Question about Brother XL-5340 Mechanical Sewing Machine
Motor locked up and there isn't any tangled thread anywhere in the machine. Pressed the OK button and it still is jammed
    Genius:
  • 1,788 Answers
Try unthreading completely and make sure that the bobbin casing allows thread to come up when you rethread the machine. Make sure that you are turning the handwheel towards you not clockwise, because you can mess up the timing. Read the manual for other suggestions.
Posted on Sep 08, 2010
Janome Magnolia 7318 suddenly started making a lot of noise, sews a couple stitches then jams, bobbin thread tangles. It is clean, no lint or thread anywhere in the undercarriage.
Remove all the thread. Install a new needle. RAISE the presser foot and rethread from the beginning. Confirm it follows the correct thread path and the upper tension is set at the midway point.
If that doesn't resolve the issue, you may need to take it for service.
Jan 15, 2017 | Janome Sewing Machines
Singer Mach. 331K4 won't turn all the way around.
Must be some thread tangled in the bobbin case or the motor is jammed and you will need an electrician . Before asking for professional help, try, changing the needle , look for the timing , check for tangled thread and put the dial on straight stitch .
Jul 15, 2014 | Singer Sewing Machines
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
E-6 is flashing, even after I have removed the tangled thread. What do I do?
try turning off the machine for a few minutes. and see if that clears it
try changing the needle
if the E-6 still keeps flashing then the machine may have to be taken in to be serviced
Jan 24, 2012 | Brother CE5000 Computerized Sewing Machine
I attached the walking foot , but the needle will sew through the fabric
this is what my instruction book says
Lo---a button is pressed when the machine halts due to overload
wait for at least 15 seconds to recover
if thread jamming causes overload, remove the tangled threads
Jan 17, 2012 | Janome Memory Craft 9000 Computerized...
The macine said it was an E6 error thread jam which I completely cleaned the bobbin area (not much there anyway) but I still cannot get it to not jam the thread on the botom. I have changed needles also.
Hello
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Jul 11, 2011 | Brother CS-100-T Computerized Sewing...
I have a problem I lost my owners Manual so I can't figure out what LO means. I sure hope you can help me. Thank You Teresa
A button is pressed when the machine halts due to te overload. Wait for at least 15 seconds to recover. If thread jamming cuses overload, remove the tangled threads.
Jun 22, 2010 | Kenmore 19110 Computerized Sewing Machine
Brother XL-5340 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
