Question about LG WM-2277HW Front Load Washer
IE water inlet error How do I fix? - LG WM-2277HW Front Load Washer
  • LG Master
  • 43,501 Answers
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 08, 2010
IE error code
Water inlet error - washing machine failed to fill
The fault code is displayed, if the washing machine does not detect any incoming water.
·Check wiring to water inlet valve
·Check water valve
·Check drain pump
·Check pressure switch
Check PCB
Oct 05, 2014 | Daewoo DWDWD3011WW Front Load Washer
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
What is problem code IE and how do I fix it on my LG front load washing machine?
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. if this doesn't help then there are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg
Hope this helps.
Mar 09, 2011 | LG WM-2277HW Front Load Washer
IE error code
IE. is inlet water valve error.
Make sure someone did not turn off the water to the washer!!!!
Remove fill hoses and check filter screens on washer and fill hoses and clean if needed.
If problem continues water valve may need to be replaced.
Jan 16, 2010 | LG Washing Machines
Error LE
The "IE" code indicates a water inlet problem. If the correct water level is not reached in eight minutes, this code is generated. Check the water inlet valve. Unplug the machine, turn off the water, and remove the water supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter.Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will have to be replaced. I'll attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Nov 17, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Keep on getting the IE erorr
Error code IE means an water inlet error. Correct water level is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes.
Make sure water supply tap is open and not frozen. Check and clean water inlet valve from debris. If the issue persists, replace water inlet valve.
Oct 18, 2009 | LG WM1814CW Front Load Washer
I am getting an IE error on my control panel. It seems to start ok but once it starts to fill with water the IE error comes up and the machine shuts off. How can I fix this?
You do not list the manufacturer and model number, but it sounds like you own an LG dishwasher.
The IE error indicates that the water is not entering the dishwasher or it is entering too slowly / with little pressure. It is important to check the water inlet pipe (hot water connection under the sink) all the way to the dishwasher. Check for any kinks/blockages after you confirm that the valve at the sink is fully open.
Please report back here with what you find. If you still have problems, there are other things to check, including the solenoid valve just past the connection of the water inlet.
Aug 03, 2009 | LG Dishwashers
What does IE on the display mean?
IE means inlet error. Most likely the washer took too long to fill, due to a plugged screen where the hose attaches to the inlet water valve. Frozen water line would do it also. Or a bad water valve.
Dec 05, 2008 | LG WM1814CW Front Load Washer
LG Dishwasher ie error code problem
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Oct 31, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
IE Error - stressed motor
Possible cause:
Remedy:
Jul 27, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG WM-2277HW Front Load Washer Logo
253 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
