Question about ASUS Computers & Internet
I was surfing the web, left the room for a few minutes and came back to a blank screen. My remote mouse wouldn't work, I couldn't get it to react by wiggling the laptop mouse or hitting keypads. Two lights by the start button were lit up one has a 1, the other an A and they're both in the shape of a pad lock. What happened, why, and how can I get into my computer the next time it happens without turning it off?
    Scholar:
  • 135 Answers
Your laptop went into sleep mode/hibernate. In many cases windows could not recover from these situations. One solution is to update the BIOS of your laptop on the acer website. Easy way to fix it is setting your power options under control panel. You can configure the settings here if your pc is idle to prevent sleep mode or hibernate.
Posted on Sep 08, 2010
I have 2 linsar DVD tvs neither is responding to the remote control
The first thing to do is have the remote tested---almost every shop has a tester--point remote at it, press any or all buttons and the tester reacts---work or no work.
Many digital cameras can be used for this also: in a VERY DARK ROOM with camera on point and watch the display screen on the camera to see if a tiny flash of light when the buttons are pressed.
If remote tests bad (not sending) it can usually be taken apart and fixed in a few minutes---this is better and cheaper than going out to replace it.
We fix a lot in our shop, some for free for customers and ones that pay it is usually under ten dollars.
About the only other thing that could be bad if remote is good, the remote receiver in the units could be bad---unlikely 2 would both be bad........
Dec 10, 2012 | Televison & Video
Remote control doesn't work
Have the remote itself first checked---most tv shops have a tester--point remote at it and press buttons and it reacts-----Many digital cameras will react on their display screen in a very dark room in the same way.
If remote itself tests good the set has a receiver that takes the signal from the remote and it may be bad.
Aug 29, 2012 | LG 37LD450 37 in. TV
Monitor wont recognize my remote control
Confirm first the remote is actually working---it can be tested with a tester made for this and some digital cameras in a very dim room will react when the remote is pointed at them by flashing on the LCD display screen when buttons are pressed.
If remote is good about all that is left is a bad receiver in the set---a very very few sets do have a lockout feature for the remote but it is rare.
typical remote receiver, some do not have the metal frame.6_3_2012_1_16_26_pm.jpg
Jun 03, 2012 | HP 2509m 25 in. TV
Remote stoped working
Have the remote tested--shops have a tester that you point the remote at, press buttons and the tester will react.
Some digital cameras in a dark room will react on their display screen when the same thing is done.
Either the remote or the receiver in the set is causing this problem.
May 28, 2012 | Polaroid Televison & Video
TV remote has no effect
The remote can be tested without the set--most shops have a tester--point remote at it and press buttons and tester reacts.
Many digital cameras in a very dim room (nearly dark) will react in same way on their LCD display screen with a flash of light.
If remote tests good--the remote receiver in the set may be bad (try putting remote as close to set as possible to see if remote works).
A very few sets also have a feature to lock out the remote--owner manual would explain if that is what is wrong here.
May 27, 2012 | Televison & Video
Foxtel remote not working
Have the remote tested--there are simple testers the remote is pointed at, buttons (any) and the tester reacts.
Some digital cameras in a dimly lighted room will react on the screen in same way when remote is pointed and buttons pressed.
If remote is good the issue is likely the remote receiver the set uses.
Apr 24, 2012 | Televison & Video
My Mitsubishi wd-63527 turns on for a few seconds and shuts itself off.
The set may have (some models) a recessed reset button on front but that rarely does any good.
This model should have two resets other than that one----soft reset if it has it is with Mitsubishi remote: On, Menu,1,2,3 enter.
Set also has a hard reset which requires a four digit number code and resets set back to factory---it is a last resort and should not be done unless the soft one does not help.
I would have the remote tested as without it you cannot do any reset--
Most digital cameras in a dimly lighted or dark room will react on screen display when a remote is pointed at them and buttons pushed or most shops have a tester which will show and react to each and every button when remote is pointed at them and buttons pressed.
This model could have a keyboard lock feature which disables the keyboard but remote should still function.
First thing is to know if remote actually is working or not.
Apr 21, 2012 | Mitsubishi WD62527 62 in. LCD HDTV
My Bose remote turns on and off withthe comcast remote but the volume does not work unless I hitthe AUX button first. Does not work with the all button pushed.
Since multiple devices have volume controls you must inform the remote which device's volume you are changing. Just like the Power button. You wouldn't want everything in the room reacting to a generic command.
Aug 09, 2011 | Bose Cinemate Digital Home Theater System...
Why does my Belkin N wireless router disconnect and reconnects
Turn off the firewall in the Router
Step 1 : Open RSP By typing 192.168.2.1 on the address bar of internet explorer
Step 2 :On the left side click Firewall
Step 3 : Leave the password blank and click submit
Step 4 : Disable it and click Apply
Step 5 : Restart te Router And try a Skype call
Step 6 : If it works let me know at warrierrakesh@ymail.com
Jan 04, 2010 | Belkin Wireless-N Wireless Router with...
Computers & Internet Logo
170 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
