Question about Meade Infinity 114EQ-DH Telescope
My lens adjuster broke on my telescope and I can no longer adjust my view. it seems that the wheel had plastic teeth. Where can I get a replacement and what is the real name of this part?
  • 3,186 Answers
You can buy another FOCUSER at several online sites-- here is one:
http://www.telescope.com/control/accessories/telescope-focusers/2-inch-orion-crayford-style-telescope-focuser
Posted on Sep 08, 2010
How do you set the finder scope on the Starview 150EQ. I have no adjustment options and it is not in line with the main telescope alignment. The instruction manual is totally inadequate.
Place a wide angle, that is longer focal length lens in the scope in daylight and focus it and centre on some distant object, a tree, blg, tower etc.
Then use the adjustment screws on the finder to centre it on this same object.
Change to your next higher power lens, that is shorter focal length, refocus and centre, and repeat with the finder adjustment.
Next wait for evening and a bright star or planet to appear and centre it in the finder first this time. It should be somewhere near centre in the lens also. Centre it properly in the lens and make a final adjustment on the finder.
Dec 30, 2016 | Optics
I can not get the telescope to focus. The viewfinder will not focus in. and can't see anything out of the out of the optical tube.
This type of telescope is viewed from the small tube at the rear. Use the longest lens you have. Most people think that they need magnification, but that is not accurate. A 5 mm lens will only have 1/6th the field of view (how much sky you see) compared to a 30 mm. The picture below was taken through a 50 mm lens.
Dec 20, 2014 | Meade ETX-90EC (325 x 90mm) Telescope
I have an older meade LX2000 EMC 10
The main problems encountered with the mechanics of the telescope centre around the mechanical swarf, grease compound, the liberal use of grease and the quality of machining of the main DEC and RA gears.
1. Remove the motors from the telescope. Be careful when removing either motor as there is a compression spring between the motor mounting frame and the worm shaft assembly.
The RA motor is located under the telescope body, removing the 4 screws and 2 Allen bolts will allow the bottom cover to be removed, thereby allowing access the the 2 Allen bolts holding the motor in place. Unplug the motor from the main PCB before removal.
The DEC motor is in the the fork arm containing the clutch and fine DEC adjustment control. (Never to be used with power applied to the scope). Remove the 3 small Allen screws holding the plastic cover plate in place and the DEC clutch knob to allow access to the motor. Remove the RJ45 connector located inside the telescope fork arm. Then remove the motor by unscrewing the 2 Allen bolts holding the motor in place.
2. Remove all grease from the motor worms, especially around the RA motor's magnetic pulse detector and the permanent magnet built into the worm shaft.
3. Remove all grease from the main DEC and RA gears, making sure to clean into the gear teeth.
4. Lightly re-grease with a Molybdenum Disulphide based grease (Castrol MS3 is great for this application if you can get it)
5. Assemble in reverse order. But before doing so, carry out the electrical adjustment above then, (a) relocate the the RA and DEC control PCB's in the vertical plane thereby gaining access to their respective backlash Allen screws. Adjust for 20thou max clearance when in final position. Note:- the DEC adjustment screw has to be replaced for a longer unit complete with a thin bolthead as this adjustment has to be carried out with a spanner....there is no room for an Allen key adjustment here.
6. A drop of Loctite must be applied after adjustment.
7. The final part of the process is to run in the gearing. Apply 12 volts to the motor wires, either at their respective plugs or to the motor direct. Allow to run for 2 to 3 hours in each direction by reversing the battery polarity to bed the teeth engagement. Remember to release the clutches.
Dec 28, 2011 | Optics
I have a makusutove 150 1800 telescope and I cant seem to get it to focus correctly - it seems as though the mirrors are focussing the light behind the viewing lens. I can get a focussed image if I hold...
You do not have enough BACK-FOCUS, you need an extension tube for the focuser like this one:
http://www.skiesunlimited.net/index.php?CategoryID=132
Buy the correct size for the focuser hole--
Jan 21, 2011 | Tasco 49114500 Spacestation(r) 114mm...
Hello there, my name is Paul and I had just recently purchased the Vivitar Refractor Telescope 60X/120X with Tripod. I have assembled everything correctly, however I have tried to view the moon, but I...
This is one of the worst telescopes you could have purchased. Plastic eyepieces and a plastic focuser! We receive many complaints about not being able to focus.
Try again--- next time buy one of these which is the best value in amateur astronomy.
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=08942
Nov 14, 2010 | Vivitar (1607225) Telescope
The alt/az adjustment knobs don't work
Are you sure the set screw is tightened? Some scopes have limited adjustment ande the screw need to be "centered" so you can adjust in both directions.
If all else fails Orion has a good customer service department:
http://www.telescope.com/control/view/page?p=custservice
Oct 29, 2009 | Orion Optics
Things are upside down looking thru the eyepiece on main telescop
If things are upside down in your telescope, you probably have a reflector telescope.it has curved mirror in the sealed end.take off the cover near the finder and point in the general direction of what you want to see.Make adjustments with the stuff on the mount.If you are viewing terrestrial objects, you will need an inverting lens to correct the image.It is called a Barlow lens and is much longer than the other lenses that come with the telescope.Good Luck
Mar 25, 2009 | Edu-Science (10166) Telescope
Hi i have an optus telescope when i find a star in my view find or the spacestation orbitating the earth i find it in my view find and when i look through the lens on the scope i see notting and i have...
Your finder is not aligned with your telescope. During the day time focus on a distant small object with the telescope-- then without moving the telescope adjust the crosshairs in the finder to match the telescope.
Dec 27, 2008 | Optics
Ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Mar 16, 2008 | GE WDSR2080D Top Load Washer
Meade Infinity 114EQ-DH Telescope Logo
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
