Question about Toshiba Satellite A135-S2276 Notebook
Hi Purchased a new 6cell Li-ion Battery for Toshiba laptop .It is giving backup of 2hrs30min .I kept battery with laptop for 3 months and again i started the laptop not charging .it is charging for some Percentage and stopped the charging.Can u please guide me what to do?
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 08, 2010
Can i rebuild this battery pack, and if so, can i add more cells
Not recommended. The case would have to be modified to accommodate more cells, the circuit board inside the battery casing may not function properly, and unless you have a commercial dual pulse welder working with Li-ion could ignite. Save time and money and pick up an extended battery such as this one : http://tinyurl.com/pxcpqv9
May 22, 2013 | Toshiba Pa3817u-1brs Laptop Battery -...
Tip
Samsung SLB-11A Battery
Batteries are very important, here has the best quality products and considerate service
Battery Type: Li-ion
Voltage: 3.80V
Capacity: 1130mAh
Color: Black
Dimension: 43.40 x 31.70 x 7.40 mm
Product Type: Replacement Battery (Brand New)
Condition: New, 1 year warranty!
Weight: 49.61 g
Inventory: In Stock
1. New Generic Samsung i8 Compatible Li-Ion Battery
2. Extra power for your Samsung i8 camera or camcorder
3. High capacity rechargeable Li-ion Battery with premium cells
4. Absolutely no memory effect so you can charge battery at anytime
5. Usually Ships Your Samsung i8 Battery in 24 Hours, 12 months warranty.
on Sep 21, 2010 | Cameras
Tip
Laptop Battery Common Knowledge You Should Know
There are five common laptop battery knowledge you should knowQ1: What does 3 cell, 6 cell means we said normally? Is it related to the battery capacity?
A1: 3 cell, 6 cell means the battery cell amount in the battery. The more batteries cells, the greater capacity of the battery, and also the longer use time.
Q2: How many kinds of the laptop batteries?
A2: It is mainly divided to nickel-cadmium battery, Ni-H battery, Li-ion battery. They always show as Ni-Cd, Ni-MH, Li. Recent years, a kind of fuel battery appears in laptop field. The present laptop commonly use Li-ion battery, but seldom model still use the obsolete Ni-MH battery, consumers can identify this from the sign on the batteries.
Q3: Why the manufacturers only implement 1 year guarantee policy for the battery?
A3: Li-ion battery working life is very short. Normal Li-ion can only charge 400-600 times. After special improvement battery also can’t exceed more than 800 times, it turns to obsolete after 2 years working life.
Q4: Why do the batteries can’t be use reach to the nominal time which announced by the manufacturers?
A4: The test condition is different. Some manufacturers use 8 cell battery to do test, but supply battery users 6 cell battery, some manufacturers close all the programs, turn down the LCD screen brightness, ban to using high power interface and other measures to test the working life, but it is can’t be reach in the daily life. And some other manufacturers only use the software to do test, but software test may cause error.
Hot laptop batteries on sale:
dell inspiron 1525 battery US $ 56.59
dell inspiron 6000 battery US $ 70.69
dell inspiron 6400 battery US $ 77.90
dell xps m1530 battery US $ 66.18
Q5: What should be take notice for the using and storing of the battery?
A5: Users should pay attention to below points:
1 The battery should be charge full over 8 hours in the beginning charging process to activate the Li-ion battery sufficiently.
2 The battery can not be discharge excessively.
3 It is better not to use the battery when use the AC adapter at the same time.
4 Storing attentive points: The battery should be take out to charge at least once monthly, It is inadvisable to store the battery when the battery is full, it is good to charge only 40% - 50% for the storing purpose, last but not least, the battery should be put in the dry and shade places.
more batteries info via :
http://www.sales-battery.com
http://www.global-battery.co.uk
on Jun 04, 2010 | Computers & Internet
My toshiba satellite u300-153 laptop battery doesn't charge even when pluged in.
If the battery is older than 2 years then it is most likely the battery. I would also try to take out the battery and leave it out for a few minutes. Then try it again.
Mar 24, 2011 | Amstron Toshiba Satellite U300-153 Laptop...
I,m not sure my problem can b fixed so I don't won,t to put my credit card info online
Hi barbr130,
if you have a problem with Battery, Buy new one. battery cannot be fixed by your self.
good luck!
Mar 16, 2011 | Amstron Toshiba Tecra A5-S416 Laptop...
Tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 | Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
