Question about Whirlpool Refrigerators
My side by side whirlpool refrigerator is icing up on the back wall of the freezer and the refrigerator side is not getting cold enough. I think it is the defroster what do I do to find out. I think the model # is Eb5ltaxvloo Conquest. I bought it in 2008.
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 08, 2010
Can feel cold air coming out of bottom of freezer but it is not cold inside
Do you see ice buildup on the back of the freezer wall about half way down?
Dec 28, 2013 | Whirlpool GS6NBEXR Side by Side...
Not cold enough, side by side
Do you see any ice buildup on the back wall of the freezer? You may need to pull the back wall panel to see if there is ice on the coils.
Feb 06, 2013 | Whirlpool Refrigerators
My whirlpool gold two sided refrigerator, model #6D5RHAXNB00, the refrigerator side is not getting cold enough! I can't feel any cool air coming through the vent on the left upper corner.
your freezer may be iced up not allowing the cold air from the freezer to blow into the frige .you may see a ice build up on the back wall of the freezer.an ice build up can also stop the fan.if you can leave the unit off for 12 hrs or longer to thaw and that helps after restarting you may need to change the defrost timer ,defrost heater or both.a faster way is to remove the covers if you can do that.
Jan 15, 2013 | Refrigerators
The freezer is not cold enough to freeze nor is the temperature in the whole refrigerator cold.
most likely you have a bad computer board if the freezer is getting warm too.if there's no ice on the back wall of the inside freezer wall then it's the board.you can check this site out
http://fixitnow.com/wp/2009/11/30/ge-refrigerator-motherboard-recall-list/
Feb 01, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
FREEZER SIDE TOO MUCH ICE FRIDGE SIDE NOT TOO COLD
If it has ice buildup on the back wall inside the freezer, it appears to have a defrost problem. Unplug it, put your food in another unit (or ice chests), open the freezer door and let it thaw out overnight for at least 12 hours or more, or until all the ice has melted from *behind* the back wall. Then close the doors and run it for 4 hours and check to see if the fresh food side is cold. If it is, call a repairman to fix the defrost problem. That could be a burned out heater, terminator, or defrost timer depending on your exact model.
Jan 03, 2010 | Whirlpool Refrigerators
Our freezer and fridge or not keeping cold enough
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor or back of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker was hot and could hear water dripping on
yes.you will have to replace the ice maker.if further used without replaceing the compressor will get damaged and you will completely loose cooling in your unit.
Mar 07, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Ice forming in freezer refrigerator not getting cold
Replace your heater and thermostat behind the back wall of the freezer. the air will not flow from the freezer to the fridge because of all the forming ice. Also replace the defrost timer. take your model number into a local parts store and they can get you the parts. This is very common!!!!! But pretty easy to do.
Nov 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker and frige
A COMMON FAILURE FOR THE WHIRLPOOL REFRIGERATORS THAT CAUSE NO COOLING IN THE FREEZER IS A BAD RELAY ON THE COMPRESSOR.
LISTEN CLOSELY FOR ABOUT 5 MINUTES TO THE BACK OF THE REFRIGERATOR. IF YOU HEAR A CLICK AND THE COMPRESSOR HUMS AND THEN CLICKS AGAIN AND SHUTS OFF THE COMPRESSOR, THE RELAY IS MOST LIKELY BAD. ABOUT A 40 DOLLAR COMPONENT.
ALSO, CHECK THE FREEZER BACK WALL. IF IT IS FROSTED UP, THERE IS A FAILURE OF THE DEFROST CYCLE. YOU WOULD HAVE TO CHECK THREE COMPONENTS. THE DEFROST CONTROL, HEATER, AND BI-METAL.
Apr 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
If the frost is on the back wall of the freezer then you most likely have a defrost problem or a bad evaporator fan motor.
Jan 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
97 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
