
May 24, 2011 | Computers & Internet
4 gb usb creating shortcuts folders
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
Mar 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a iomega eGo HDD and its not showing up on my computer but it shows up under my devices how do I fix that
It depends. If this is the _very_ first time that you have connected the IOMEGA device to your computer, you'll need to "initialize" the HDD for usage by Windows (or Mac OS).
Or, if you've previously done that, and you've written files onto it, and now cannot read those files, you have an entirely-different problem, namely a "hardware" problem.
An external storage device has several major components:
* the USB cable (which in your case, seems OK, since the device is listed)
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure
* optionally, an external power-supply that connects to the enclosure.
Use a multi-meter to measure the voltage/amperage generated by that power-supply,
and compare with the specifications on the power-supply's label.
Disassemble the enclosure, and remove the disk-drive.
Connect it as a "slave" disk-drive in a desktop computer, to see if bypassing that USB-to-disk-drive adapter bypasses the problem.
If the device is still under warranty, IOMEGA will replace it, at minimal cost to you.
If the warranty has terminated, buy a new, compatible, disk-drive, and install it inside the enclosure, to "revive" your external storage device.
Nov 04, 2010 | Iomega Computers & Internet
Usb flash drive showing shortcuts inside, help me, how can i remove shortcut virus from a "microsd memory card"?
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
http://shortcutvirusremover.blogspot.com
Sep 08, 2010 | SanDisk 1GB microSD Memory Card
Memorex U3 traveldrive,USB 2.0 won't open Word '03 file in Vista,says, ''shortcut path does not exist.'' But shows it in there at 450 KB? Help. Thanks, Charles
try to copy the file on the hard drive and then open it and make sure the file u are mentioning is not a shortcut sometimes we even send a shortcut into the usb drive instead of the real file by mistake so check it
Jul 09, 2009 | Electronics - Others
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
3,480 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
