Question about Samsung RM255LASH Side by Side Refrigerator
Freezer and fridge quit cooling. The fan works and the display reads 58 degrees for both. The tstat setting is -2 for freezer and 36 for fridge. sounds like compressor isn't running. any suggestions?
  • Samsung Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 08, 2010
FRIDGE FREEZER, HAS ONLY THE FRIDGE PORTION WORKING NORMALLY, SO WHY IS FREEZER BARELY ABOVE -2 DEGREES?
the fridge is working and the freezer is freezing so what is your problem?
what is the problem with freezer at -2 degrees? i dont understand what your problem is? ?????
is -2 not cold enough? too cold? what is your problem?? you dont say. do you know the english language? in my world, a refrig that works , but the freezer gets -2 degrees is not a problem? what is your issue ? you dont say? change the setting for the freezer.
if you want it other than -2 degrees. what is the malfunction?
you read and speak english language right?
Dec 29, 2014 | Refrigerators
Just had the thermistors replaced in the frigde freezer the fan is working now and the freezer is - 22 but the fridge is at 14 degrees.
Where are you getting these temps from? If your unit is in Celsius mode, that would mean fridge is 57.2 degrees and Freezer would be -7.6 degrees. Without a model number I am unable to see the style of controls you have. Double check all settings are in the middle, meaning if you have a digital display, temp @ 0-36, if you have dials make sure they are set to the middle ie..(a-e then set at c, 1-9 set at 5).
I hope this helps...
Jul 23, 2011 | Refrigerators
I have a GE mdl PSI23SGRCSV side by side. initially the digital temp displays for both freezer and fridge sides went to 16 on freezer side and 43 on fridge side. This happened almost overnight it seemed....
it may be that your fridge is now low on freon the techs now do not know what to do the best thing to do is to call the tech and ask them to test the compressor pressures and see if it is low on charge. unless you know how to take the lower back panel off (the one that is probably cardboard) and feel the lines on the compressor and see if it is really cold and really hot that means that it is cooling properly but if it feels a little warm cominv out of the cooling side and hot on the return side then you need more freon.
Mar 04, 2011 | Refrigerators
Refrigerator is not working, freezer is working
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore trio 569. Fridge No getting cold Temp is now 81 degrees Freezer ice cold
Mark, check to see if the fan is running in the freezer section. Common problem on these 596's trios. If the fan is running, you might have a defrost problem. If it isn't, your part number for the motor is 67002778. No fan, no cool upstairs...Catriver..post back.
Mar 04, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Samsung RM255LASH Side by Side Refrigerator Logo
123 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
