Question about NEC ETJ 16DD-2 Corded Phone
How do i put my phone on DND?? - NEC ETJ 16DD-2 Corded Phone
Is there another way to put it on dnd??
yes, ask system admin for *code to dial
Sep 02, 2014 | Cisco 7942G IP Phone
The ringer is turned off and can't figure out how to turn it on. So I'm not getting any calls. My message light does not come on either. Please help!
Hello
Examine the base of the Uniden cordless phone. Locate the "DND" button on the main base of the phone.The DND button means do not disturb and it puts the phone in silent mode when pressed
Reactivate the ringer by pressing the "DND" button again. All the handsets will ring when someone calls you.
Jun 10, 2011 | Uniden DECT 6.0 Cordless Telephone...
FWD/DND SHOWING RED AND INCOMING CALLS RESTRICTED
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
How do I divert calls to a mobile number and then undivert calls
pickup the handset (phone... watever) and press the FWD/DND button then press #2 then type in the number of the mobile (or number you want to forward to...), and hang up the phone... then when your finished with the call forwarding function, press FWD/DND again and this time press #0
What 2 does it turn on the call forwarding feature
. and 0 turns off forwarding/do not disturb functions
theres 5 different functions after you press FWD/DND
0: turns FWD/DND off
1: put the phone into Do Not Disturb Mode
2: call forwarding
3: Busy-Forwarding.. which means if your on the phone and someone rings, it forwards them to the number you specify
4: No Answer- when you don't answer the phone if forwards the caller onto the number you type in
and lastly 5: Busy/No Answer- does both function 3 & 4
i hope i've helped
, Cameron
Jan 22, 2010 | Panasonic KX-T7630 Corded Phone
How do I put my phone on DND?
You get a chance for that to work next time :-)
Panasonic features are in the system, not the phone. If you have a TA series, from the phone, pick up the handset and press the FWD/DND button and dial 4#. (you may also dial 71 in place of pressing the button).
Cancel is 0# in place of 4#, but you also have CF to voice mail issues, where 1+VM EXT is all calls and 2 is BUSY/NA.
If you have a TD or TDA or TAW system, you get lucky, because the FWD/DND button works in 3 modes. For DND it's 7101 or *7101. The button will light with a solid red light and when you press it, it either flashes or goes off. The system gives you both FWD and DND settings.
Carl
Apr 05, 2009 | Panasonic KX-T7730 Corded Phone
Need to set up DND
You would have to have know the type of telephone system.
go into prog 39 and put code 498 on that port(000*015)
info@ameritelnj.com
Tony
Jan 16, 2009 | Toshiba DKT2020SD Phone
Taking off DND
press "feature" 69 then press "feature" again ~ problem solved!
May 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
DND Feature turned on
DND feature is 85.
To cancel DND press FEATURE # 8 5 on the set with the issue.
Feature 69 is for priority calling...
Feb 29, 2008 | NorStar Meridian M7310 Phone
NEC ETJ 16DD-2 Corded Phone Logo
26 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
