Question about Sony Handycam DCR-TRV22 Mini DV Digital Camcorder
Camcorder appears to record but when placed in VCR mode there is no playback and the screen is blue. Is there an easy fix?
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 08, 2010
The LCD is blue and won't play back . We have cleaned it. Camera mode works when recording. Just no playback picture in VCR mode. ...
you most likely has a bad screen, if you can, play back your video into a VCR, dvd burner or televisino with rca type inputs, this will at least let you save your movies.
Mar 18, 2011 | Sony Handycam DCR-TRV250 Digital Camcorder
Canon HV10 camcorder - can't get video mode to playback
hi, if you get blue screen,but your recording has been ok, then you must be change LCD FLAP, you sure get fix your camera,
Aug 30, 2009 | Canon HV10 HDV Digital Camcorder
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
Blue screen
In the playback mode, the screen is suppose to be blue, till you start the tape playing, but if you get the blue screen in the record mode, I have not idea how to help you. You should see what the camera lens see, when in record mode.
Apr 02, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
No playback just blue screen
sounds like the dvc7 needs a cleaning tape.
Sep 24, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
Oct 31, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Open Questions:
Sony Handycam DCR-TRV22 Mini DV Digital Camcorder Logo
78 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
