Question about Gateway Audiocodes MediaPack MP108-FXS 8 Port VoIP Phone
(2) MP-108 Audio codes - fxo connects to PBX analog stations FXS - has Telephnes this has worked fine for years- custoemr upgrades to MPLS and begins having loss of ausio- reboot fixes issues -- couple of hours later- same thing -
3 Suggested Answers
SOURCE: ACT/SDM 9350 MULTIPLEXOR
I have 1 ;)
a netperformer SDM-9350
I realy dont know its specs but you can contact me at glenns@aapt.net.au
Posted on Aug 30, 2008
SOURCE: AUDIOCODES MP-118 FXO
Hi, I am using Audiocodes MP-118 FXO too
Man, check the Reverse Polarity.
1st.- Go to Protocol Management
2nd.-Go to Advance Parameter
3rd.- Go to General Parameter
4th.- Go to Enable Polarity Reversal and select ENABLE
5th.- BURN and RESET
You have FAS calls, because Reverse Polarity is disable.
Lucky
Posted on Nov 04, 2009
Cannot reset to factory default
Are you unplugging ethernet cable from MP? make sure you do otherwise factory reset will not work.
May 22, 2012 | AudioCodes MP-114-FXO - 0 FXS Ports, 4 FXO...
Can I reprogram a rt31p2 router from vonage
No there is no way to do this, no software to do the job exists.
Dec 29, 2011 | AudioCodes MediaPack MP-114 FXS and FXO...
Unable to access a fresh Audio codes box via http using default IP address.
What IP address are you pointing at? 10.1.10.10? 192.168.0.1? try with 10.1.10.10 and worst case scenario install wireshark on your PC and take a trace when connected directly to MP and power it on, there you will see some bootp messages (IP address 0.0.0.0) and after that you will see messages from MP announcing its IP address. If device is brand new you should login fine using Admin / Admin. Beware that some internet explorers do not allow login even with right user/password, try with a couple of them.
Aug 22, 2011 | AudioCodes MediaPack MP-114 FXS and FXO...
I would like to connect an audiocodes mp 114 fxs to an Avaya Communications manager. The problem is Call sets up but no audio is heard. I also can not get the gateway to register with the avaya aura Ses...
Are you able to get a Wireshark trace from a mirror port of incoming/outgoing traffic for that MP? that way SIP session and RTP (audio) session can be analyzed and issue pinpointed. If no audio is arriving into MP no audio is expected to go out, if audio IS being delivered from the MP to the network, MP is doing its job. If audio IS getting into MP from network but no audio goes out further debug should be made, also if no audio is being delivered from MP to the network.
Jul 29, 2010 | AudioCodes MediaPack MP-114 FXS
My mp-114 dials 5252 when I access a line. Do you
You may have enabled the "auto dialing" feature and may have that destination configured. Please post your INI config file and I will be able to assist you further.
Aug 07, 2009 | AudioCodes MediaPack MP-114 FXS and FXO...
Way to reset mp-114 audio code to factory settings and configure
Unplug the network cable and hold in the RESET button (small hole on back of unit) with a paperclip for 6 - 10 seconds. The default IP is 10.1.10.10 sm 255.255.0.0 if it is an FXS
10.1.10.11 sm 255.255.0.0 if it is an FXO
May 16, 2009 | AudioCodes MediaPack MP-114 FXS
Can u tell me function of DSP , LGS CARDS IN 3600
LGS is same with FXS (Foreign eXchange Subscriber) card. It's voice card for serving voice needs with 2 wire connection. A analog phone connect to LGE on alcatel 3600 and other analog phone or PBX on remote alcatel 3600.
Look the others card e.g LGE (FXO) and E&M card.
DSP card processed the voice.
thanks
Feb 26, 2009 | Alcatel Newbridge MainStreet 3600...
96 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
Tom Chichester
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
