Question about Kitchen Ranges
How to replace a light bulb for Turboair rangehood- Argenta? I find it's difficult to take off the plastic cover of the light bulb. Many thanks.
4 Suggested Answers
SOURCE: Change light bulbs in rangehood
I found the instruction manual on the Baumatic website.
Thanks anyway
Posted on Apr 19, 2009
SOURCE: Venmar stove hood, plastic cover for light is broken
Need plastic cover on Venmar vent Hood, which measures 3 1/2 inches by 18 inches with 2 tabs.
Posted on Feb 25, 2010
The part number for the 1200,1400,1600 & 1800 series is #01752 light difuser.
They all fit the same opening.
Try venmar-ventilation.com.
Also appliancepartspro.com.
Posted on Feb 27, 2010
Where can i purchase a complete filter tray for my rangehood made by Parmco
http://www.axial.co.nz/onlineshop/Rangehoods/rh-Parmco
Sep 18, 2014 | Refrigerators
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Mar 16, 2011 | Microwave Ovens
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
How to replace fog light bulbs
hi..You will have to access the fog light bulb from below the vehicle.
Remove the plastic clips from the wheel well cover extension that is
below the fog light.once the clips are out and the plastic cover is pull
down,you should be able to see the back of the fog light.you can try
to replace the fog light bulb by removing the two 10mm bolts and slide
the fog light assemble out through the front of the bumper.Turn the cover
of the rear of the fog light and replace light.
try this out..
thank u..
kindly rate my response..
Jun 14, 2009 | 2004 Toyota Celica
Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
May 13, 2009 | Faber Perla 602599 Kitchen Hood
Thanks anyway
Apr 18, 2009 | Kitchen Ranges
How difficult is changing brake light on 2004 Envoy?
Hi. Its quite easy and i have a guide that will help you achieve your goal.
Step1 Determine how the bulb is accessed: On some models the lens (the red or white plastic part over the light) must be unscrewed from the outside, and on others the bulb is accessible only from inside the trunk. If there are no screws on the lens, you can assume that the bulb must be replaced from inside. Usually there will be a plastic cover that must be removed in order to access the bulb. There may be tabs, screws or small knobs that hold this plastic cover in place. Step2 replacelight_2s.jpg Unscrew the lens on the outside, or take off the plastic cover from inside the trunk, to reveal the bulb. Step3 replacelight_3s.jpg Unscrew the bulb. You'll have to push in and turn at the same time. Step4 Take the bulb with you to the auto supply store to help you find an exact duplicate. Step5 replacelight_5s.jpg Clean the connection with a wire brush and/or wipe it clean with a rag if there's any corrosion. Step6 replacelight_6s.jpg Screw the new bulb into the empty socket. Again, you'll have to push in and turn simultaneously. Line up the tiny raised bumps on the base of the bulb in order to screw it in. Step7 Replace the lens or the plastic cover. Step8 replacelight_8s.jpg Test your work by stepping on the brakes and turning on the headlights while a friend watches the new bulb to make sure it lights up.
Please rate and god bless.
Mar 26, 2009 | 2004 GMC Envoy
Replacing drivers side head light bulb 2004 Prius
The bulb isnt bad to replace. Is it HID? There is a round black plastic cover that needs to be unscrewed. A dealer normally charges .3 to change a bulb. If youre having difficulty, pay a professional. Its really not that difficult.
Dec 27, 2008 | 2004 Toyota Prius
Kitchen Ranges Logo
137 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
