Question about Sanyo 12KS51 11800 BTU Cooling Only Mini Split Air Conditioner with Clean-Air Filter
No cold air though system seems to operate ok in other repects/
    Problem Solver:
  • 10 Answers
Hard to believe it hasnt given a fault code
Posted on Dec 28, 2010
It is brand new and when I start the air conditioner very cold air comes out and within two minutes the air isn't cold anymore.
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. For assistance check us out at Tamarac Ac Company!
May 20, 2016 | Heating & Cooling
Freezer is working properly but fridge doesn't seem to be. Light not coming on and food not cold enough, though not there seems to be some cooling
check that the damper door between the refrige and freezer is operating with the refrige adjust control,sometimes they ice up in a position and cant let cold air in to the refrige,deice it with a hair dryer and then adjust that control and watch if it moves open or closed
Mar 09, 2010 | Refrigerators
I OWN A VOLKSWAGEN PASSAT, JUST BOUGHT IT NOW THE HEAT BOLWS OUT COLD AIR WHAT SHOULD i CHECK OR DO
Check operation of the heater coolant on/off control valve and operating mechanism.
Check thermostat is installed and working OK - replace if in doubt.
Check if coolant heater supply hoses are warm/hot when coolant valve on.
If hoses are cold (no coolant flow evident) check coolant system is properly filled (bleed system as necessary to remove possible air locks).
If still no coolant flow check heater system for blockage.
If all above ok, check heater unit air control vanes operation.
Jan 22, 2010 | 2001 Volkswagen Passat
This car has the automatic temperature control system
The hot/cold switch is probably bad.you have a blend door box that opens to let the cold air in and closes to let the hot air in.From what you are saying this part is no responding to the switch movement.Make sure power is at the switch and power should go through the switch when put on cold air this moves the blend door.Some times the blend door goes bad and has to be replaced its under the dash on the right side.
Aug 10, 2009 | 1999 Mercury Grand Marquis
Temperature gage has fluctuates between 100 and 260, the water is full and fan seems to be working ok, and all belts seems to be ok.
You need to verify that the gage is accurate, if it is then the cause is the thermostat, but check the gage first, a repair shop can do this or you can feel the air coming off the radiator fan, if it is really hot changing to cool rapidly then the T-Stat is sticking open.
Aug 01, 2008 | 1997 Jeep Grand Cherokee
Manual heating system with automatic trans. 7.3 L Diesel, 45k miles
it may be your thermostat, the gauge on the dash is a dummy gauge, there is only three positions that it sees, dead cold, operating temp, and hot, so even though the needle looks fine it just means it s closer to operating temp then it is to cold,
Jul 31, 2008 | 2003 Ford F250 Super Duty Crew Cab
Indest Fridge Freezer
Possibly something was spilled and it got to the door gasket. Clean the door gasket area with warm soapy water. In the door there is nothing critical to the system operation that should cause the condition you have.
May 17, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Sanyo 12KS51 11800 BTU Cooling Only Mini Split Air Conditioner with Clean-Air Filter Logo
56 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
