Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
SMELLS WHEN I FLUSH - Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
  • 127 Answers
This brand of toilet needs to be vented to the outside. If you left the pipe open or the seals are not intact it will emit a smell when flushed.
Posted on Sep 10, 2010
1998 t100 Transmission slipping in drive and reverse.
Check your transmission fluid levels first. If its good then that rules that out. When was the last time you did a transmission fluid flush and filter? It's recommend to flush and change filter in transmission every 30,000 miles. Also if fluid looks redish brown and smells burnt you could have bad bands.
Sep 27, 2013 | Cars & Trucks
Cadet 3 toilet smells like pee - NOT a SEWER smell, a urine smell. It's a brand new toilet, installed by our contractor. There's a brand new extra thick wax ring too. The room smells like urine when nobody...
If your contractor supplied the toilet, then it is his/her problem, not yours. If you supplied the toilet, then: take a mirror and examine under the lip of the bowl. How does the glazing look? Are there areas without glaze? If so, these bare areas are a breeding ground for bad odors. You can try a thorough cleaning both inside the bowl and around the outside of the toilet with an amonia cleaning product. If you use amonia, DO NOT use bleach: the two combined create a deadly gas. Whatever you do, do not hang a bleach based product inside the tank: the bleach will eat away at anything rubber inside the tank. There is a bleach product that hangs inside the tank and disperses the bleach directly into the tube that leads to the toilet bowl. This would be OK.
Aug 12, 2013 | American Standard 4021 White Cadet 3...
Water smells like rotten eggs.
When the water heater smells bad, it is time for a new anode rod.
And then you flush the water heater with 2 bottles of hydrogen peroxide.
With water heaters that experience the problem frequently, you change your incoming cold water pipes so hydrogen peroxide can be added easily.
http://waterheatertimer.org/Replace-anode-rod.html
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
http://www.waterheaterrescue.com/pages/WHRpages/English/Longevity/water-heater-anodes.html
http://www.prweb.com/releases/2010/02/prweb3592714.htm
Oct 23, 2010 | RELIANCE ELECTRIC WATER HEATER
Drum smells
Open the door and run your hand deep inside the door seal. It probally has a slime around it. You can clean this with a bleach water mix. You might need to pull the seal somewhat inside out to get it real clean. Then run an empty load to flush it all out. Here is a link for replacing the seal or spring clips if you pull one off. http://appliancehelponline.com/washerdoorseal.html
Jul 07, 2010 | Hotpoint Aquarius WD640 Front Load...
The washing machine smells!!
Run a load of just water and chlorine bleach. Run it HOT. After that, use bleach to clean the door seal and seat.
Apr 10, 2010 | Zanussi ZWF1640 Front Load Washer
Jeep grand cherokee transmission clunk
well then it sounds to me as if you need a transmission replacement...a flush or service at this point won't do you any good, as the transmission is using the contamination in the fluid to build pressure. so if you flush it all away, then the new fluid is way too thin to build any pressure...just replace your transmission....
Nov 19, 2009 | 2000 Jeep Grand Cherokee
What is it when the transmission delays to shift?
a few different reasons first check fluid level--look and smell oil if it smells burnt have fluid and filter replaced-- filter need changing-mechanical band/gear slipping
Oct 30, 2009 | 1996 Ford Crown Victoria
The water and ice in our refrig tastes and smells like rotten eggs. our water from the tap does not. even with a filter it still smells that way. It was perfectly fine for the first 4 months we had it....
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
Aug 13, 2009 | Maytag MFI2569VE Bottom Freezer French...
Inside my machine smells musty
Make a solution of Hot water and Soda crystals obout 2 liters
Pour it into the machine and do a couple of very hot washes.
It will not harm the machine and will flush away residues that make the smells
Leave the door slightly open whe nthe machine is not in use as that will allow the inner and outer drum to dry properly
Jun 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Ice smells, and tastes bad...no filter to change?
May 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
750 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
