Question about Samsung HM500JI 500 GB SATA Hard Drive
Comment formater mon disque dur externe SAMSUNG HM500JI500GB ? mon disque dur LG de Samsung ne s'ouvre pas et ne se formate pas avec tout les systèmes Windows quel est la solution ?
FujiSiemens
SOURCE: Formatting a Samsung MP0804H IDE extrernal HDD from NTFS to FAT32
Hi there Dave, well you can use a software called Partition Magic 8 to convert your 80GB hard disk to utilise FAT32. This software is quite user friendly. There are several options for you to choose form in this software including resizing your drive and creating partitions on the fly. However some settings requites a computer restart or reboot in order to complete successfully. This software can be obtained from most software stores or even download form the internet. After installing the software and running it, your drive should show inside the programme; right click on the drive you want to change a setting and select the options available. At the 'Format' button select FAT32. You will be asked for drive letters and cluster size but you can use the default settings, then apply the settings. Once you are done with that select the Okay button in the main programme window and the formatting process will start. Hope this helped you. Cheers :-)
Posted on Feb 13, 2009
  • 67 Answers
SOURCE: Samsung SpinPoint SV1203N 120 GB FHD
Try increasing the actual partition to the capacity numbers in the windows xp formatting , and also format the hard drive using NTFS .
Posted on Dec 09, 2007
checkitright
  • 1362 Answers
SOURCE: Prbl?me de d?tection
1-etre vous sure que l'attachement est fonctionel? essayer un autre
2-votre PC doit vous dire qu'il ya un appareil externe qui est connecte
3- ensuite vous installez le driver essayez ces sites gatuits pour votre driver
http://www.printcountry.com/drivers/SAMSUNG_SF_5100_DRIVER_DOWNLOAD.htm
http://hubpages.com/hub/Samsung-Printer-Drivers
Posted on Aug 28, 2008
pankaj_dic
  • 1250 Answers
SOURCE: my samsung 500gb external hdd is niether copying nor being format
you can do one thing remove the hard drive from the casing and put on some other casing then check, if the problem is the same then its the problem of hard disk
Posted on Oct 09, 2009
  • 76 Answers
SOURCE: I just bought a samsung
The computer should see drives plugged into a USB port but might not know what they are.
If the computer gives no indication after you plug in a devise check the USB cable.
Try the following 1. Go to start 2. Go to the control panel. 3 Click Add new hardware and follow the Wizard instructions.
Posted on Sep 23, 2010
Je n'arrive plus a faire suivre mes mails et videos diaporamas une fenetre s'ouvre avec un panneau interdiction me disant que le mail ne pouvait pas etre envoye . que faire ? d'avance merci .
Bonjour, il va falloir que tu fermes ton compte Yahoo et que tu t'ouvres un compte avec gmail ou hotmail. Ce qui arrive c'est que Yahoo intercepte toutes les correspondances et ne les envoient jamais a nos comptes. J'ai deja eu le meme probleme et ma compagnie d'internet ont decouvert que Yahoo prenaient tout ce que j'envoyais (meme quand j'envoyais des photos, videos ou couriels a mes comptes gmail et hotmail). Depuis que j'ai abandonner Yahoo, je n'ai plus de probleme. :-) J'espere que ma reponse t'aideras.
Nov 21, 2011 | Yahoo Mail
Mon ordinateur ne prend pas windows 7
Hey! Il semble que votre logiciel est dommage ? moi pour ce que vous devriez probablement faire est d'essayer ? nouveau d'installer des fen?tres ? nouveau si cela ne fonctionne pas essayer de d?marrer votre ordinateur avec Linux(je vous recommande de Linux dans ce cas le t?l?charger ici: http://www. pendrivelinux.com/universal-usb-installer-easy-as-1-2-3 /) si elle fonctionne parfaitement les moyens de votre disque dur est ok sinon vous avez un probl?memat?riel et c'est probablement votre disque dur et vous avez besoin de le changer . bonne chance et faites moi savoir si ?a marche:)
Sep 17, 2011 | Compaq Presario X1000 Notebook
Ne trouve pas le pilote du dvd ram gt 31n le mien ne fonctionne plus
QUESTION: "can not find the driver dvd ram gt 31n mine no longer works"
Salut.
Il n'est pas clair ce que vous entendez par "DVD-RAM 31n GT." J'ai fait des recherches de ce numéro de modèle "GT 31n", sans succès. Je vais donc supposer que c'est le numéro de modèle du lecteur de disque optique interne (DVD-RAM) de votre ordinateur.
Vous ne dites pas quel système d'exploitation que vous utilisez. Vous avez également choisi de ne pas donner toutes les informations concernant votre ordinateur ou de ses spécifications. Ces aurait pu avoir été des éléments d'information utiles.
Presque chaque système d'exploitation informatique, en particulier les courants, ne nécessite aucun pilote supplémentaire pour les lecteurs optiques comme celle du lecteur DVD-RAM. Les pilotes pour fonctionner presque chaque lecteur optique sont déjà intégrés dans le système d'exploitation.
Le seul logiciel que vous pouvez télécharger pour ce lecteur optique est Firmware. Firmware améliore et renforce les spécifications de performance, mais on peut rarement réparer les défauts ou restaurer un disque optique non-fonctionnement d'une fonctionnalité normale avec Firmware.
Vérifiez l'étiquette pour le fabricant du lecteur. Il est susceptible d'avoir été fabriqué par l'une des entreprises connues pour ce produit (LG, Sony, Hitachi, Samsung, etc.) Allez sur le site Support et Téléchargements de cette entreprise et vérifiez les mises à jour du Firmware associés à ce lecteur optique et de votre système d'exploitation.
Je suis presque certain que peu importe où vous regardez, vous ne trouverez pas de pilotes pour ce périphérique.
Si l'appareil ne fonctionne pas il pourrait être un problème de Jumper Settings. Regardez à l'arrière du lecteur pour voir le Jumper Pins et le Jumper. Regardez sur l'étiquette pour voir un diagramme des paramètres différents pôles.
Si il est toujours défectueux, essayez de le connecter avec un autre câble IDE, et essayez de nettoyer la lentille laser avec un Nettoyeur de CD DVD Lens.
Si il est lente, c'est peut être un problème avec l'ordinateur. Certains systèmes d'exploitation va automatiquement ralentir un lecteur optique à une faible vitesse de base après il a démontré un certain nombre d'erreurs de lecture.
Aussi essayez de vérifier et modifier les paramètres (SATA /) IDE dans le BIOS.
Enfin, le lecteur peut aussi être défectueux et peut-être a besoin d'être remplacé.
J'espère que cela aide.
Si cette réponse va certaine manière à aider à résoudre votre requête, un problème ou de défaut, s'il vous plaît prendre le temps de l'évaluer.
Cela permet aux fournisseurs de solutions, comme moi, mieux comprendre les besoins et le point de vue des questionneurs, comme vous, et nous guide dans l'exploration des meilleures façons de fournir les réponses les plus complets de qualité, utiles et de haute et de solutions que nous pouvons.
Si vous avez besoin d'aide, s'il vous plaît n'hésitez pas à poster une autre question ou ajouter un commentaire à cette question.
Merci pour avoir utilisé FixYa.
Sep 15, 2011 | Computers & Internet
MON DISQUE DUR NE SE CONNECTE PLUS A MON ORDINATEUR
Bonjour.
Connectez le disque dur a autre ordinateur en utilisant un cable USB different u s'il vous plait. Si cela ne fonctionne pas sur le disque dur doit etre retire del boitier et utilise un boitier de disque dur different.
Voici un article en anglais sur le meme probl?me:
Aug 07, 2011 | Iomega 34611 500 GB USB Hard Drive
J'ai un pc acer aspire m1640 et j'arrive pas instaler xp
Cet Acer a un disque dur SATA - XP ne peut le reconnaitre pendant l'installation sans le driver, Tu peut le trouver ici (avec tout les autres)
http://www.getpcmemory.com/drivers/download-acer-aspire-m1640-desktop-windows-xp-drivers/
Decompresse-le e brule-le sur un cd - quand (pendant la installation) tu sera questionne de lui met le dans le lecteur.
Feb 21, 2010 | Acer Aspire M1640 Refurbished Intel...
Plus de lecture sur mon MAC
LaCie externe USB 2.0 500 Go 7200 tr / min de 500 Go Disque dur
Je un ne sais pas exactement ce que vous faites référence en ce qui concerne la
fonctionnalités de votre Lacie avec votre Mac, comme je l'aurais plus besoin de détails
de vous. Mais, au moins à vous diriger dans la bonne direction.
Tout d'abord voici le lien pour votre externe LaCie USB 2.0 500 Gig
Disque dur pour plus de soutien de LaCie:
Lien:
* LaCie externe USB 2.0 500 Go 7200 tr / min de 500 Go Hard Drive Support
En outre, si, pour plus de soutien pour des problèmes avec ce disque dur, y compris si nécessaire d'avoir à reformater votre disque dur, voici le lien:
Plus de dépannage pour votre LaCie externe USB 2.0 500 Go HD pour Mac.
Si vous avez besoin davantage d'aide, laissez-nous savoir si ces liens de soutien ne permet pas de résoudre votre problème actuel avec LaCie. également fournir des précisions sur la question, afin que nous puissions mieux vous aider.
Observe,
-Mactechtrainer
Jan 30, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Mon Lecteur MP3 Apple iPod classic 80GB ne fonctionne pas
Réinitialiser Pour réinitialiser votre iPod: * 1. Basculer le commutateur Hold sur et en dehors. (Positionnez-le sur Hold, puis désactivez-le à nouveau.) * 2. Appuyez sur la touche Menu et du centre (Sélection) simultanément sur les boutons jusqu'à ce que le logo Apple apparaît, environ 6 à 10 secondes. Vous devrez peut-être répéter cette étape.
Astuce: Si vous éprouvez des difficultés de réinitialiser votre iPod, placez-le sur une surface plane. Assurez-vous que le doigt qui appuie sur le bouton de sélection ne touche une partie de la molette cliquable. Vérifiez également que vous appuyez sur le bouton Menu vers l'extérieur de la molette cliquable, et non vers le centre. * Si les étapes ci-dessus ne fonctionne pas, essayez de connecter l'iPod à un adaptateur secteur et branchez l'adaptateur dans une prise électrique, ou connectez l'iPod à votre ordinateur. Assurez-vous que l'ordinateur est allumé et qu'il n'est pas d'aller dormir.
Si ce permis de résoudre votre problème, vous avez terminé.
Si ne pas essayer cette
Si ne pas essayer thisRetry votre iPod avec un autre port USB de votre ordinateur, pas un port USB de votre clavier ou un concentrateur.
Si ne pas essayer ce redémarrage Redémarrez votre ordinateur et assurez-vous que vous avez le logiciel dernières mises à jour installées. Note: * Pour mettre à jour vos logiciels Windows, sélectionnez Windows Update dans le menu Outils d'Internet Explorer. * Pour mettre à jour vos logiciels Mac OS, sélectionnez Software Update dans le menu Pomme.
Réinstaller * Pour mettre à jour et réinstaller votre logiciel de l'iPod, commencez par télécharger la dernière version d'iTunes. * Ensuite, ouvrez la nouvelle version d'iTunes et connectez votre iPod à votre ordinateur. * Sélectionnez votre iPod dans la liste Source et cliquez sur "Vérifier les mises à jour" sous l'onglet Résumé. iTunes vérifiera si votre iPod doit être mis à jour et effectuer la mise à jour pour vous. * Si cela ne résout pas le problème, essayez de désinstaller complètement iTunes et de réinstaller la dernière version d'iTunes.
Restaurer * Note: étant donné que la restauration efface l'ensemble des morceaux et des fichiers sur l'iPod, assurez-vous de sauvegarder tous les fichiers que vous avez enregistrés sur le disque iPod. Toutes vos chansons, vidéos, podcasts, livres audio et jeux peuvent être chargés à votre iPod à condition que vous les avez stockés dans votre bibliothèque iTunes. Comment faire pour restaurer votre iPod: * 1. Assurez-vous que vous avez réinstallé la dernière version d'iTunes. * 2. Ouvrez iTunes, puis connectez votre iPod à votre ordinateur. * 3. Après quelques instants, il apparaîtra dans la liste Source dans iTunes. Si l'iPod d'affichage ne montre pas les «Connecté» ou «Ne pas déconnecter" vous pouvez avoir besoin de mettre l'iPod en mode disque pour continuer. * 4. Sélectionnez votre iPod dans la liste des sources et vous verrez informations à ce sujet figurent dans l'onglet Résumé de la fenêtre iTunes principal. * 5. Cliquez sur le bouton Restaurer. Vous serez invité avec des options de restaurer un ou plusieurs qui peuvent rapidement iTunes pour télécharger automatiquement de la dernière version du logiciel iPod. Les 4 options de restauration possibles sont:
Si cela ne résout pas votre problème, alors vous pourriez essayer d'appeler l'assistance Apple
Sep 27, 2009 | Apple iPod classic MP3 Player
On me propose d acheter d occasion une imprimante lexmark x 11500 au prix de 50euro. pouvez vous me dire en fran?ais si c est bien et se ce mod?le va s adapter a mon ordinateur qui est tout simple, de...
D'occasion a mon avis ( j'en ai un ) c'est cher ! mieux vaut en acheter un neuf pour quelques euros de plus - au moins il y a une garantie -
Je vous avertis a l' avance que l'encre est SUPER chere ! mais tout depend de vos besoins - le mien marche bien, pratique, mais finalement pour une copie par exemple, a mon avis, mieux vaut aller a la boutique du coin ! (parce que l' encre est si chere !) - mais ca depanne quand on est presse -
Le scanner marche bien - par contre je ne sais toujours pas comment imprimer les photos sur papier photos... Lexmark ne semble pas avoir d'encre speciale photo - je n'ai pas essaye l'encre normale sur papier photo avec cette imprimante, parce que mes essais avec une autre n'ont pas marche ....
J'espere que ca vus donne une idee ....
Mar 07, 2009 | Lexmark X1150 All-In-One InkJet Printer
Disque cod?
To have answers in these types of groups it is best to translate in to English.
The question in English:
Hello, I have a problem with a laptop which called for a password bios. Well, I removed the battery for a moment and that is installed. I launched the boot on the disc cd then it did the restart, it asks me a password hard disk. I then passes through several means even SKY_FOX I tried but nothing.C 'is a brand Fujitsu Siemens Lifebook and I do even more started on the system' exploitation. I really need help, if you could do something without needing expensive experts. Thank you. __ Have you contacted the former owner to get the password? If the hard disk is pass-word protected and you do not have the password, the fix would be to un-install the partition, and re-make it. Then do the full re-installation of the operating system, and the re-registration for ownership. In some cases where the hard disk is password locked, there may be no possible way to be allowed to undo and re-make the partition to do a full re-install. If this is the case, changing the hard disk will fix it. The old hard disk would be scrapped unless you can have its password. BIOS Level Password Procedure: With some models of computers, you can remove the BIOS battery and wait until the BIOS setup is depleted. Then you should then be able to have access to re-set up the BIOS. You will have the choice to put in a new password or simply not to. If the computer hardware is pass-worded at the BIOS level and it does not deplete with the battery removal, you will have to send the computer back to the manufacture to have the computer un-locked. You will have to pay the shipping and the service fee. When sending the computer back to the manufacture for the unlock, you will be asked for proof of ownership of the computer with proof of identification. With most computer companies, a copy of the purchase invoice, and a copy of your driver's permit or citizenship card should be acceptable. ________________________________
Google Translated, Answer in French: Avez-vous contacté l'ancien propriétaire pour obtenir le mot de passe?
Si le disque dur est mot de passe protégé et vous n'avez pas le mot de passe, le correctif serait d'installer un-la partition, et re-faire. Ensuite, faites le plein de nouveau l'installation du système d'exploitation, et le ré-enregistrement de la propriété.
Dans certains cas où le disque dur mot de passe est verrouillé, mai il ne peut être moyen d'être autorisé à annuler et re-faites une partition de faire une re-installer. Si tel est le cas, changer le disque dur fixe. L'ancien disque dur serait supprimé à moins que vous ne peut avoir son mot de passe.
Mot de passe BIOS niveau procédure:
Avec certains modèles d'ordinateurs, vous pouvez supprimer le BIOS batterie et attendez jusqu'à ce que le BIOS est épuisé. Ensuite, vous devez alors être en mesure d'avoir accès à re-configurer le BIOS. Vous aurez le choix de mettre en un nouveau mot de passe ou tout simplement ne pas le faire.
Si le matériel est libellée au passage à niveau le BIOS et ne pas épuiser la batterie avec le déménagement, vous aurez à envoyer l'ordinateur à la fabrication d'avoir un ordinateur sans littoral. Vous devrez payer les frais de livraison et les frais de service. Lors de l'envoi de l'ordinateur à la fabrication pour la déverrouiller, il vous sera demandé une preuve de propriété de l'ordinateur avec la preuve d'identification. Avec la plupart des sociétés informatiques, une copie de la facture d'achat, et une copie de votre permis de conduire ou carte de citoyenneté devrait être acceptable.
Jerry G.
Sep 03, 2008 | Intel Motherboard
Contr?leur IDE VIA PCI Bus Master
Quelle est la marque et le modèle de votre ordinateur?
Jan 11, 2008 | Microsoft Windows 98 for PC
Samsung HM500JI 500 GB SATA Hard Drive Logo
121 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
