Question about Dell Inspiron 2200 Notebook
Everytime I turn my laptop on I get the following error: error loading c:\windows\system32config\systemprofile\appdata\local\ihabiduke\mugaxav Then it says access denied. It has limited my internet access.
    Sergeant:
  • 132 Answers
You should reinstall your windows.the file is had become curropted due to viruses.
Posted on Sep 08, 2010
I keep getting an error message that says, "Microsoft Outlook. Cannot open the Outlook Window. The set of folders cannot be opened. Errors have been detected in the file C:\Users\my name\AppData\Loc
To resolve this problem, use the following steps. On the Start menu click Run. In the Run dialog box, type the following command:
Outlook.exe /resetnavpane
Note:
There is a space between "Outlook.exe" and "/resetnavpane" Click OK. Note If you are using Windows Vista or Windows 7, you may not see Run on the Start menu. In this situation, use the following steps to locate the Run option. On the Start menu click All Programs. Click Accessories. Click Run.
Apr 15, 2013 | Dell Computers & Internet
Why does my acer asprie 5742 keep clearing my cache?
METHOD 1: Reset Corrupt Thumbnail Cache Folder
First of all try to reset thumbnail cache folder so that it starts storing thumbnail cache files from scratch.
1. Press Win+R keys together to launch RUN dialog box, then type following string in RUN box and press Enter:
C:\Users\Username\AppData\Local\Microsoft\Windows\Explorer
Replace Username with your correct Windows user account name.
If the above trick doesn't work for you. Type appdata in RUN dialog box and press Enter. It'll open AppData folder. Now go to "Local\Microsoft\Windows\Explorer" folder.
2. Once you open Explorer folder, select all files/folders present inside it and delete them.
Some files might remain in the folder. Leave them and restart your computer. Now Windows should create thumbnail cache without any problem and it'll not delete them again.
Dec 01, 2012 | Acer Aspire One PC Notebook
Every few days my pc goes to bluescreen and shuts down (restarts). Problem description is given as follows: Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7600.2.0.0.768.3 Locale...
Hi !
I suggest to run your computer on safe mode by restarting your computer and press F8 when booting to load the fixed some error and driver conflict. Then windows setting will load and restart again. See if this solve your problem.
Good Luck. I hope it helps you.
Jan 09, 2011 | Microsoft Windows 7 Home Premium for PC
I just removed a virus from my computer running Vista now when I start it up it shows 2 errors Error loading C:...\AppData\Local\uhidatugapojuy.dll Error loading...
How did you remove the virus? If you deleted files in the hard drive you have likely removed some .dll files as well. The best solution is to re-install the operating system from the set-up disc or from the hard drive partition if you know how to access it - you can go to the MFRs site to determine the process. It might require a key stroke order i.e. F11, to activate the recovery partition upon turning on the computer from cold start. You will as well need to go to the Dell website, enter your service tag number and then download the drivers needed for your model.
Oct 25, 2010 | Dell Inspiron 9400 Notebook
Error 1606
Re: Please Help Unable to Install TIVO Desktop -- Error 1606. Could not access network location %APPDATA%\
The response to "Echo %appadata%" should be
C:\Users\UserName\AppData\Roaming
A space in the user name shouldn't be a problem, but creating a new user may fix the problem because it will create the account with default registry settings which will hopefully have the missing %appdata% information.
If you want to check on this before creating the new user, just for curiosity's sake, check the following Registry key:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders and check the value for AppData in the right hand pane. If it's missing, then that would explain the problem. It should be as listed above, substituting the UserName with the folder name for the user under Users.
Also check the key
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
The value of this key should be
%USERPROFILE%\AppData\Roaming
More keys to check:
HKCU\Volatile Environement (1)
HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
HKU\Sxxxxx\Volatile Environement (1)
The values in (1) should have the full path spelled out, the values in (2) should use the %USERPROFILE% variable in the path. If the value under HKU\.DEFAULT is missing or bad, then creating a new user probably won't work either. If that value is missing, then I would recommend a clean reinstall of Windows because there is no telling what else is messed up also.
The value for AppData in the registry key HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
is C:\Users\Murray Admin\AppData\Roaming
In the key the key
The value for AppData is %APPDATA%
The value for Local AppData is %USERPROFILE%\AppData\Local
In HKCU\Volatile Environement (1)
The value for HOMEPATH is \Users\Murray Admin
In HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
The value for AppData is %USERPROFILE%\AppData\Roaming (all the keys have the %USERPROFILE%\ )
In HKU\Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders (2)
The value in one of the \Sxxxxx\Software\Microsoft\Windows\CurrentVersion\Explorer\UserShell Folders keys for AppData is
%APPDATA% (Missing the %USERPROFILE%\ ) --- Could this be the problem???
All the other values within do contain %USERPROFILE%\
Do you think editing the key, adding %USERPROFILE%\ would do the trick? If so, it would be alot eaiser then
a re-install. There is not much junk on it as this pc is only about a month and a half old. The other machine
is about six months old. Both are from the same manufacturer (Compaq) but different models.
Also - Using the set command the value returned for %APPDATA% are:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Murray Admin>set
TEMP=C:\Users\MURRAY~1\AppData\Local\Temp
TMP=C:\Users\MURRAY~1\AppData\Local\Temp
Jan 20, 2010 | HP Computers & Internet
Trying to install office 2007 but keep getting error code 1606 cannot find network location %APPDATA%. What can I do to fix this?
To resolve this issue, follow these steps:
  1. Click Start, click Run, type Regedit.exe, and then click OK.
  2. Locate and then click the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  3. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 7. For Windows XP and for Windows Server 2003, see the following table. Collapse this tableExpand this table Value name Type Value data AppData REG_EXPAND_SZ %USERPROFILE%\Application Data Cache REG_EXPAND_SZ %USERPROFILE%\Local Settings\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\Local Settings\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\Local Settings\Application Data Local Settings REG_EXPAND_SZ %USERPROFILE%\Local Settings My Pictures REG_EXPAND_SZ %USERPROFILE%\My Documents\My Pictures NetHood REG_EXPAND_SZ %USERPROFILE%\NetHood Personal REG_EXPAND_SZ %USERPROFILE%\My Documents PrintHood REG_EXPAND_SZ %USERPROFILE%\PrintHood Programs REG_EXPAND_SZ %USERPROFILE%\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\Start Menu Startup REG_EXPAND_SZ %USERPROFILE%\Start Menu\programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\TemplatesFor Windows Vista, see the following table. Collapse this tableExpand this table Value name Type Value data {374DE290-123F-4565-9164-39C4925E467B} REG_EXPAND_SZ %USERPROFILE%\Downloads AppData REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming Cache REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files Cookies REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies Desktop REG_EXPAND_SZ %USERPROFILE%\Desktop Favorites REG_EXPAND_SZ %USERPROFILE%\Favorites History REG_EXPAND_SZ %USERPROFILE%\AppData\Local\Microsoft\Windows\History LocalAppData REG_EXPAND_SZ %USERPROFILE%\AppData\Local My Pictures REG_EXPAND_SZ %USERPROFILE%\Pictures My Music REG_EXPAND_SZ %USERPROFILE%\Music My Video REG_EXPAND_SZ %USERPROFILE%\Videos NetHood REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts Personal REG_EXPAND_SZ %USERPROFILE%\PrintHood PrintHood REG_EXPAND_SZ %USERPROFILE%\Documents Programs REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs Recent REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent SendTo REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo Start Menu REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
    Startup REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup Templates REG_EXPAND_SZ %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
  4. If any Name, Type, or Value does not match the table in step 3, right-click the Value name, and then click Delete.
  5. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 3, and then press ENTER.
  6. Right-click the value that you created in step 5, click Modify, type the value in the Value data box for the Value name, and then click OK.
  7. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  8. In the right pane, verify that the values are the same as the values in the following table. If each value matches the table, go to step 12. Collapse this tableExpand this table Value name Type Value data Common AppData REG_EXPAND_SZ %ALLUSERSPROFILE%\Application Data Common Desktop REG_EXPAND_SZ %ALLUSERSPROFILE%\Desktop Common Documents REG_EXPAND_SZ %ALLUSERSPROFILE%\Documents Common Favorites REG_EXPAND_SZ %ALLUSERSPROFILE%\Favorites Common Programs REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs Common Start Menu REG_EXPAND_SZ %ALLUSERSPROFILE%\Start menu Common Startup REG_EXPAND_SZ %ALLUSERSPROFILE%\Start Menu\Programs\Startup Common templates REG_EXPAND_SZ %ALLUSERSPROFILE%\Templates
  9. If any Name, Type, or Value does not match the table in step 8, right-click the Value name, and then click Delete.
  10. In the left pane, right-click User Shell Folders, point to New, click Expandable String Value, type the Name value that you want from the table in step 8, and then press ENTER.
  11. Right-click the value that you created in step 10, click Modify, type the value in the Value data box for the Value name, and then click OK.
  12. Exit Registry Editor, and then restart the computer.
Sep 04, 2009 | Microsoft Windows Vista Home Premium with...
C:\Users\toshiba\AppData\Roaming\fyxegtbu.dll
You have Malware or Spyware. If you can load your destop, download and run http://malwarebytes.org and http://www.spybot.com. If you can't load your desktop, download (including updates) from another computer and run on your desktop. Good luck.
Jun 17, 2009 | Microsoft Windows Vista Ultimate Edition
Scanner won't work
try removing the program first then remove the scanner from the computer then turn it off for 60 sec. thenafter 60 seconds turn it back on then connect the scanner again wait for a pop up on the lower right of the screen it will message you that found new hardware then click on it and try installing your software if there is no pop up your scanner might have a problem. hope i help
May 03, 2009 | Computers & Internet
Memory Module & hardware conflict
Dear Sir
Please try latest service pack from net and check. Some hardware devices are not compatiable.
Mar 12, 2009 | Toshiba ZA2000P02 - Satellite...
Dell Inspiron 2200 Notebook Logo
82 people viewed this question
Alun Cox
