Question about Avermedia AVerKey Plus (AVERKEY-PC)
No video to tv from averkey plus conexion in pc is o.k.
I am trying to hook up an averkey to a laptop and TV. I have the TV set on video-1 and I have used the FN -F7 keys several times but I still do not have a picture on the TV and the red freeze light...
Check the resolution you are outputting to the TV and check the resolution the TV is set to. These must match for the TV to display properly.
I hope this helps
Aug 31, 2011 | Avermedia AVerKey 300 Gold (61K0C3BF)...
Is there a way to get audio to my tv through this device?
What you need is a audio Y splitter such as a Belkin Audio Y Cable Splitter You can pick one of these up at your local radio shack.
Plug the stereo jack into the audio out on computer (green colored port) Then plug the red/white ends to the matching ports on your tv. Make sure you use the same audio ports that the video from the iMicro is plugged into.
Mar 01, 2011 | Avermedia AVerKey iMicro (58686)
I whant driver averkey plus v5.20 work whit
send request to need_software@ymail.com
Aug 25, 2009 | Televison & Video
Averkey
Unit powers up but will not show a picture on the TV. Was working previous day. I have check all cords and even replaced them with ones from another averkey but still no picture.
Apr 02, 2008 | Avermedia AVerKey Plus (AVERKEY-PC)
BLACK AND WHITE PICTURE
Verify that your region setting is correct, ie USA is NTSC.
Please let me know if this works for you.
thanks
Jan 18, 2008 | Avermedia AVerKey iMicro (58686)
AveMedia
averkey lite I work with xp ok.but I opperating vista now I cant on my tv screen.
Jan 09, 2008 | Avermedia QUICKPLAY (pquickplay)
AverKey3 Plus
Hi, sorry to tell you this, but static electricity has killed every conceivevable type of electronic device ever built by man or woman. The insides of your TV has very high voltage and the only safe solution is to take it to a repair man. Ask for a qoute before any work is done, try to get at least 2 quotes.
It may be cheaper to replace than repair the unit and with 2 quotes you will know that you are not being conned.
Regards mistyman
Oct 09, 2007 | Avermedia AVerKey Plus (AVERKEY-PC)
Avermedia Averkey lite - Monitor Colour Display Issue
I had the same problem. I was going from PC -> Dvd recorder -> TV.
I had the S-Video output from the averkey going via an adaptor into the DVD scart input. I discovered a setting within the DVD menu which could select between 's-video' and 'composite video' on the scart socket. (it appears that scart can carry either/or, I guess).
I changed from composite to s-video, and I got colour.
I think seeing a greyscale image indicates that the signal being sent is S-Video, but the equipment that is recieving it is expecting composite video.
Sep 23, 2007 | Avermedia QUICKPLAY (pquickplay)
Avermedia AVerKey Plus (AVERKEY-PC) Logo
48 people viewed this question
Top Avermedia Televison & Video Experts
Alun Cox
Are you an Avermedia Televison and Video Expert? Answer questions, earn points and help others
