Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
How do i use this deice to save my material on it
    Sergeant:
  • 172 Answers
Plug in your device to the computer wait until its installed or detected by the computer
eg open my documents folder right click on the item or files you want to transfer to your Sandisk and select send to (send it to the name of sandisk)
or you can
open my computer > open sandisk window then open the my documents folder or the folder you want to copy and drag it over to sandisk window
hope this help
Posted on Sep 08, 2010
Engine cranks but can not start for RAV4
There are pages of good material to read in the link below and it saves a lot of writing . Study this material and it will help you diagnose the cause or causes.
Crank No Start
Dec 17, 2015 | Cars & Trucks
Tip
Deicing Your Windows
Summary: During the winter months, or even a freak spring storm, it isn't uncommon to find the windows of your car covered in ice. Deicing your windows can be a bitterly cold experience, so why not learn the best possible ways for both preventing ice from forming on your windows and removing it in a hurry when you need to. Here's how. I really don't like going outside every morning to deice my windows. If you live in cooler (or even colder) climates, then chances are pretty good that you know what I'm referring to.
Over the years I have tried many different methods for deicing windows. I discovered that some work (though at a risk) while others seem to work just fine at preventing ice from forming (what better way of deicing your windows-provided you remember to do it, and others work-but require you to get really cold. Here are some methods, and a brief description of what happened to me when I used them.
  • Defroster. Probably the most common method available. Unfortunately, this method also comes with risks. While a properly working defroster can quickly (no more than 20 minutes usually) remove icy build up, it can also worsen any preexisting cracks in your windshields if turned on too high. There is another drawback to this method, and that is its cost. You can't really run the defroster without turning on the engine, and that takes gasoline.
  • Scraper. The traditional method for removing ice from windshields, a scraper should be in every vehicle that is in a cold climate. In fact, many car rental companies include them in their cars when you rent a vehicle from them during the winter. On average, this method can take about as much time as the defroster method, and while you are not as likely to crack your windshield, you will most likely get cold.
  • Vinegar. One of the best ways for deicing your windshield and windows is to prevent the ice from forming at all. However, not everyone has a garage that they can store their car in. In those situations, it is best to use a 50/50 solution of vinegar and water. Use half vinegar (any kind, though I prefer white since it does not smell as much) and half water in a spray bottle and spray it on your windows at night. This helps prevent ice from forming. The only drawback is that you have to remember to use it at night, otherwise it doesn't do you very much good. Although you can still remove ice by spraying some on your windows in the morning, you'll just need a whole lot more.
  • Rubbing Alcohol. For those who really need to move, try putting about 5 tablespoons of rubbing alcohol into your windshield washer reservoir. This turns the regular windshield washer fluid into a deicing agent at a fraction of the cost, and works wonderfully. Simply spray and use your windshield wipers as normal.
  • Blanket. This is perhaps the easiest way to prevent ice build up on your windshield. Just place a blanket over your windshield at night, and remove it before driving anywhere.
on Feb 03, 2011 | Chevrolet Malibu Cars & Trucks
How can i turn the refrigerator side off on my samsung rs264 model?
Can't be done. The fridge gets cold because air comes over from the freezer...that's true of all refrigerator/freezers. You'll need to shut down the entire thing to deice it.
Jul 08, 2014 | Samsung RS2630SH Side by Side Refrigerator
Why does my AC unit freeze up...and how can I prevent it from happening?
YOu have the temp set to low.. they need to shut down every now and then to kinda deice. Check the filter as well . lose off rooms that are not in use during the day. But my guess is that it's set way to cold.. you will also have to shut it down for a hour or 2 and deice it.
Jul 13, 2011 | Goldstar Heating & Cooling
I purchased danby dehumidifier less that 1 year ago and p1 is on most of the time. What can I do?
According to your Owners Manual:
P1 is part of a normal function of your dehumidifier. When your compressor is working it will build frost on the evaporator coils. When there is enough frost on the coils the unit will go into a P1 deicing program. This deicing cycle will last anywhere from 15-45 minutes. Once complete it will automatically resume normal function. The cooler the room the more often this function will turn on.
If you think it's still staying ON to long, contact Danby Consumer Help 800-263-2629
Hope this helped you.
Apr 28, 2011 | Danby DDR607EE Dehumidifier
I BOUGHT A USED ASPIRE 3100-5100 MOTHERBOARD AND GET THIS ERROR WHEN IT TRIES TO BOOT. ERROR Resource Conflict ? PCI in slot 03 Bus:06, Deice:01, Function:00 ERROR Resource Conflict ? PCI in slot 03...
You should try clearing the cmos battery. It's a small battery on the motherboard that can be taken off. Take it off for 20 minutes and put it back in. Then boot up again.
May 03, 2010 | Computers & Internet
My father has an Electrlux ER 78311 fridge/freezer. It started icing up inside fridge and top of freezer. After we deiced it, it stopped working altogether. Still makes a noise as though it's working....
Did you deice totally or just the ice you saw. To properly deice the freezer section you have to remove the panel on the back of the freezer section and using a hair dryer remove all frost build up on the evap. coils. The most common cause of this problem in these models is the defrost t-stat going bad. Install a new defrost t-stat located on the coils and you will be good to go again. Hope this helps.
Feb 03, 2010 | Electrolux Refrigerators
Easy Heat roof deicing cable with a nick
cut the cable and rejoin with snap joint the cover with insulation tape that should do the trick
Nov 14, 2009 | Easy Heat Water Pipe Heating Cable
I cant hear my ringtones all it does is vibrate how do i fix it
Click on Profiles-select advanced-Select the type of profile-Select the type to be activated out of the Holster-(None-tone-vibrate-vibrate+tone)select the ring tone-Select volume adjust according to your wish(Low,Medium,High or Escalating) Do the same if the deice is in the Holster and save.After saving do hard reboot.
Jul 14, 2009 | RIM BlackBerry Pearl 8100
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
35 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
