Question about Logitech Z-5300e Surround Sound System Computer Speakers
There's a clicking noise when i turn the volume knob with my logitech z-5300
Channels for my z-5300 logitech not working
If you are having problems with you sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 21, 2011 | Logitech Z-5300 Computer Speakers
I just connected my Logitech lS11 speakers. How do I tell my computer that I now have these? When I click on my volume icon in the tool bar to adjust my volume does not work? thank you
Windows does not detect specific models of speakers. I would adjust your Windows volume all the way up and then adjust the sound on your volume knob on speakers. This way the sound volume is easier to adjust on speaker than using the volume control in the toolbar.
Mar 06, 2011 | Logitech LS11 Speaker 2 Speakers
My logitech x240 surround powers on but no sound comes out....what could be the problem??
If you have an extra headset around, plug it into the same place the speakers are plugged into, if it works, your speakers are bad (or check to make sure the power light is on on them and that their volume knob is turned up).
If you still do not get sound, click on your little volume/speaker icon by your clock, then click 'mixer' at the bottom of it (Windows 7 hopefully?). Make sure the different volume controls are turned up because sometimes one low one will affect the entire system.
(If Windows XP, right-click the speaker, then 'Open Volume Control'. Adjust until you hear sound.)
Dec 08, 2010 | Computers & Internet
I HAVE A Z-2300 NO SOUND
Is it plugged in with a 3.5 millimeter jack? If it is, pull it out of the computer and press you thumb on the tip, if no humming noise comes out, your speakers are probably blown.
However, if a humming noise does come out. Please check to make sure the volume on the computer is turned up/unmuted, the software's volume is turned up/unmuted, your sound card driver is installed (Right-Click "My Computer" -> left click on properties -> Click on the Hardware tab -> click on "Device Manager" -> Click the "+" next to "Sound, video and game controllers" and make sure there is no Red "X"'s or yellow "!"'s.
If you do get a hum, and you do have everything set up right in Windows, try a different pair of speakers or head phones. Your sound card might be fried.
Also, make sure you're plugging the speakers into the correct port on the computer (It's usually a washed out green port"
Mar 01, 2010 | Logitech Audio Players & Recorders
I turn them on and no sound
The Following Configuration check:
1. Check your Speaker connect to the computer port properly.
2. check volume balance - go to start-control pannel-sound & game controller - check sound balance.
3. go to My Computer - (right click) - properties - Hardware - Device Manager - Uninstall all sound drivers
4. scan on device manager - It will automatically update.
Feb 02, 2010 | Logitech Z-5300 Computer Speakers
Volume knob does not work
the radio has to be replaced or sent out to get fixed. there is no easy fix to this problem.the knob is shot. (sometimes you can get the vol to move if you wiggle and push and play with the knob)You are better off replacing the radio with a nice aftermarket one.
Dec 20, 2009 | Jeep AM/FM Cassette with CD Changer...
Logitech S500 Volume Knob Broken
The simplest thing to try is some compressed air directed to the knob. This would clear out any dust or dirt that may be obstructing the knob. I am not sure what you mean by power cut so I am shooting in the dark here. If you mean a power surge that caused the volume to quit working then I would suggest an external volume control such as http://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH/ref=pd_bbs_2/002-2257004-6895258?ie=UTF8&s=electronics&qid=1194009359&sr=8-2
Or
http://www.radioshack.com/product/index.jsp?productId=2102975&cp=&sr=1&origkw=volume+control&kw=volume+control&parentPage=search
Dec 18, 2008 | Logitech X-540 Computer Speakers
Popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
May 07, 2008 | Logitech Z-5300 Computer Speakers
Headphone jack is weird...
HAVE YOU TRIED THE BEST QUALITY HEADPHONES LIKE SONY AND DID YOU CHECK YOUR COMPUTERS VOLUME?
Mar 25, 2008 | Logitech Z-5300 Computer Speakers
Noise when changing the volume and connecting speaker to anything.
firstly check the cable, some times it may in loose contact
otherwise any radiation equipment is located near by the amplifier,
sol. replace the location of the amp. and check cable loose contact
other wise
it is due to its amplifier IC problem, it is weak due to over load signal, or temperature of IC make leakage
sol.replace IC
Oct 24, 2007 | Logitech Z-5300 Computer Speakers
Logitech Z-5300e Surround Sound System Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
