What color is the scanning lamp supposed to be? white or red? This is a AIO Dell 1235cn. Thanks
  • 32,281 Answers
White, because white reflects all the different colors.
Posted on Sep 08, 2010
How much does it cost to replace the imaging unit in my 1235cn laser printer?
Janice,
You can call the Dell Spare Parts Department at 1-877-717-3355 for pricing on replacing the imaging unit.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
DellCares
Dec 02, 2014 | Dell K159M 1235cn Multifunction Color...
Dell 1235cn scanner locked
in shoul be scanner motor error.first see the scan light is blinking or not then open the scan lid and manualy rotate the scanner motor.if it rotate normaly then place it again and try to retest.if the problem not solved then replace the scanner mottor
Jun 17, 2012 | Dell Multifunction Colour Laser (1235cn)...
Every time I scan documents on my 1235cn, it puts THREE black lines through my entire scan. I have cleaned the screen and it still isn't working. it only happens when the scan feeds through the top, not...
You have something on the document feeder scan window. Open the top of the scanner like you are going to scan a book or something large. At one end you should see a section that is separate from the main glass. This section is where the document feeder scan the pages. Use a soft cloth with glass cleaner sprayed on the cloth to scrub the windows and the white strip above on the cover that you opened up. Here is the link to our tip page on Fixya with a picture of the scan window.
http://www.fixya.com/support/r3639811-black_lines_faxes_or_copies
This should get you back printing and scanning again.
We hope this helps, if so please rate our solution.
BuddyMc
Dec 10, 2010 | Dell Multifunction Colour Laser (1235cn)...
What is error #2200
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Mar 23, 2010 | Dell 962 Photo All-In-One InkJet Printer
Lost my AIO software
HI you do not need the AIO. You can use Fax and Scan program of Vista.
Mar 07, 2008 | Dell 922 All-In-One InkJet Printer
Printer will not print with color cartridge in
go to dell AIO center
click maintain/troubleshoot on the top
under trouble aio problems - click ink levels
click maintenace tabs
and then clean print cartridges and align print cartridges. then try printing a test page.
if this does not work, remove the cartridges and install them again.
let me know how it goes
Sep 08, 2007 | Dell Photo 964 All-In-One InkJet Printer
Horizontal Banding
From the Microtek KB: www.microtek.com Scans that produce lines, fading, and discoloration generally result from a corrupt scanner driver installation or a burned out lamp. To determine if your problem is caused by a burned out lamp, simply open the scanner lid and check the color of the lamp. If the color is a shade of red, pink, or green, then the lamp is burned out. Perform a scanner preview to get a clear view of the lamp. If the lamp is a bright white and the problem still exists, please contact technical support.
Jun 06, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
Scaning . . . Scanning. . .. not scanned
Not sure if this is the correct way around, but it worked.  Go to Start --> All programs --> Dell Printers --> Dell Photo AIO Printer 922 --> Dell All-in-one center
From here, you can determine and change your scan settings as needed;  then click "scan now" (thus by-passing the button on the actual AIO machine).  This scanned photos into my picture program so I could email to all the grandparents!
Nov 14, 2006 | Dell 922 All-In-One InkJet Printer
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
