Question about Vulcan Heating & Cooling
Pilot light will not stay alight to ignight gas burners
    Master:
    Sergeant:
  • 449 Answers
Check the thermal couple
Posted on Sep 08, 2010
Although pilot lights are lit, only one burner works the other 3 do not??? also do not see pilot light for oven??? does it even have one or light by match only??
Hello Linda
All burners have a small hole in the flame spreader which directs a jet of gas to the pilot lights when you turn the burner knob. These get clogged by food residues over time.
Remove all the burners and give them a good soak in hot soapy water. Sometimes you need oven spray first.
All modern ovens have a pilot light. There will be a red button which is usually hidden below the front removable panel or just inside a warming drawer at the top. You press and hold the red button and then light the pilot inside the oven. You continue holding the button for the flame to heat up a gadget called a thermocouple. This is a valve that only allows gas to the main burner if the pilot light is alight.
Take a look at the videos in the link.
pilot lights Google Search
Aug 23, 2016 | Kitchen Ranges
Rayburn problems
if the pilot flame onto the thermocouple is 2 small [partialy blocked pilot feeder orifice] this will cause your described symptoms also flame 2 far from t/couple ! Tip of flame farthest from pilot burner should touch and slightly overlap tip of thermocouple
Dec 23, 2013 | Heating & Cooling
Hello i have a J5 lincat fryer and the pilot stays alight but the burners won't connect (light) have replaced the thermostat and the thermo couple but still no joy any ideas on this not sure what to do...
Check if there is 500 to 750 millivolts across the thermopile wires; thermopile generates 500 to 750 millivolts if properly heated to energize pilot and main valve solenoids of the gas valve for pilot and main burner operation. If the voltage across the thermopile is good and all wiring connections are ok, I think you have to replace the gas valve.
Regards.
Jun 15, 2011 | Imperial IFS40 Deep Fryer
How to light the pilot light on a natural gas wall heater
SEt to pilot, Push knob, push pezio ignighter until pilot lights, hold for 30 seconds. if it stays lit turn to on, if it doesn't stay lit, you have a bad thermocouple
Mar 24, 2011 | Vulcan Heating & Cooling
2 of the 4 burners on my maytag gas stove aren't working. the oven is fine, just need to know where to light the pilot
Most newer Ranges don't have a pilot ... they have an electronic ignighter. When you first turn the burner on ...you hear the spark going crack,crack
Feb 20, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Burner will not light. With the pilot light burning and the gas is turned-on to ignight the main burner the pilot light goes out.
call aservice tech your pilot light might be blocked therefore the pilot flame might not be strong enough to handle the puff of gas when the gas valve opens ps. if the unit is off in the summer spiders are usually the problem. Hope this helps
Aug 19, 2010 | Endless Summer Heating & Cooling
Pyrox natural gas heater not functioning properly
Clean the burners out with air pressure,like from a air tank,and a blow gun,then clean the pilot light orifice(this is where the pilot light is)if this does not help,replace the thermocouple ,it will be the problem,if this was at all helpful,please rate,thank you.
Jun 15, 2010 | Heating & Cooling
N90 EHLtype C 11 Pilot gas wont stay alight.
Your problem is probably with the thermacouple. Contact a service company.
Apr 13, 2010 | Thetford Refrigerators
Heating & Cooling Logo
107 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
