Question about Optoma EZPRO 580 Metal Halide Replacement Lamp 250W [ Technology SP.80507.001 ] Projector Lamp
How to install 277 volts and how too get it. What are the requirements?
  • 35 Answers
Huh? could you possible be more obtuse?
Posted on Oct 27, 2010
Any wiring diagram for a 277 volt emergency lighting ballast
If you refer to emergency lighting tube with 277 volt, here is the wiring diagram for your reference:
Apr 08, 2014 | Electrical Supplies
Show how to set the itermatic et821c
Following link has manual for Intermatic ET8100 series
Choose astronomic dawn-dusk timer -or- 7-day programming
http://waterheatertimer.org/Intermatic-ET-series-timers-and-manuals.html#ET8000
be sure to install two AAA batteries in compartment located on front just below the buttons.
Also reset the timer prior to programming ... and this will clear any conflicts or prior programming.
Timer default voltage is 120 volt AC. Choose 208-240-277 volt by moving selector switch located on back of timer.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 17, 2014 | Intermatic ET8215C- 7-Day Electronic...
How to connect a 3 floresent bulb ballast to 277 voltage power source
first you need to know that the ballast is 277 volts or you will fry it, 120 volt ballast will not work on a 277 volt system, i suggest that you need to get an electrician to help you with this, if you hook it up wrong it will cause a problem
Nov 19, 2011 | Home
Hanging a outside light 277 volt 700 watt bulb. What size wire and breaker ic need
where are you putting this? on a commercial building? cause most homes do not have 277, if yes then use a 30 amp and # 10 wire
Oct 06, 2011 | Home
LP126HD3A rated for 265 volts AC single phase I have 240V ac single phase, how can I use this unit on 240V ac
You'd need to supply a "Buck-Boost" transformer to do this properly. Technically, the 265 VAC is one hot leg and neutral of a 480 VAC 3 Phase Y system that measures 277 VAC. The 265 number comes from this:
265 is the standard nameplate voltage for a 277 volt motor or AC unit.
230 is standard name plate for 240.
200 is standard name plate for 208
460 is standard name plate for 480.
110 is standard name plate for 120.
Most electricians call the hot leg / neutral circuit "277V AC".
Some popular "Buck-Boost" transformers will convert 208 to 240 and 240 to 208 volt systems, and 240 to 277 and 277 to 240 volt systems - among many other variations. These are auto-transformers as the primary secondary windings share a connection. KVA ratings differ significantly from name plate because of this fact. You should contact a qualified electrician to not only size, but wire the transformer for you. Failure to install a Buck-Boost transformer - and running this unit on 240V AC mains will cause premature failure of motors - fans and compressor due to overheating. This can also result in a fire hazard.
I hope this helps and good luck!
Sep 06, 2011 | LG LP126HD3A Air Conditioner
How to install 692 series light switch
P&S 692 is pilot light switch.
Pilot light requires neutral wire. Neutral wires are white wires twisted together and covered with wire nut located in back of electric box.
P&S 692 wires same as Cooper 277
http://waterheatertimer.org/images/Cooper-277-pilot-400.jpg
Jun 20, 2011 | Pass & Seymour #692LAGCC6 15A Almond SP...
Hello i have an intermatic model #t104r 208-277 volt my problem is that it works manually but it doesnt work automatically? whats wrong?
If you can also manually turn the dial so that the load turns ON and OFF, then the timer motor is bad :-( Replacements are available here for about $30:
http://www.aplussupply.com/intermatic/timer.htm
Scroll down to "WG 1573", Timer motor 208-277"
Dec 10, 2009 | Intermatic T104R 208-277Volt 40-amp Timer...
46 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
