Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kenmore 106.58582890 ice/water dispenser housing bottom warm to touch.
3 Suggested Answers
  • 23 Answers
SOURCE: Water/Ice Dispenser Mixed Up
Do you have separate levers for Ice and water, or do you have one lever and then you slide a switch to either one and then push the one lever.
Posted on Dec 07, 2007
milten1
  • 1304 Answers
SOURCE: kitchenaid no water, but ice
first thing i would check here is my water resivoir, on these models it has a tendency to freeze,, hit the tank and upper line with a hair dryer for several minutes then give the water a try....
barring that it may be time to change your water filter even if the sensor has not picked it up yet
Posted on Oct 26, 2009
I need the housing for my ice/water dispenser Kenmore Coldspot 106.56926600
Part Number: 8201756
http://www.applianceblog.com/mainforums/sears-kenmore/16912-kenmore-dispenser-housing-broken.html
Jun 11, 2012 | Kenmore Refrigerators
Kenmore front load washing machine leaking water from under the the detergent dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub. Pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer and remove it. Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening. Reach down into this opening to see if an item is inside the hose. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again. If the dispenser still leaks, then I recommend calling a service technician to diagnose and fix this problem.
May 01, 2012 | Kenmore Washing Machines
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Mold on Ice dispenser
If there is mold on the outside of the ice dispenser you should wipe it down periodically/ weekly or more often with a mild mixture of soapy water with a touch of bleach in it. Make sure that nothing in the refrigerator is blocking the port that ice is deliver through or that ice is not building up around the inside of it. And do not let water or ice lay stagnant in the door tray at the bottom of the dispenser.
Good Luck and God Bless
GodsAuthor
Aug 21, 2010 | Kenmore 53642 / 53644 Side by Side...
Kenmore 48102 Front load washer won't siphon out laundry detergent.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore Energy Star 44092 Front Load...
We have a Kenmore frontloader pooring water from soap dispenser
Oct 16, 2009 | Kenmore 44102 Front Load Washer
How do i clean my fabric softner dispenser on my kenmore elite
Feb 15, 2009 | Kenmore Washing Machines
Soap will not dispense
Feb 07, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Oct 16, 2007 | Kenmore Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
