Question about HP PSC 1315 All-In-One InkJet Printer
Every time I turn on my Hp 1315 printer it prints a sheet with lines and rectangles etc...at top of this sheet is says "to get best quality, follow the steps using this sheet" I do I get this to stop printing ?? wasting bunches of paper... Thanks Jim
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
secretgeek50
  • 57 Answers
SOURCE: getting extra 1 inch margin on ''normal'' or ''best'' print
Hi - have you checked the settings for both the document(s) you are trying to print and the defaults for the printer? It could be that there is a default setting that is trying to override what you want to do. I can't think of a reason for it to act differently with different quality of print, unless the ink is running low - that can affect a document printing or not, but again, I would not think to this effect.
Some things to check on -
- Go to the control panel, open the Printers and Faxes folder, and right click on your printer.
Choose PROPERTIES. Make sure everything is set like you want it to be.
(If you are on a network of some kind, someone else's settings could be overriding yours. If you are not on a network, make sure "Do not share this printer" is checked on the sharing tab.)
-try to update the driver. Here is a good place to look -
http://preview.tinyurl.com/6bwuk8
I am assuming you have already actually checked for little scraplettes of paper that might be stuck near a sensor or an ink cartridge. I'd even pop the ink cartridges out and put them back in. Sometimes dust can build up on them if a printer isn't used often, or has been sitting for a long time.
Also, make sure you don't have a setting on your own computer to print out a blank sheet before a printing job. If your printer is actually run through an I/T department at work, they could have it set up by default to kick out a separator sheet to help keep orders separated.
I hope one of these things might work for you! : )
Posted on Nov 20, 2008
SOURCE: My HP PSC 1315 printer
printer will not power up!
Posted on Dec 15, 2008
yooperbud
  • 8637 Answers
SOURCE: HP Business Inkjet 1200 printer always prints the Alignment Page
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
hashchathy
  • 246 Answers
SOURCE: Prints alignment sheet every time you turn power on.
please try to reinstall the printer driver
Posted on Feb 13, 2009
My HP PSC 1350v prints a test page every time I turn on the printer?
Bet you recently replaced a print cartridge!
That model of printer recalibrates after any cartridge replacement.
Let one of those sheets print out in full. Read what is on the sheet. Place the sheet on the scanner
and press the button that the sheet indicated to be pressed. The printer will go through a alignment
cycle then quit. Once that is finished you should not have to do anything till the next time your change
a print cartridge.
Mar 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Alignment sheet prints---cannot print anything else
u will have to first scan the alignment paper in your scanner this will solve your problem
Nov 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
After replacing the ink cartridges ran out I replaced them for new ones and the machine is not telling me that cartridges are empty tried and tried to rereplace them and I still keep getting the same
  1. Press the Menu/Set key.
  2. Press the up or down navigation key until TEST PRINT appears on the LCD.
  3. Press Fax Start. The DCP/MFC begins printing the Print Quality Test Sheet.
  4. By reviewing this Test Sheet, you can determine if the print quality or alignment needs improvement or adjustment.
StepA - Checking the print quality:
  1. The display will read "IS STEP "A" OK?" 1.YES 2. NO.
    Before choosing YES or NO, closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
    If all lines are clear and visible, press 1 (YES) and proceed to StepB. If you can see missing short lines, press 2 (NO).
  2. The display will then ask you if the print quality is OK for each color. Press 2(NO) for any color with the problem.
  3. The display will then show START CLEANING? 1.YES 2. NO.
    Press 1(YES) and the DCP/MFC will start cleaning the color ink cartridges.
  4. After the cleaning is finished, press Fax Start. The DCP/MFC will print another Print Quality Test Sheet.
  5. If you can see missing short lines in any of the four color blocks press 2 (NO) and repea the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
StepB - Setting the Alignment:
  1. The display will then read "IS STEP "B" OK?".
  2. Examine the 600 DPI and 1200 DPI test prints on the Print Quality Test Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1(YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  3. Print another Print Quality Test Sheet by following the steps provided at the top of this page and check it.
  4. Press Stop/Exit.
Aug 11, 2008 | Brother MFC 420CN All-In-One InkJet...
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
2.
3.
4.
5.
6.
7.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1350 Photo Printing (Glossy Paper) Pront Quality issue
keep checking the HP site for an updated Driver for your printer, but why not use an online photo printing service like Walgreens or Walmart, You can't possibly print photos at home cheaper than they can, and this way you get actual photographs back.
Dec 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
148 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
